Question about Toshiba Computers & Internet
When I turn on my laptop it just shows the LOGO. Then the system stops working and freezes up. I tried system restore before but it didn't work.
    Sergeant:
    Champion:
  • 256 Answers
Try restoring to older date...
Posted on Nov 06, 2010
My Toshiba L305-S5907 wont unfreeze
Do a System Restore again but pick a restore point (date) before the troubles began.
Oct 11, 2012 | Toshiba Satellite L305-S5907 Laptop
So i go to turn my toshiba laptop on and it loads until it gets to the please wait screen then it just stops and freezes. Please help me.
Hi, I see that the laptop is not working anymore. You can try removing the battery and also removing it from the adapter. then pressing the the power button for at least 10 secs. Then try to log on again. If you cannot still log on to the computer. You can try to go to safe mode with networking. When you press the power button, you need to tap the F8 key immediately at least 5-10 time until you Advance Boot Options. You can now choose safemode with networking. If you are able to log on. IF you are able to log on, click on start > then go to program files > then go to accessories > then choose System Restore. On system restore, choose the date when the computer is working and it will reload the computer back. you should be able to log on again normally If still you cannot log on safemode. you can now try the option Last known good configuration. it will load the previous settings when the computer logged on. If that still didn't work. You might need to reload the OS again. and you need to get the Operating system.
Thank you for using Fixya. your recommendation is highly appreciated for the free support.
Aug 22, 2011 | Computers & Internet
I turn on my laptop, and the computer gets to the screen where it says "starting windows" and it does not go any further. It freezes at that point.
1. Disconnect all external devices (printers, USB hubs, USB drives, etc...) and then boot up. If this corrects the issue then add the devices back one at a time until you discover the piece of hardware causing the issue. Then get any updated drivers\software for the device.
2. Use the"Last known good configuration" from the Windows Advanced Options menu. If this option resolves the issue then look for any updates or software installs that may have caused the problem.
3. Boot to Safe Mode from the Windows Advanced Options menu.If you can get into safe mode then the issue could be driver or software related. From within Safe Mode run a System Restore.
4. Perform a Clean Boot
"Please Post back to let us know if we helped.Kindly rate this article"
Mar 17, 2011 | Toshiba Computers & Internet
My dell inspiron freezes on the welcome page
While there are a number of possible solutions which may or may not work depending on several factors, the easiest to try is to boot to safe mode and run a system restore.
To boot to safe mode:
When you start the system, as soon as the blue dell logo goes away, tap the f8 button. This should get you to a menu from which you can choose "safe mode". It will show a bunch of writing on the screen and should eventually bring you to the login page, login as administrator.
Run system restore:
This varies depending on which version of windows you are running. In XP it is start>all programs>accessories>system tools>system restore.
Other things you can try:
Login as a different user.
Use start>run>msconfig from safe mode to disable startup items which may be causing the problem.
Consider removing recently installed software which may have caused the problem.
Scan for viruses, malware, spyware, ect.
Run diagnostics on the system by pressing f12 on the dell logo and chosing diagnostics.
The worst case scenario to fix a problem like this is reinstalling windows.
Feb 27, 2011 | Dell Inspiron 1525 Notebook
Have a Dell Studio. When I power up the Dell Logo appears with loading bar below that. The bar stops about 2/3 of the way, it freezes up and starts beeping. Nothing I've tried works.
this is often related to a possible motherboard problem. Try these steps: turn it off, remove the battery, and AC adapter, then press and hold the power button for about 5 to 10 seconds. Once done, reconnect at least the adapter , turn on the laptop and as soon as the Dell logo shows up, tap F2 a few times to enter System Setup (BIOS screen). From there, go to the Maintenance category, and select Load Defaults, press Enter. Press ESC, then select Save/Exit, restart the computer and see how it goes.
Sep 27, 2010 | Dell Studio 15 Laptop
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
When I turn on my built in webcam, it works for a
probably this might cause by a conflicting windows update. i would suggest try to do a system restore first, restore it to the time when the webcam was working fine. after system restore if it works then i want you to disable the windows update from control panel. if this fails then proceed to uninstalling and resintalling the webcam driver.
Oct 28, 2009 | Dell XPS m1530 laptop. TUXEDO BLACK. 15.4"...
My compaq presario cq40 laptop's logon screen didn't open. and key board, touch pad didn,t work. pls tell me a solution
my screen laptop not functional as well..seem like the power supply not connect to the screen..it because there are blink-blink light signal at the keyboard
Sep 21, 2009 | Computers & Internet
Right basically when i press the on button it turns on but gets to the hp logo screen and stops mouse still working but otherwise unresponsive help!
try going to safe mode by pressing f8 while it is loading.
once your on safe mode try system restore to restore the computer to a state when it was working
system restore is on:
start >programs> accessories>system tools>system restore.
Sep 11, 2008 | HP Computers & Internet
Key board stops responding when windows loads
your mouse freezes; you should only use system restore as a last resort
any virus/spyware you had in the past will come back
turn the computer off(you may have to shut power off pressing on power button)
when you see ibm logo, tap F8 key repeatedly until your hear beeps or a high pitched noise
use option safe mode; use 'most recent config where my settings worked' option in safe mode(use up and down arrow keys to highlght, then press enter)
If that does not work, try another(earlier) restore pt w system restore or install mouse drivers on a cd on another laptop, then
place in cd rom and try to install it on the problem laptop
if this is no good, you should really reinstall windows, back up impt docs, etc.(delete old partition)
that model has a built in restore function by pressing F11 on startup, it will restore your piece to factory condition(along w spyware that comes along w the builtin ibm utility)
I had the same exact laptop, the fan got noisy, so I replaced it w another that was from a good t30, guess what:
"fan error"
Ibm laptops are too problematic to work on
thats why I use dell
if you need more help, msg me or post on here
Feb 25, 2008 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
