Question about Microsoft Office 2003 Pro (269-07387) for PC
My microsoft office 2003 requested for a file named pro11.msi. now i want to download it.
  • 475 Answers
You cant download PRO11.MSI. PRO11.MSI is a file that come with your Office 2003 installer. So try to look it on your CD or on your harddrive.
for more information regarding how to download pro11.msi refer the below website
http://office.microsoft.com/en-us/help/locate-missing-msi-files-HA001118572.aspx
Posted on Nov 06, 2010
I need pro11.msi file, pls provide free download site...
Contact Microsoft. They can replace your install disk or provide you with a download link.
Sep 17, 2011 | Microsoft Office 2003 Pro (269-07387) for...
I need a pro11.msi file
Try having a look at this it might help
http://office.microsoft.com/en-ca/powerpoint-help/locate-missing-msi-files-HA001118572.aspx?redir=0 I also found this item that might help
Have you tried repairing your installation?
1. Click Start, and then click Control Panel.
2. Click Add or Remove Programs.
3. Click the Office program that you want to repair, and then click Change.
4. In the Maintenance Mode Options dialog box, click Reinstall or Repair, and then click Next.
5. In the Reinstall or Repair Office dialog box, click Detect and Repair errors in my Office
installation, and then click Install.
6. When the repair process is finished, run the update again.
Most likely you will need to have your Office 2003 CD handy.
MS Office Download Page
http://office.microsoft.com/en-au/of...e/default.aspx
Jun 16, 2011 | Microsoft Office 2003 Pro (269-07387) for...
Hello, I am trying to find the file PRO11.MSI in my computer. What do i do to fix the problem i am uable to use excel.
The PRO11.MSI File will be on the CD that you used to install Office.
Hope that helps, pls rate the solution
Nov 11, 2010 | Microsoft Office 2003 Pro (269-07387) for...
My word is asking pro11.msi file and i cant uninstall
this is a Office 2003 Professional setupfile.
You would find this when you insert your office CD or browse the location from where u installed MS Office onto your machine.
Sep 19, 2009 | Microsoft Office Outlook 2003 for PC
My computer is set on automatic updates and it is unable to find file PRO11.MSI to update pls advise
Hi there.
Its looking for Office 11 to update and you probably have not got the installer (.msi) file on the PC.
All you have to do is skip that particular update.
Good luck and thanks for using FixYa!!
Apr 09, 2009 | Macmillan Using Microsoft Windows XP...
Does anyone have clue about the " Pro.Msi" File
An .msi file is a database of all the files, settings, and configuration information for the associated application. When you install Office on your computer, the .msi file is saved in a hidden folder. Without this file, Windows Installer cannot update your configuration, install optional features, or apply software updates. Office cannot be installed, repaired, or updated if the .msi file is not found.
Why is the .msi file missing? The most likely reason for Windows Installer to require the installation CD is because the saved version of the .msi file for Office has been inadvertently or deliberately deleted from your computer. It is also possible that the file is damaged or corrupted.
Occasionally, changing the drive letters associated with partitions on your hard disk can cause this problem to occur — such as changing drive C: to a different letter or moving the hard disk drive from one computer to another. Other possible causes are a damaged or corrupted hard disk or registry file.
What to do when prompted for a missing .msi file If you are prompted for the location of a missing .msi file, you must provide the original installation CD used to install Office on your computer.
  1. Make sure that you have inserted your Office installation CD into the CD drive of your computer. If you installed Office from a network, browse to the network location from which you installed Office.
  2. Click Retry.
In most cases, these steps should resolve the problem and Office can complete the installation and configuration of the needed component.
default.aspx?assetid=za790050011033I don't have the installation CD
Without the installation CD — or for computers purchased from companies such as Dell, HP, Compaq, or Gateway — you need to provide a repair CD to reset the installation created for your computer by the manufacturer. For information on how to apply the repair or installation CDs, you might need to contact the support representatives of your computer supplier.
In many cases, the files that you need are compressed on the repair CD and must be run by using a special program provided by the computer manufacturer. In some cases, the computer manufacturers might have customized the .msi file or changed the file name.
In situations where you cannot obtain the installation CD, your options are the following:
  • Continue with the existing installation of Office without updating. This is not recommended. Your documents and computer might become compromised from security threats.
  • Remove the installation and reinstall Office by using another installation CD. Removing the previous installation may not be possible in severely damaged systems where the registry is corrupt.
  • Run a repair CD provided by the computer manufacturer. For information on how to apply the repair CD, you might have to contact the computer manufacturer or consult the documentation provided with the computer.
If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. A table that correlates .msi files to Office versions is provided later in this article.
