Question about Panasonic DMRES15 DVD Recorder
Dont work with remote control, shows SET I, I also used the rcontrol to turn on a Panasonic TV
  • 144 Answers
This problem is caused by having more than 1 panasonic product using remotes, the remote may need to be reset say to set 2. I had this problem. It will tell you in the user trouble shoot guide to press and hold ok button down with the number button say 2 for several seconds, that should put the remote to to the correct setting.
Hope this helps
pete
Posted on Nov 06, 2010
How to setup phillips universal remote to a panasonic tv
Philips Universal Remote control Instructions
  1. Turn on the device (TV, DVR, etc.) you wish to operate.
  2. Press and hold the SETUP button until the red light indicator remains lit, then release the SETUP button.
  3. Press and release the desired mode button (TV, DVR, etc.).
More items...
Philips Universal Remote control codes for TV, VCR, Set-top Box ...
www.directutor.com/.../philips-sru210327-universal-remote-control-codes-tv-vcr-set-top... How to setup phillips universal remote to panasonic tv Google Search
Nov 29, 2016 | Panasonic Televison & Video
What code do I use to set up my sky hd remote to control my panasonic tx-p42x10b tv
With you sky remote follow the steps below:
TV
RED + SELECT ( flashes twice )
TV
0051
now try the volume button. If this works then press SELECT to save. If not press TV and then volume again. Repeat this step until the volume works then dont forget to press the SELECT button to store the code.
Job Done. Please leave a thumbs
Cheers
Little Dish Fitter
Oct 06, 2009 | Panasonic Televison & Video
Remote control code
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Feb 15, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
Pairing Sky+ Remote with Panasonic Viera remote
3. Press tv again
Dec 29, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
Jan 03, 2008 | Televison & Video
DTV remote code
KZXten,
Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
Here's a link to the remotes Comcast is providing in my area.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Dec 23, 2007 | Panasonic PVQ-2510 25 in. Combo
Remote code for PV-M1349
The secret is that the VCR code turns the set on/off and the TV code controlls the volume...try this:
Program the Verizon remote AUX button using the panasonic VCR codes until it turns the set on/off, program the remote for TV using the panasonic TV codes until it controls volume, then program the STB button to control all 3... STB, TV, and AUX. If you are missing any VCR or TV funtions try another respective panasonic code until all functions are available.
Panasonic VCR codes are 1089, 0062, 0189, 0252, 0643, 1062.
Panasonic TV codes are 0277, 0078, 0677, 1437.
To figure this out, I had to use the "what if none of the codes worked" section and figured I'd try the VCR codes since the TV codes would not turn it on/off.
Good Luck!
Nov 25, 2007 | Panasonic PV-M1349 Combo
Telefunken TV, Model TTV-215(C)
Hi all you Telefunken TTV-215 owners. My tv did this to. Panasonic in Bloemfontein helped me by phoning Telefunken and getting back to me within 10 minutes. All you have to do is turn your tv on and then press and hold the F button on the remote and while doing this press and hold the MUTE button also. If this doesn't work try olding down the display button on your remote for +- 5 seconds. If still no results try phoning your nearest Panasonic dealer.
Sep 01, 2007 | Televison & Video
Panasonic DMRES15 DVD Recorder Logo
83 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
