Question about Kenmore Heating & Cooling
What is the wattage for a kenmore 30 dehumidifier? Model # C675-25930-20
2 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: what is wattage of kenmore 110.22942101
Now you have presented and interesting question. Lets assume your washer uses 120 volts and during different parts of the cycle it uses more watts. Here is a link to a calculator. Just remember the higher the voltage the lower the watts. Sea Breeze
http://www.crownaudio.com/apps_htm/designtools/ohms-law.htm
Posted on Jun 28, 2009
How many watts does my oven use?
The wattage will be on a plate on the outside of your appliance! Probably on the back or side! The wattage will depend on the country of use!
Dec 31, 2014 | Kenmore 30" Electric Double Wall Oven
Tip
Technical service manual for the 54501 Dehumidifier
Again, this is shown as a Goldstar LD50EL. But, it is the same model as the Kenmore and is the actual unit built FOR Kenmore. Below is the url for the tech service manual. http://136.166.4.200/contents/Files/Dehumidifiers/DH404E/DH404E_service_manual.pdf
on Jul 31, 2007 | Kenmore 54501 Dehumidifier
How to set timer on 2014 Kenmore 50 pt Dehumidifier
if you hold mode button down does it not cycle thru timer settings?
May 24, 2014 | Kenmore 30-Pint EnergyStar Dehumidifier
My Kenmore Elite Dehumidifier model 42-99701 runs but does not cool enough to collect water. Not a drop. found this page where I can order parts but I don't know what part I need to replace. Please help....
Dehumidifers are cheaply made and most likely it has formed a refrigerant leak. It would cost more to repair than to replace with a new one. They are basically a disposable appliance.
Oct 12, 2013 | Kenmore 54501 Dehumidifier
I will use a transformer that cuts down from 220volts to 110volts. I don't know the wattage of AD40DSR1 dehumidifier. What is it?
whats the brandname of the dehumidifier more importantly the amperage. a number with the letter (a) next to it. lets say it is 0.5A . then your wattage should be the voltage of the dehumidifier multiplied by the amperage of the dehumidifier. "ASSUMING" the voltage is 110v and the amperage 0.5A then 110Vx0.5A= 55watts
Aug 13, 2011 | Whirlpool AD40DSR Dehumidifier
Kenmore dehumidifier M/N 580.53650200 only runs for about 1 minute, then stops. Dehumidifying level is set to minimum (40) and it's damp in the basement so I know the air is not too dry. The fan works, the...
Well to knowledge the problem 40 percent is dry. means your basement is great. humidity should be 30/50 percent 50 grows mold. also if it runs for a min the auot shut off is activating. check this first.
Manifestr
Oct 06, 2009 | Kenmore 5365 Dehumidifier
What is the amperage rating for the kenmore 30'' electric built-in oven model number 911.41065791 at 240volts?
most ovens just inside the oven door on the top edge have a metal nameplate with model# and the wattage at X# of volts,it could be on the rear but most in frt,take total wattage and devide by input (supply)voltage i.e. 240volts(example 12,000watts/240volts=50 amps)
Jul 11, 2009 | Ovens
Dehumidifier
IS THE ROOM HUMIDITY LOW. IF IT IS BELOW 30% THE HUMIDISTAT WILL SHUT DOWN THE UNIT. THE AMMBIENT TEMP SHOULD BE ABOVE 65 DEGREES AND THE HUMIDITY SHOULD BE ABOVE 50 %.
Mar 26, 2008 | Kenmore 53301 Dehumidifier
30 pint model # M30H3082A
A common problem - low on refrigerant. Unfortunately it's not a simple fix. Check your warranty to see if you're still covered for "Sealed system repairs"
Nov 30, 2007 | Kenmore 54501 Dehumidifier
Heating & Cooling Logo
49 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
