Question about Keurig B50 Coffee Maker
My Keurig is making less quanity of coffer per cup recently than it always has in the past
SOURCE: my Keurig b60 is spitting water into reservoir instead of kcup
I had a similar problem except there was no water going into the K-cup. I fooled around with the machine for awhile but I had no luck. Figuring I had nothing to lose, I broke out a can of air that one uses to clean computer keyboards. I sprayed the air into the nozzle that puts water back into the reservoir and air came out of the water intake hole but not the needle that puts water into the K-cup. This meant that there was a block between the the needle and the reservoir. I plugged the water intake hole with a towel and my fingers then sprayed the air into the same nozzle. All of a sudden, a large blast of water came out of the needle. The machine worked after this. Just be careful not to put your hand in front of the needle because the water might be hot. Also, unplug your machine before doing any tinkering. Hope this might help some people.
Posted on Feb 28, 2011
SOURCE: How do you turn on a Keurig to get a cup of coffee
I know on mine I have to open and close the chamber where I put my coffee. It then blinks ready and I press the size cup I want to brew. Hope this helps! :) And sometimes if there isn't enough water in the reservoir it won't brew so try and putting more than just a cup's worth of water in it :)
Posted on Sep 22, 2009
SOURCE: keurig turns off after making only one cup, when
I just solved this problem with my Keurig Plantnum. It seems that the valve that lets the water in is sensitive to clogs or sticking. Or perhaps like me, you have very hard water and calcium is starting to build up. Anyway, what worked for me was filling the resevoire all the way and turning the unit on. Then while the pump was buzzing I lightly jiggled the reseviore and all of the sudden the water level started to go down.
Posted on Jan 25, 2010
  • 60 Answers
SOURCE: The Keurig is heating up the water, yet is does
Descale, Clean out the needles with an unfolded paper clip, Take out the K cup holder and clean it out
Posted on Mar 23, 2010
espressonist
  • 1711 Answers
SOURCE: keurig does not brew the large cup of coffee, only
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Posted on Aug 15, 2010
My coffee maker will not fill a full cup . I have to run it twice per cup.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 02, 2011 | Keurig B60 Coffee Maker
Recently the amount of coffee produced is less....
heatman101
Aug 30, 2011 | Keurig B60 Coffee Maker
Doesnt always make a full cup of coffee sometimes it doesn't even make a cup. Machine i s less than a year old.
heatman101
Aug 18, 2011 | Microwave Ovens
Decreased brewing volume per cup, sluggish start to brewing
You should descale to see if that helps but if not you should contact Keurig 866-901-2739 or Green Mountain Coffee and 866-639-2326 to see if they have any suggestions or if this may be a known issue with that model brewer
Feb 11, 2010 | Keurig B60 Coffee Maker
How do you turn on a Keurig to get a cup of coffee - I hit the button and it says green and ready but nothing is coming out - I put the cup's worth of water in the side container - what do I do to get it...
Sep 12, 2009 | Keurig B50 Coffee Maker
Keurig B50 Coffee Maker Logo
167 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
