Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Hi Need instructions on how to operate, no water or steam but tank is hot.
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Nov 19, 2010
We have recently installed a new water filter into our steam mop ,but it does not work now and makes a load clicking noise
Follow the instructions to de scale the steam chamber. If it is not getting hot at all , check the thermostst and the hi temp safety switch for proper operation.
Dec 31, 2014 | Filter Vacuums
The heating element within the steam cleaner gets hot but does not emit any ateam
Hi norma, make sure all the tanks are full water and soap and operating properly. Refer to the manual, Greg.
Dec 20, 2014 | Vacuums
My h2o mop won't steam. How do i fix it?
If your H2O mop will not steam:
1. Ensure you have followed the operating instructions.
2. Ensure you have followed the troubleshooting instructions.
If the unit fails to produce steam:
3. Switch off the power at the outlet.
4. Look at the water reservoir. Inside you will see a flexible tube with a cone on the end. Tilt the unit or give it a gentle shake to submerge the cone in water.
5. With the cone submerged, switch on the power supply and follow the normal instructions. The unit should produce steam as normal.
Note: Unless the cone is submerged in water, the unit will not steam.
Apr 21, 2012 | H2o TR220002 Steam Cleaner
Just need simple instructions, can not find mine at the moment due to Christmas rush. Do I need to put warm or cold water in tank?
It doesn't really matter - the water is heated to the correct temperature inside the steam mop - so you can use either. It's recommended that you fill with clean cold water, but if you put warm water in, it will still work and will generate steam faster from startup.
Whichever you use, just make sure you don't overfill it past the MAX mark on the tank.
Regards,
BElectric
Dec 16, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop will not syeam grey pruple shark steam mop
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
heatman101
Nov 04, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop is spilling water out and not steaming.
Empty tank and fill with bottled spring water...
heatman101
Dec 05, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Stopped steaming only releases water into pad
heatman101
ag
Mar 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Prolectrix 3 tier steam
Is the unit spraying ok? If not then the heater may be plugged. Other than that, you should fill the tank with hot tap water, the the heater will only heat it alittle more, you won't really see steam.
Jan 19, 2008 | Bissell 1699 ProHeat Clear View Upright...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
302 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Marvin
Marvin
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
