Question about GE Dishwashers
My GE dishwasher does not drain. Model GLD5600N00BB. I have cleaned out the drain passgge and jiggled the air knob with no success. I have raised the flexible tube to 32 inches above the floor . Is there something that I can do to test the drain without having to run a full wsh cycle each time I adjust something?
SOURCE: dishwasher will not run. clean light flashes seven times
I had success with the "Hi-Temp Wash - Normal - Hi-Temp Wash - Normal" sequence of button selections. This must occur within 6 seconds and initiates an internal diagnosis of the machine. The process runs for about 19 min. and shuts off. During the process several LED's light up and several funtions start and stop. If the machine has no broken systems, you should be able to open the door add some soap and the usual dirty dishes and carry on with normal operation. Thats all I have done and the wife is no longer on the war path. Good Luck
Posted on Mar 01, 2007
  • 4 Answers
SOURCE: Neff Dishwasher won't drain
I've had this problem a couple of times with my dishwasher. In both cases, the cause was a shard of broken glass that had managed to get past the filters and jam itself underneath the impellor. Hard to see, but easy to fix. First ladle out the water.
Pull off the lower rotor arm, unscrew the filter and take out the filter bowl, tray and cylindrical filter. Get as much water as you can out of the filter cavity.
Then, using a Torx-20 driver, remove the screw holding the impellor cover and lift the cover off. (this is the small bit of plastic at the left end of the filter cavity.) Check whether the impellor can rotate freely by spinning it with your finger several times - if it jams or grinds, then there's probably something jammed under it. (It may seem to be fine at first, so do check thoroughly, as any debris can move around with the water flow and only jam occasionally) You may have to use a cocktail stick or similar to poke out anything that's stuck underneath.
Glass is a particular problem, since it's almost impossible to see when there's any water around (it's easy to cut yourself too!)
Anyway, that's worked twice for me now - and I didn't have to even move the machine out of its cupboard to fix it.
Hope that helps.
Posted on Mar 14, 2008
  • 54 Answers
SOURCE: DIshwasher Cycle TIme INcreases by 20 minutes over two years
Try cutting the breaker off for 5 min, This will reset the control. The issue is in order for a dishwasher to clean the dishes properly the water in the dishwasher needs to be at least 120 deg f. If its not the dishwasher keeps adding more time with the heater on to try to achieve this temp. The dishwasher only uses about 1 gallon of water per fill so if the water heater is a ways away or the temp is not hot enough, the water temp in the dishwasher will not reach 120.
Posted on Jul 04, 2008
SOURCE: GE Dishwasher is not draining water
GE Prifile dishwashers have a valve called a "Piston" and an "O" -Ring under the screen that become degraded over time. The part is around $10 and it takes about an hour to do the repair. You can do this yourself if you are handy and have some simple tools. You can go to the GE website and get a free owners manual.
Posted on Aug 01, 2008
  • 10865 Answers
SOURCE: GE Profile dishwasher not drawing water from water line
If you look inside the dishwasher paying special atention to the left front corner. Remove the lower dishrack and then you will see a dome shaped piece of plastic attached by one screw. Remove this screw and check and see if the float is gunked up. Sometime you have to remove the lower access panel to remove a little pal nut off the bottom of the float assembly to actually remove it to clean. Clean it real good and reinstall. This should solve your problem.
please mark my answer as a fixya! thanks.
Posted on Mar 12, 2009
Ge potscrubber 700 dishwasher - the soap dispenser cover is locked and will not open. I have run the dishwasher several times and tried to force it but it will not budge. any suggestions?
Soap dispenser cover will not open until front knob is at 4:30 or 5 o'clock. Turn knob to 5 o'clock and jiggle dispenser cover. If cover still does not open, is detergent caked such that door won't open? If yes, remove caked detergent. If no, disconnect power at breaker. GE repair manual says to remove screws for inner door panel and inspect detergent dispenser mechanism with lever and trip lever for broken or binding parts.
Oct 13, 2013 | GE Dishwashers
I have standing water in bottom of GE GSD 666 dishwasher. I pressume I need to clean screen/filter? How?
I have the same problem, same model GSD660G0322. Have an inch or two of standing water. When I run the drain pump in Service mode, it successfully clears the water. How do I access the filter to clean?
Oct 22, 2011 | Dishwashers
GE Nautilus dishwasher doesnt drain
Water dosent drain Is there a reset button???
May 15, 2010 | GE Nautilus 24" Built-in Dishwasher
Water is puddeling on the bottom of my 18 yr. old GE dishwasher
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Sep 22, 2009 | EuroTech 24 in. EDW194E Built-in...
DW will not drain
If the dishwasher is not completely draining, your dishes probably aren't as clean as they could be either.
Most dishwashers have a filter screen to keep solid food from getting into the pump. This could be stopped up. Also look for kinks in the drain hose.
Aug 21, 2009 | GE 24 in. Profile PDW7880G Built-in...
GE Model gsd5330d00ww will not drain. There are no drain obstructions and I have replaced the piston gasket in the rear of the tub. What is my next step in figuring out the problem?
HI. check the following areas for fualts.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer/control
Jul 30, 2009 | Dishwashers
Won't Start Cycle, but will put water in bottom of dishwasher
Model # should be on inside of tub wall....but any way...
This is a typical GE problem which I have seen many times...When a DW sets for a while not being used...the motor often freezes up....Take the front (lower panel off....find the motor assembly...(with the DW unplugged!!...very important)reach in with you hand or a screw driver...preferably your hand...at the back of the motor...there should be a impeller blade...you should be able to reach in with a finger and pull it down..it may be resistant so find a way to hold it in place as you reach up to the next impeller blade and pull down further...finally it will all of a sudden free up....after which you plug it back in and start it up...I am also including a step by step (no drain problem check list as you may run into an issue like this if it has not been operated for a while ....notice article # 5).
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
I hope this helps...it is always useful to include the Model #...more specific instructions can then be provided
Good Luck and good day.....please rate my effort...the Fang
Mar 28, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher wont run
This is a typical GE problem which I have seen many times...When a DW sets for a while not being used...the motor often freezes up....Take the front (lower panel off....find the motor assembly...(with the DW unplugged!!...very important)reach in with you hand or a screw driver...preferably your hand...at the back of the motor...there should be a impeller blade...you should be able to reach in with a finger and pull it down..it may be resistant so find a way to hold it in place as you reach up to the next impller blade and pull down further...finally it will all of a sudden free up....after which you plug it back in and start it up...I am also including a step by step (no drain problem check list as you may run into an issue like this if it has not been operated for a while ....notice article # 5).
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Mar 24, 2009 | GE Nautilus 24" Built-in Dishwasher
I have had no problems with my GE dishwasher for the last 3 years. All of a sudden, when its draining, the water is coming up through the extra knob on the sink. I am not sure what it is called, but it...
The drain line between the air gap (thingie next to the sprayer) and the sewer drain piping. If the sink drains fine, the clog is between the air gap and the point at which it connects to the piping under the sink.
Please take the time to give this solution a fix ya rating.
clarkco
Mar 07, 2009 | GE 24 in. GSD4060JSS Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwashers Logo
98 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
