Question about Panasonic DMR-E85H DVD Recorder
Hd tv i have an hd projection tv, a blue ray player and a blue ray dvd, why isnt my picture coming out to be clear and sharp, its not an hd picture???
    Novelist:
    Scholar:
  • 100 Answers
Greetings allyz 1,
I am not exactly sure I understand your question? are you asking why your signal from your DMR-E85H isn't HD?
If that is the case, after looking at your DMR-E85H's specs it only provides a standard 480i or 480p broadcast.
But if your question is if you have a HDTV and a BluRay player, with BluRay DVD's why your not receiving a HD picture it maybe due to your connection. for my understanding you should be able to connect the standard component cables from the BluRay player to your television to receive the HD signal, but HDMI may be best.
I hope this answers your questions.
Jon
Go Ahead. Use Us.
Posted on Jun 16, 2008
    President:
  • 624 Answers
Projection TV's have a very nice picture, but they still do not look as sharp as a plasma, LCD or CRT. It is an HD picture, it is just the problem with projection TV's (depending on just how bad the picture is), it should still look good, but it will not compete with the others types of TV's
I have a Mitsubishi WD-62525 TV with a Blue Ray DVD player hooked up to it. When I play a standard DVD, the picture is fine but if I play a Blue Ray DVD the picture is scrambled. I hooked the same DVD...
Might be tuned to the wrong output. The big tv has more than one input and is select able. Is there a blue ray selection for TV or input for that device.
Aug 09, 2014 | Mitsubishi WD Televison & Video
My BD530 player doesn't play all movies clearly. Some come cover good others re all snowy
When properly connected to a High Definition display or TV, Blu-Ray Disks (BD) should play crystal clearly. Inserting an old "non-Blu-Ray" disk (or the original "DVD") in the Blu-Ray player will display a comparatively "fuzzy" picture. This is the difference between High Definition and Standard Definition. A "BD player" can not "upgrade" the picture quality on DVDs to that of a BD or High Definition picture.
Rent, purchase or choose Blu-Ray Disks (BD) whenever a choice is offered to view the High Definition version of a movie or video. Selecting the DVD version will provide the lower quality or Standard Definition version of the same movie or video.
Check the covers or disk itself to determine if the movie or video is in DVD or BD format. That will tell you what you can expect for picture quality.
I hope this helps & good luck! Please rate my reply - thank you.
Mar 17, 2011 | LG Super Blu BH200 Blu-ray and HD-DVD...
Bought new sony bravio blue ray dvd player hooked to hdmi port changed inout to digital one then tried changing port and trying in digital 2. same symptom on both sound perfect but no picture of any kind....
There are three only three possibility's here, one there is a problem with the HDMI HOOK UP ON THE BACK OF THE TV, SECONDLY IT COULD BE THE DVD PLAYER IS NOT COMPATIBLE WITH THAT TV, AND LASTLY YOU MIGHT NEED TO HAVE THE TV SERVICED FOR SYSTEM ISSUES
Mar 06, 2011 | JVC HD-70G886 70" Rear Projection HDTV
Do I need a tuner or converter box for this type of TV?
Most projection tvs even if they say HD need a converter box. This is because the HD tv part is referring to playing hd video through the component inputs. This input is typically where you would connect a dvd player or blue ray player. Most projection tv's where made before the transfer of analog to digital tv.
Hope this helps
Jan 29, 2011 | Hitachi Televison & Video
I have picture but no sound when connected thru hdmi using a panasonic blue ray Dvd player. It is working fine with my 42 inches sharp lcd.
Be sure you are not trying to use 1080p/60 from your Blu-Ray player to your Toshiba. You should connect the player to the Sharp, then set the output to 1080i... then move it over to the Toshiba.
Mar 14, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Jun 02, 2009 | JVC HD-52G786 52" Rear Projection HDTV
How to connect blue ray to philips 46" hd tv with direct tv service
Connect using hdmi or component video from dvd player to tv.
Apr 24, 2009 | Televison & Video
Sharp BDHP20S Full HD Aquos Blu-Ray / DVD player DVD & Blue-ray light constantly flashing
Prob the mainboard, like a needle in a haystack trying to track a fault down on that board - Better to replace it.
Cheers
Jun 02, 2008 | Sharp Televison & Video
Dvd player, hd dvd movies
If this is just a regular DVD player, then no. You need an HD DVD player to play HD DVD discs. Now the HD DVD players should play regular DVD discs.
Feb 12, 2008 | LG DR787T DVD Recorder
Panasonic DMR-E85H DVD Recorder Logo
80 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
