Question about Dometic RM2652 Refrigerator
The freezer door on my Dometic fridge will not saty closed,the springs are not broken,how do i rejust them?Its a Dometic 2510 model
  • 19 Answers
SOURCE: Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Posted on Nov 18, 2008
  • 9 Answers
SOURCE: My dometic fridge doesn't cool some times but the freezer works
I don't know what type of fridge you have side by side or top mount or bottom mount but what every it is sounds like the air ducts are blocked with ice or the air damper is not working.
Posted on Apr 02, 2009
konzzz
  • 255 Answers
SOURCE: Bottom not cooling
the blower is broken or frozen.you need to defrost and clean it.or the air passages are clog.
Posted on May 08, 2009
  • 34 Answers
SOURCE: My freezer door will not stay shut. Dometic Model RM2453.
yes you can.remove two screws from under one side pull it away slightly and it will come away.you will then have one housing on both sides left in the fridge wall,they will have a little pressure on them from the springs. just prise them away. you will need help to replace them, as you need pressure against the spring to keep the door closed. you can buy springs and housings seperately from camec there is left and right housings.give me a call if you need to ..
Posted on Jan 03, 2010
motor1258
  • 6674 Answers
SOURCE: my dometic fridge will not turn on
Check to see if you have a switch for storage, on, off etc. usually between doors, or near top right corner of fridge compartment. It may be in wrong position.
Posted on Jun 03, 2010
I have a dometic fridge freezer model number RM2652 where can I get it repaired on the recall. I live in the Uk
go google and type in --authorized repair agents for dometic fridge /freezer equipment---
look for one close to where you are
contact the "contact us " area on the manufacturers web site
Sep 17, 2016 | Dometic Refrigerators
We have a Dometic Refrigerator Model RML8555. The door latch (refrigerator side) has broken for the 2nd time. It is just out of the 2 year warranty. Dometic sent us the new part and replaced it. When...
do you mean the handle?
my fridge does the same thing
its like vacuumed closed if you try to openit right after closing
knowing this Im careful on trying to reopen it
seems to be a normal
Oct 09, 2013 | Dometic Refrigerators
I have a dometic rv fridge, the freezer works not the fridge
you have to send the brand name and model number so i can help you.all that happens is the evapcoil in the freezer gets cold,the evap fan motor blows cold air from the freezer into the fridge side,depending on your model you could have a bad damper,this is a door that is in the fridge section,it opens and closes letting the air come in,try this,open the freezer door,if you don't hear the fan blowing you could have a bad fan motor,also touch your hand on the back inside wall of the freezer,if you have frost or like ice on the back wall you have a defrost problem,ice is biulding up on the coil and the fan can't blow the air over to the other side..if you need more help,do these tests and send the model number off of the machine and brand name,side by side or freezer on bottom,open the fridge door,look up on right hand side wall near ceiling or on ceiling,freezer on top look on left side in fridge section.
Jul 12, 2012 | Dometic Refrigerators
Dometic RM2612..Replaced Thermister, was cooling excellantly, now freezer works well but no cold in bottom of frigg? What may cause this?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jul 12, 2010 | Dometic Refrigerators
My dometic fridge will not turn on
May 14, 2010 | Dometic RM2852 Refrigerator
We have a Dometic 2310 - freezer works well, fridge seems inconsistent. Top of fridge gets very warm. Is it helpful to add a cooling fan?
Sep 24, 2009 | Dometic RM2652 Refrigerator
Bottom not cooling
May 08, 2009 | Dometic RM2620 Refrigerator
My freezer door will not stay shut. Dometic Model RM2453. This is the model with the freezer compartment inside the unit. Springs in freezer door seem weak or broken.Can I safely remove the plastic spring...
Apr 22, 2009 | Dometic RM2452 Refrigerator
Dometic RM2652 Refrigerator Logo
Top Dometic Refrigerators Experts
Sheldon Dedek
Lollo Pop
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
