Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
My drain cancel button works but nothing else, do I need a new control panel or a fuse kit?
  • 3 more comments
  • Rick Seiberling Nov 06, 2010
    I pressed the air button but it did not change anything. Do I need the control panel -- the one you see in the pic above on the front of the dishwasher or the circuit board (electronic control board/panel) that goes inside?
    AIR DRY button made no difference. When you say "control" do you mean the white control panel with the buttons or the electroic control board that is inside behind the panel? They are two different items.
    I am unable to click on the "continue" button, it takes me out to a site for school loans????
    I can't get a response from Daniel due to pops ups so I'll ask again...
    Whirlpool Gold, quiet partner IV. Model GU1500XTKQ0 Daniel say yes I need a new "control" but do I need the control panel with the buttons that you see on the front of the dishwasher or do I need the control board/electronic inside behind the panel?
  • Rick Seiberling Nov 08, 2010
    I know about item 11 but how do I tell if it's item 1 or 11? Control panel vs control circuit board?
  • Whirlpool Master
  • 3,247 Answers
In case you have not already done so then refer to this site for the details of the assembly. You are looking at item 11 , I think.
Please rate my solution if it is helpful otherwise post a comment.
Posted on Nov 07, 2010
  • Sam Nov 08, 2010
    I would say the item 11. But first just remove the connectors and put back on. Might be just a corrosion.
  • 4,323 Answers
Hi
First try to reset the control by pressing the AIR DRY button for 15-20 seconds. After doing this if the issue remains then you'll have to replace the control. Please tell me if you need more help.
Daniel
Posted on Nov 06, 2010
My maytag dishwasher model MDB7749SAM stopped working about three days ago. The start/resume button flashes continuously and won't turn off. I flipped the breaker switch but nothing reset. The cancel...
Most likely moisture has affected the switches in the panel or the controller is faulty.
Refer assembly shown in the link below. Open the panel and locate the ribbon cable. Carefully take it out and with a hair dryer lightly dry up the parts. Put everything back and turn power back on. If no difference still then you may have to replace the control board.
MAYTAG Undercounter Dishwasher Control panel and latch Parts Model...
Aug 01, 2014 | Dishwashers
Du1145 will not work
frist turn power off to diskwasher then back on see if the button start working if none the button will not work you made need replace the touch pad,some model come with the control panel all in one some are separately.
Dec 23, 2017 | Whirlpool Dishwashers
I have a whirlpool gold quiet partner III. The cancel drain button works but nothing else. If you press any of the button for a period of time the normal button flashes; nothing happens though. Any...
Try to reset the dishwasher by using this sequence of keys within 6-8 secs.
HiTemp/ heat Dry/ Hi Temp/ heat Dry/ Hi Temp / Heat dry.
If it works all lights should turn on. Press Cancel to exit.
I am assuming you have already tried to turn the mains power off and back on.
If still no difference, then the controller or the panel has packed up.
You can locate the parts from this site.
Mar 21, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Kitchenaid kud101tj "cancel drain" light and "Rinse Only" lights are falhing and DW won't start???
Don't know if this will help, but when I had problems with my control panel (lights blinked and nothing worked) I fixed it by disconnecting the power completly from the dishwasher at the fuse box. Leave it off 10 or 15 minutes and then repower. That reset mine and it worked again...has happened several times and each time I could fix it by cutting the power. If that doesn't work, you may need a new control panel.
Sep 11, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Kenmore Elite Dishwasher(665.15979990) wont drain
If the control panel is still lighting up I think it the thermal fuse has blown if you can take out the control panel and in that you will find the fuse you can test this with ohm test and here is a pic of what the fuse looks like and if you do replace this make sure you replace the new wires that come with the new fuse good luck hope this helps
Nov 21, 2009 | Dishwashers
Dishwasher control panel not working
Unless you can reset those electronics to factory defaults you may need a new panel controller. Contact manufacturer first for a possible hidden code to do this. They can also help you with parts if needed. Sears Online In Store Shopping Appliances Clothing More
Sep 05, 2017 | Kenmore 15073 Stainless Steel Built-in...
Dishwasher will not start..we've had it about 3 to 4 years
Some of these units have a thermal fuse in line with and mounted on the control card. This will need to be checked. Also check the door switches. Some models will aloow power to the control card but to nothing else.
Oct 12, 2007 | Kenmore 16872 Built-in Dishwasher
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
