Question about Moen & One Handle Tub & Shower Faucet
I have a moen single handle tub and shower faucet took out the clip and pulled but the stem will not come out what esle is holding it
    Scholar:
  • 81 Answers
You need to purchase a replacement cartridge before trying to remove a defective Moen cartridge. Always buy genuine Moen. If your valve turns on and off with a pull/push action you need part number 1225B, otherwise you need part number 1222. The 1200 cartridge will work in lieu of the 1225B but is more expensive and no longer used in Moen valves. There is a tool that comes with these cartridges which looks a bit like a white plastic cap.with notches on one end and a square head on the other.
Once the clip has been removed the only thing keeping the cartridge in the vslve is old sticky lubricant. Place the tool over the cartridge end and rotate as necessary until the notches are fully engaged and it no longer rotates. Using pliers or a wrench over the squared end, twist the tool back and forth several times. Remove the tool, and using pliers, pull the old cartridge out. Put the tool on the replacement part and insert it back into the valve. Lightly tap on the squared end to make sure the new part is completely seated, then use the squared end again to turn the cartridge as necessary to align for the clip to be reinstalled.
Posted on Nov 07, 2010
Handle will not turn water off
single cartridge? pull old one, flush some water through empty valve then install new cartridge. once installed, make sure the horseshoe clip is properly inserted to keep the stem in. once the clip is in right, there is a chrome tube with a ridge that slides over the barrel and the clip. the ridge acts as the stop for the handle. also make sure there are stops inside back of handle to hit the ridge on the chrome tube. the plastic inside the handle may break off allowing the handle to spin. the stem unit/cart may also be installed 180 degrees out of place. pull the lock clip and use the remover tool that came with new cart to rotate it 180 degrees with water supply turned off.
Jun 17, 2013 | Moen & One Handle Tub & Shower Faucet
We recently installed a Moen single handle faucet in a refinished shower after having a plumber replumb the front of our house. Handle appears to be properly installed. Now there is no hot water or even...
u need to adjust the scald protector all single handle units are shipped in cold position for safety reasons if have paper work for handle it explains how to adjust if not unscrew handle and remove on handle / valve stem will see a red and a blue plastic clips pull back clips and turn slightly and push back do this till desired hot and cold setting are to your liking replace handle and your done
Dec 17, 2010 | Moen & One Handle Tub & Shower Faucet
How do I pull a Moen cartridge from a tub mixing valve?
You pull the little clip out from around the stem and then pull straight out on the cartridge, If it doesn't want to come out you may need Moen's cartridge puller (around $40.00)
Jun 26, 2010 | Moen & One Handle Tub & Shower Faucet
I have a moen 1 knob push-pull faucet for my tub/shower. When I push it in sometimes water continues to drip. It is probably 30 years old. Are their replacement parts for it?
The old MOEN single handle faucets like youve described usualy took a 1200 or 1225 cartridge. Both are available at most of your big home improvement stores. The answer to your question is yes MOEN parts are still avail. Hope this helps. If this advise is helpful, please give me a vote.
May 13, 2010 | Moen & One Handle Tub & Shower Faucet
Moen Single Handle Shower faucet can't get cylinder out
New moen cartridges for tub/showers come with a handy white plastic tool to aid in old cartridge removal. One end is squared off for a wrench, the other is slotted to place over the old cartridge in the wall after the clip has been removed. Place onto cartridge and use a wrench to turn several times back and forth. Remove , grab the stem with pliers and give a tug. You want either service part #1225B (pull/push to turn on) or #1222 (just turn knob counterclockwise to turn on. Get the replacement before you proceed.
May 06, 2010 | Moen & Bayhill& Single Handle Tub & Shower...
Moen single stem bathroom basin tap (25 years old). Trying to remove cartridge to grease it or replace it. Have removed handle and retaining clip. Pulled hard but can't shift it. Don't want to break...
You are on the right track. You have to use some force when pulling the stem from the faucet. Your replacement cartridge should have a little black or whit cap. that is inserted on top of the cartridge and by turning the cap will help loosen the whole cartridge
Feb 21, 2010 | Moen & One Handle Tub & Shower Faucet
Moen one handle tub & shower is leaking from spigit
A stem is a cartridge in a real old valve. You have pulled retainer clip, you can try to pull it out with pliers, but you might need a moen cartrigde puller.
Sep 06, 2009 | Moen & One Handle Tub & Shower Faucet
Moen single tub shower handle insatll
The valve has a faceplate that attaches with two screws and depicts the hot and cold mixing scheme on it. in the center of this is where the valve stem is located. It has a chrome escutcheon that slides into the faceplate and over the stem.There is a small -U- schaped clip that slides into the top of the valve body where the valve stem is seated that retains the valve stem. With all this in place all you have left is the acylic handle that has a unique shape to it on the internal portion that corresponds to the shape and position of the valve stm. Align the handle and stem and push the handle on. A small screw goes into the center of the handle to attach it to the valve stem. LASTLY you should have the acrylic button that covers the screw holding the handle on. All you do is align it appropriately and push the button onto the handle. The chrome handle version is essentially the same but is retained by a small allen screw on the underside of the base of the handle. I hope this assists you and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Oct 22, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Moen & One Handle Tub & Shower Faucet  Logo
599 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
