Question about Miele Washing Machines
Check inlet light stays on - Miele Washing Machines
  • 487 Answers
Take of the water hoses and check the inlet filter. Most likely is plugged
Posted on Jun 15, 2008
Hot water inlet stays on water runs on floor
sounds like a bad water inlet valve, the selenoid may have gone bad. try reversing the hoses and see what happens, if the cold water stays on, ITS BADDDDDDDDD u can always check with a multimeter to confirm.
Sep 26, 2014 | Washing Machines
I have a miele w864 washing machine that will not fill with water
Does the light "Check Inlet" stay on? If it does, it is likely the water inlet valve solenoids that are inoperative. How old is the washing machine?
Aug 30, 2014 | Miele Washing Machines
Fuel fill inlet alarm
check the filler door to se if it closes all the way..some snap shut..
Dec 20, 2013 | 2001 Ford Escape
Engine check light stays on, replaced battery , didn't slove problem meter shows alternator putting out 15 volts
nothing wrong their then ,look elsewhere like a vacumn pipe perished on the inlet manifold
Dec 19, 2010 | Ford Explorer Cars & Trucks
I have a 2002 Toyota Land Cruiser. The check engine light has suddenly come on. Any idea why? it has 96K miles. And has been regularly put through the manufacturers recommended maint schedule at the...
I have owned many Toyota's, they all had the check engine light come on and stay on, when they went off, I worried. I never had it checked to see what it was, but it could be a number of things. Oxygen sensor, idle air control, inlet air temp, mass air flow, variable inlet system, electronic dist, etc, etc, etc, get it to a parts store with a scanner and see what comes up. Check it out.
May 15, 2010 | 2002 Toyota Land Cruiser
Will not load water, light stays on 6 and beeps
Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve ports. Make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. Hope this helped and best wishes.
Sep 01, 2009 | Washing Machines
I have a br 420c magnum blower and it will not stay running.... it acts like it is getting too much gas. i pulled muffler, spark arrester screen, i adjusted the idle, i adjusted the h and l screws...
H and L screws should be between 1.5 and 2 complete turns counter clockwise from where they lightly bottom out. if still no good, check diaphragm in carburetor on inlet needle side. it needs to be pliable and NOT laying on the inlet needle lever.
Jun 30, 2009 | Garden
Mini load, rinse hold and on/off lights flashing
Check the relay and the control board. Something is telling the inlet valves to stay open and allow water. If you just bought and replaced the inlet valve that would be your next stop
Feb 20, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Put detergent in a dishlex dishwasher now the pump stays on a& the dishwasher does not work, just displays a flashing red eco light
Hello jack SparWelcome,
You said, Put detergent in a dishlex dishwasher now the pump stays on a& the dishwasher does not work, just displays a flashing red eco light
What is the BRAND and MODEL Number and year of your dishwasher. Model can be found on sticker inside.
Did you turn off the power at the breaker for 5 minutes to see if it resets the system?
If this is not the case, Please explain!
What do you mean the pump stays on?????????????????????????
If it is not getting water and not working then these may be the problem
Water source turned off
Check to ensure the water source is turned on and water is getting to the water inlet valve.
Float switch
The float switch allows water to enter into the machine to a point where the float will rise up off of the switch and disconnect power to the water inlet valve. If the switch is defective or the float is stuck in the up position, the water will not enter into the machine
Defective water inlet valve
If there is 110v across the two wires on the water inlet valve when the machine is set to fill, the valve should open and the water should enter into the machine. If the water does not enter, the valve is defective.
Defective Timer
The timer is a series of switches that controls all machine functions. If one of the contacts in the timer is defective, the machine will lose that function. knowledge of the the use of a vol/ohmmeter is essential to testing the timer as well as the ability to read the timer sequence chart that is supplied with the machine. In most cases this requires a professional technician.
Huuum
Oct 22, 2008 | Dishwashers
Fuel Problems
check for air inlet at carburettor leaks.
Jul 13, 2008 | 1989 Ford F 150
Washing Machines Logo
51 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