Office 2003, Office XP, and Office 2000 provide the Detect and Repair command. You can find the Detect and Repair command on the Help menu of almost all Office programs. Using this command corrects identifiable problems such as missing files, corrupt files, registry omissions, or damaged registry entries. It replaces the .msi file if it was deleted, damaged, or is the wrong version. Using the Detect and Repair command usually requires you to provide the installation CD for the version of Office currently installed on your computer.
default.aspx?assetid=za011526611033 How to prevent similar problems in the future To help avoid this problem in the future, use the following guidelines:
  • Do not delete hidden folders or files from any drives on your computer.
  • Do not move drives or change their disk identifier (for example, C: to D:).
  • Install all needed applications as Run from My Computer instead of using Install on Demand (available from custom installation within Setup).
  • Occasionally run the Windows Disk Defragment program to repair cross-linked files, recover lost clusters, and remap bad sectors on your hard disk. Any data present in a bad portion of the hard disk is usually lost and commonly associated with physical damage to the disk. This is most likely the result of high-vibration environments, such as the computer being struck, dropped, or kicked.
If you have Microsoft Windows XP as your operating system, consider using the System Restore option to restore your system to a previous configuration. Consult the Help and Support option of Windows XP for more information on System Restore.
Office 2003 .msi files If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. The following tables tell which .msi files go with which Office versions.
File name Description accessed.msi Microsoft Office Access 2003 Developer Extensions mui.msi Microsoft Office 2003 Multilingual User Interface Pack (one for each language) muiwiz.msi Microsoft Office 2003 Multilingual User Interface Pack owc11.msi Microsoft Office 2003 Web Components prjmuicwz.msi Microsoft Office Project 2003 Multilingual User Interface Pack Wizard prjstde.msi Microsoft Office Project Standard 2003 pro11.msi Microsoft Office Professional Edition 2003 projproe.msi Microsoft Office Project Professional 2003 ptk.msi Microsoft Office 2003 Proofing Tools sbe11.msi Microsoft Office Small Business Edition 2003 vismuiwz.msi Microsoft Office Visio 2003 Multilingual User Interface Pack Wizard visprolmxi.msi Microsoft Office Visio Professional 2003 Office XP .msi files File name Description dao.msi Microsoft Data Access Object (DAO) lpk.msi Microsoft Office XP User Interface Pack (one for each language) lpkwiz.msi Microsoft Office XP User Interface Pack Wizard ork.msi Microsoft Office XP Resource Kit pro.msi Microsoft Office XP Professional Edition proplus.msi Microsoft Office XP Professional with FrontPage Edition ptk.msi Microsoft Office XP Proofing Tool Kit pub.msi Microsoft Publisher 2002 sbe.msi Microsoft Office XP Small Business Edition std.msi Microsoft Office XP Standard stdedut.msi Microsoft Office XP Standard for Students and Teachers owc10.msi Microsoft Office XP Web Components Office 2000 .msi files File name Description data1.msi Microsoft Office 2000 Premium Edition (all Office products) data1.msi Microsoft Office 2000 Professional Edition (similar to Premium but does not include Microsoft PhotoDraw) data1.msi Microsoft Office 2000 Small Business Edition (includes Microsoft Word, Microsoft Excel, and Microsoft Outlook) data1.msi Microsoft Office 2000 Standard Edition (includes Microsoft PowerPoint, Word, Excel, and Outlook) data2.msi Microsoft Office 2000 Disc 2 (includes Small Business Tools and Publisher) msowc.msi Microsoft Office 2000 Web Components orkdata.msi Microsoft Office 2000 Resource Kit proofkit.msi Microsoft Office 2000 Proofing Toolkit Note In Office 2000, the file name data1.msi does not clearly identify which version of Office you have. In this case, you need to inventory the installation of Office programs on your computer by examining your Start menu entries or click Add or Remove Programs in Control Panel and scan through the list of entries to determine the version of Office that is installed.
Zulfikat Ali
Jan 24, 2009 | Microsoft Office 2003 Pro (269-07387) for...
Can not open email attachment
The MSI file it is asking for is an additional feature from your Microsoft Office software disk.
You will have to find a copy of that version of office to be able to install it.
What is the extension on the email attachment file? You might be able to use a different program to open it.
Jul 09, 2008 | Averatec 3200 Notebook
PROBLEM OF PRO11.MSI
Go to start menu, run, then type 'excel' and hit enter, the installation menu will start but you can just cancel it. To me, the installation will start again and again but I cancel it as Book 1 excel already opens. Then you can double-click any excel file that you want and open it. It worked for me! :)
Apr 08, 2008 | Microsoft Office 2003 Pro (269-07387) for...
Microsoft Office 2003 Pro (269-07387) for PC Logo
4,186 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
