Question about Invicta Watches
Hello i recently changed the battery in my invicta 4050 atomic movement watch. and now going on close to a month has not corrected its self to the right time. is there a manually procedure to correct the time. thank you,
5 Suggested Answers
escapement
  • 2334 Answers
SOURCE: cannot get invicta atomic watch
Here is the link to Invicta watches:
http://www.invictawatch.com/
Choose SERVICE and click on relevant tab to find out instructions.
As this is the only site on internet, there isn't much more I can do for you.
Don't forget to rate, please.
Posted on Jan 13, 2009
cmcduncand
  • 714 Answers
SOURCE: on time atomic watch wrong time zone
The EXSV10 Atomic Talking Watch by On-Time sets itself to the official time standard of the United States government, maintaining split second accuracy. It can also literally "tell" you the time. It talks! The On-Time talking atomic watch also has daily alarm capability, and can be set to announce the time every hour.
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 24, 2010
joeguest2
  • 2080 Answers
SOURCE: Hello! I bought the Invicta 8939
Most good dive watches with a screw in crown need the crown to be pushed in and turned clockwise AT THE SAME TIME in order to screw in the crown fully and make the watch watertight.
When you want to adjust the date or time, you just rotate the crown counter-clockwise until it pops out a bit. If you gently pull the crown out to the first position you can turn it to adjust the date. If you pull the crown out farther, to the second position, then you can turn it to adjust the time.
Never take your watch into the water unless the crown is fully screwed in finger tight or water will get into the watch movement compartment and ruin it.
Good luck, hope this helps.
Posted on Mar 23, 2011
  • 1739 Answers
SOURCE: I can not set time
Invicta provides a generic Instruction Manual for all models. The manual can be found here:
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
Posted on Jun 08, 2011
My invicta reserve Zeus bolt stopped working after not wearing for a little while and now I tried winding back up and it doesn't want to work
Most Invicta Bolt Zeus watches have a quartz movement and require a battery. I'm not sure there is any Zeus with a mechanical movement that needs winding. A jewelry store should be able to change the battery for a small fee if that's what it needs.
Mar 21, 2016 | Invicta Watches
The second hand won't tick
On many Invicta watches, the large hand which points towards 12 o'clock is not a second hand. It is the hand used with the stopwatch function. If yours is a chronograph, the second hand, if there is one, may be one of the three small dials on the watch face. There are a number of movements used in Invicta watches and the operating instructions can differ from movement to movement. The battery also will be different depending on the movement.
Dec 01, 2015 | Invicta Subaqua Watches
The invicta 4048 is an atomic watch with 4 buttons only. I need to know how to set this watch. Previous experts have refered me to the standard Invicta instructions PDF. The atomic watch is not covered...
The Invicta Atomic 4048 is "discontinued", and Invicta is not very helpful. They do NOT offer an instruction manual for the 4048, because it's discontinued. You can call Invicta at 800-327-7682 then you have to ask for "Melvin" who only works until 1PM eastern time. OR you can do the following:
Hold down the 8 0'clock button until it flashes, select 12hour or 24hour preference, use the button at 4 o'clock to select your time zone (GMT) The watch should reset itself to your GMT time.
Mar 01, 2011 | Invicta Atomic Collection Autotech Analog...
Neeed manual for Invicta 4047 Atomic Watch
The Atomic watches set date & time automatically. The general instruction book applies to the alarm & chronograph features.
Jun 25, 2009 | Invicta Atomic Autotech 4051 Watch
Casio 4305 battery change problem
You don't say whether it has the minutes right and the hour wrong or if both are wrong. If it's just that the hour is wrong, you need to set the time zone.
Atomic clocks and watches have a "zero" position. Your manual should tell you how to "zero" the watch and what the time should be when it is zeroed. Each manufacturer is different. I have one that points to 3:00 and one that points to 12:00. If you zero your watch and it doesn't point to the right position, you will need to remove the movement from the case and manually move the hands to the zero position.
Been there, done that.
Jun 13, 2009 | Casio Waveceptor Atomic VQ200HA 1AV watch
Lost manual to set atomic 4045 watch
Unfortunately no. You will need to try contacting Invicta direct. Sometimes you can go to Invicta retailers and they will have some left over or they will have instructions for similar models.
Mar 26, 2009 | Invicta Atomic Autotech 4051 Watch
Watches Logo
306 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
