Question about Frigidaire Dishwashers
Low Rinse-Aid Indicator Light is on - Frigidaire Dishwashers
5 Suggested Answers
SOURCE: put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
Posted on Apr 30, 2009
SOURCE: I have a Bosch dishwasher with a rinse indicator
Phone Bosch 08448 928 979 for a step by step solution. Program select at 12 o'clock. Press ON/OFF and Time Delay button together. Press time delay button, display should change from 1 to 0, indicating warning light is inactive.
Posted on Jul 14, 2010
Macmarkus
  • 2605 Answers
SOURCE: Pump is constantly running -
Hello, welcome to FixYa.
Based on your description it sounds like the emergency overfill switch has been actuated.
Here`s what to do and what to look for. ( unbeknownst to many this is built by B/S/H/...or better known in north america as BOSCH )
**Turn off the breaker/power at your homes service panel...safety first of course**
Remove the the bottom panel, referred to as a toe panel or kickplate, essentially the lower service panel.
When you remove the outer toe panel, (typically black in color, though sometimes white depending on the model, customization etc.) there will be another small "L" shaped panel which is non finished steel, I find removing that allows much easier access as well.
This panel can be somewhat more difficult as it secures the plastic channeling for the wires but if you observe closely you`ll see it does "snap" out of place...carefully.
Once the panel has been removed check for any obvious signs of water in the base ( the unit has a plastic overfill basin with a float which will actuate an emergency overfill cycle, hence the drain pump runs & runs )
If you don`t witness any water in this area, direct your attention to the left in this basin/bottom ( from the front to be sure ) and you should see a device which will resemble a "stir stick" you`d use for coffee etc. it will be a red in color stick.
With the aid of a wooden spoon, long screwdriver, or if you can manage to reach by hand, lift it up and down gently and listen for a "click".
If there is no sign of water and you can here the "click" when lifting up and down the float actuater ( red stick ) then turn the machine back on and give it a try before reassembling the toe panel so you can observe for any possible leaks.
Let me know what you find. This is the most likely cause of the symptom you are describing so we can move forward if this doesn`t resolve the issue.
Thanks for choosing FixYa.
Good luck.
macmarkus :)
Posted on Aug 21, 2010
  • 77 Answers
SOURCE: my dishwashers rinse aid compartment
That just means that your dispenser isn't sensing that the ring agent is full. You'll need to order and replace the dispenser to fix the issue.
Good luck
www.ApplianceRepairLesson.com
Posted on Mar 04, 2011
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol ABOVE the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the SANITIZE button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
HOW TO CHANGE FROM LOW RINSE TO HIGH RINSE
Fill up the rinse-aid resevoir. Or (depending on exactly what you are asking), turn the little indicator just inside the rinse-aid fill port to a higher number.
Feb 22, 2015 | Samsung Dishwashers
How do I change from low rinse to another rinse on my Samsung dmt610rhs dishwasher
Where to put rinse aid in cdw10 dishwasher
Rinse aid makes dishes sparkle more as it improves their drying. The rinse aid container is situated on the inside of the door. You should fill the rinse aid container when indicator lights up on the container and the rinse aid indicator light on the control panel flashes. You can use simple vinegar as a rinse aid (white is best but apple or malt is fine).
Adding rinse aid.
To open the dispenser, turn cap anticlockwise. Take care when you pour in the rinse aid to avoid it overflowing. You can regulate the amount of rinse aid used by the dishwasher, move the adjuster which you will find under lid. The amount of rinse aid needs to be increased if the dishes appear dull or you can see circular stains. The amount of rinse aid needs to be reduced if the dishes are sticky or see white streaks.
You can choose from six different positions. It is normally set to 4.
Jun 07, 2014 | Hotpoint 24 in. FDW60 Free-standing...
The "Rinse Aid" red light
The rinse aid light is just an indicator to let you know the rinse aid is low. You fill it in the container next to where you put the detergent. Just push the yellow button and the lid will pop up. rinse aid is more important on the newer miele dishwashers, as they dont have "active drying" like the older dishwashers did. They depend on the rinse aid to sheet the water off the dishes at the end of the cycle. They are designed this way to reduce energy consumption. If you choose not to use rinse aid, and you dont mind wet dishes at the end of the cycle, either disregard the red light, or fill the rinse aid dispenser with water to trick the machine into thinking it is full.
If you are not going to use the onboard water softener, you can turn it off. Refer to your owners manual, or call miele tech support at 800 843 7231 and they can walk you through the programming to disable the water softener. these are not fault lights, they are simply reminders that you need to fill the containers.
Jul 20, 2011 | Miele Dishwashers
I have a Bosch dishwasher with a rinse indicator light. When the light is on it's supposed to be indicating that the rinse aid is emptybut my rinse aid container is not empty even though the light is on....
Jun 25, 2010 | Dishwashers
Where do I put salt into a G665 model
Salt and rinse aid are low if the indicator light is on.
Salt is placed in a compartment in the bottom of the inside of the dishwasher. It has a round approx 10cm diameter screw cap.
Rinse aid goes in under a flap in the inside of the door near the powder dispenser
Dec 02, 2009 | Miele 24 in. G665 Built-in Dishwasher
Miele Novotronic G842SC Plus
Add the requested rinse aid.. The light is on telling you it's low/empty.
Oct 20, 2008 | Miele 23 in. Novotronic G841 Built-In...
Dishwashers Logo
502 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
