Question about Kenmore Dishwashers
I have a Kenmore Elite dishwasher. 6 years old +/-. It doesn't turn on. The buttons to the left of the panel light up and time amount is indicated but the start button doesn't start the machine.
  • 3 more comments
  • alane970 Nov 11, 2010
    Daniel gave me a solution and I got all excited but it didn't work. I think he thinks I have a different model. He said to reset the control by pushing High Wash temp- Heated dry-High Temp Wash- Heated Dry. My machine doesn't have those buttons.
    Starting from left to righ my buttons say;
    Antibacterial
    Pot Pan
    Normal Wash
    Chinaq gentle
    Time saver
    Quick rinse
    HiTemp scrub
    Sanu rince
    Air dry
    Delay hours
    Start
    Cancel
    With these , is there another sequence to reset the control panel?
  • alane970 Nov 12, 2010
    This did not work.
    These did not work
    Is this an easy, unplug/ plug event?
    When I took the door apart previously to see what was happening the only thing insode was the dorr mechanism which is all mechanical and a circuit board that appeared to be easy to repove then unplug old wires and plug into new control panel. That circuit board IS the control panel you are speaking about.................right?
  • 4,323 Answers
Hi
It seems that the control needs reset, to reset press these buttons 3-4 times in sequence HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY. You can also press and hold the AIR DRY/RINSE ONLY button for 15-20 seconds. After doing this if the issue remains then the control needs to be replaced. Please let me know if you need more help.
Daniel
Posted on Nov 06, 2010
  • 2 more comments
  • Daniel Scott
    Daniel Scott Nov 11, 2010
    To reset press and hold the AIR DRY button for 15 seconds. Another way of resetting is to press these buttons in sequence NORMAL WASH-QUICK RINSE.
  • Daniel Scott
    Daniel Scott Nov 12, 2010
    Replacing control is only other option.
  • Daniel Scott
    Sorry for late response...it depends on how good are you with electronics...
  • Daniel Scott
    Yes you are right
The pots and pans light and normal light is blinking
Kenmore Elite Dishwasher blinking light Control Board FIX ...
? 1:37
www.youtube.com/watch?v=flzhfmIIYpM
Apr 14, 2011 - Uploaded by MegaHowtoMan Kenmore Elite Dishwasher blinking light Control Board FIX ....year old washer, did a google search for the problem, and your video came up.
Sep 01, 2015 | Dishwashers
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Dishwasher won't start and start button doesn't light, but other buttons respond
I think you still have warranty, it sounds you have faulty control panel, even if it's new does not mean it is good.
Mar 19, 2013 | Kenmore Dishwashers
Kenmore elite dishwasher wont work
Remove the console panel with T15. then remove the cover from the main control board. top right of center of the main control you will see a removable fuse, either a black disc with a black and a black/w white strip connected. remove one wire from the thermal fuse and check for continuity. if it is open replace it. if it is not open call for service.
Apr 30, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite: Model 66576962K601.
I had exact same issue. I've called Sears Maintenance. They had to change 2 pieces in UI: Timer KUDS02SRB10 and CONSOLE Assy. Cost 360$ pieces  130$ Job Charge 60$ taxes.
Now It works perfectly, but I bought 1100$ 3 years ago... Really expensive to keep it running.
Nov 29, 2009 | Kenmore Dishwashers
Dishwasher clean light blinks after i turn it on
If the Unit is one year old or less it will be repaired free of charge if you contact the manufacturer, they will find the nearest certified appliance repair company in your area.
The problem will turn out to be a bad control panel or control board.
Good luck
Sep 12, 2009 | Kenmore Dishwashers
Kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
Apr 19, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
While not in operation dishwasher slowly fills up.
water valve is clogged try to turn your valve to dishwasher under sink
Nov 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Elite Dishwasher Problem
I had this same problem so I took the front panel off to access the thermal fuse.  What I found instead was that food had become lodged in the door latch which was keeping the door safety switch from operating properly.  I took a thin screwdriver and removed the food from the cavity.  Since you did not have the problem in your first five years the cavity just might be the problem since that is about the amount of time it took me to get too much food stuck in mine as well. This solution took five seconds and requires no disassembly.
Oct 09, 2008 | Dishwashers
I had the same problem when I bought it and it just happened again; the problem is solved by ressting the control panel: Hi Temp ---> Heated Dry two or three times. It kind of goes into a testing cycle and the clean blinking light goes off.
Dec 08, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
51 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
