Question about Cuisinart CWM-100 Microwave Oven
I have a Cuisinart CMW-100 1450 watt microwave The main fuse 20 amp is blown. Replaced it and it blew again.What's next
5 Suggested Answers
  • 52 Answers
SOURCE: Cuisinart Microwave won't heat food
open the casing and replace the blown fuse.there are several so check them all. probably why the machine was in the auction
Posted on Feb 21, 2009
SOURCE: Cuisinart CMW-100 , wont heat or turn the table? all else o.k.
We changed the 20amp fuse and that was not the problem so we returned it to Macy's. If anyone knows of a reliable brand of microwave today please let us know. All the reviews on microwave ovens recently are bad.
Posted on Jul 31, 2009
SOURCE: Our cuisinart cmw-100 still has the power sources
Bad door switch, usually the top one. The switch costs < $2.00.
Posted on Sep 14, 2010
  • 8909 Answers
SOURCE: cuisinart microwave cmw-100 opening of
Check the door interlock switches.
Posted on Feb 12, 2011
I have a GE JKP62G microwave-oven combo. The oven works fine. The microwave blew the 15 amp fuse. When I replaced the fuse, per your earlier directions, and tried to use the microwave, the new fuse blew....
Cause 1
If too much current passes through the microwave circuitry, the line fuse will blow. If the line fuse blows, the microwave won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. If you don’t resolve the underlying issue, the new fuse will blow too
Cause 2
Main Control Board
The main control board might be defective. However, this is rarely the case. Control boards are often misdiagnosed—check all of the more commonly defective parts. If you have determined that all of the other components are working properly,replace the main control board.
Cause 3
Thermal Fuse
The thermal fuse cuts off power to the microwave if the microwave overheats. To determine if the thermal fuse has blown, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. The thermal fuse cannot be reset—if the fuse is blown, it must be replaced.
Since its a electrical isue cal a liscenced professiona to resolve the issue . Your microwave oven isnt at fault . I belive the supplay to it has issue and would have blown anyway.
May 29, 2018 | GE Microwave Ovens
Had poweroutage now oven dont work hoping its a blown fuse, and where would I locate the fuse fuse
You have blown a fuse. Check inside the oven chamber and look for missing powder paint or signs of arcing, if so dispose of the microwave. If the inside is good remove all the screws and remove the cover. Replace the fuse. If the magnetron was making louder noises prior then replace the magnetron. Since the fuse went the giant capacitor is likely bad. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Nov 21, 2013 | Cuisinart CMW-200 Convection/Microwave...
After plugging it in, the microwave made the normal noise and then the light went out and nothing works. No power to the unit. Are there any fuses that could be blown? Or is it toast? Thanks, Steve
How microwaves are designed, this problem would be a door switch issue and a blown fuse. If this unit is new and under warranty returning as a DOA. If not find a friend to open the unit and look for a bad switch alone with an open fuse at main power supply.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 02, 2013 | Cuisinart CMW-100 Microwave Oven
Microwave blows fuse to kitchen outlet when it is plugged in. microwave still works.
What else in on the circuit? Your oven should be on its own. If you live where I live, this should be a 20 amp 120 Volt AC branch wired directly from your power panel.
If this is not the case, have a licensed electrician install a proper circuit for you.
Mar 18, 2013 | Cuisinart CMW-100 Microwave Oven
Replaced 20amp fuse that was blown. new fuse did not blow, but oven is still dead.
see this causes and fix it. God bless you
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work
Sep 22, 2012 | Cuisinart CMW-100 Microwave Oven
I have replaced the fuse in the # cmw 100 but it blows as soon as i plug it in
When the fuse goes on a microwave, if you can't find any burned wires touching the frame, it is usually a bad capacitor... sometimes the magnetron needs replacing too.
Mar 22, 2012 | Cuisinart CWM-100 Microwave Oven
Viking Microwave Model VMOC205SS little over 4
9 amps is approx. correct. Does magnatron make an odd sound when running? If not, you will need to discharge cap then clean terminals with alcahol. Replace diode as well. Should run correctly.If blows again, replace magnatron. Suggest you put a 12 amp fast blow fuse in circuit and nor a 20 fuse.If you dont have a grill or an oven, use a 10 amp fuse.
Sep 17, 2009 | Viking VMOC205SS Microwave Oven
Jul 30, 2009 | Cuisinart CMW-100 Microwave Oven
Cuisinart CWM-100 Microwave Oven Logo
Top Cuisinart Microwave Ovens Experts
William Miller
William Miller
Lawrence Oravetz
NOEL
NOEL
Are you a Cuisinart Microwave Oven Expert? Answer questions, earn points and help others
