Question about Electronics - Others
My files in the teac 1gb sd card cannot be delete or remove, i tried to format the sd card be error message says cardis write protected
  • 70 Answers
This card will be formated by ms-dos command first you open dos window then type a command format e: enter key.
Posted on Nov 06, 2010
When I enter my memord card in nokia 311 it say the operation is failed and the memory card is not formatted.how to remove virus from my memory card and replace my music and Image.
All you have to do is
Step One (save data)
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
When do the data recovery process, you can find the cause of damage to the micro SD.
Cause of the damage the virus infected (solutions: see method 1)
When saving data, be careful, do not recover the virus file. You must choose the proper file for the recovery.
Cause of the damage bad sectors (solutions: see method 2)
Damage to the partition table (solutions: see method 1)
Micro SD write protect. Characteristics: (solutions: see method 3)
1. Micro SD can be opened, the data can not copy and paste (from the micro SD into a computer, or from computer to the micro SD). When the format, the message "Removable media write protect".
2. Micro SD can not be opened, and when the format of the message "Removable media write protect".
Step two (repair micro SD)
Method
Using the HP Drive Key Boot Utility, the first way
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
Method 2
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
Method 3
To write protect a micro SD cases, 40% probability of success.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
I hope this information helps. Thank you for using FixYa!
Oct 02, 2011 | SanDisk 2GB microSD Memory Card
I have 1gb kingston microsd card not opened tell password now.plse tell me master password
I can help. What is not the problem, is the position of the switch entirely. With the SD card Face up and the tiny white plastic switch on the left side, should be slid toward the card edge connector (the shortest side). I know you may have done this and it still doesn't work. Here's why, On the opposite side of the SD card from the switch, there is a tiny "Notch" cut out.
Place a piece of tape, masking, electrical, sometimes transparent will work. Be very precise in placing the tape over the notch, but not over the brass connector on the opposite side. Then place it in your card reader, format it, read and write files to your desire.
This is a little known issue with the design of all SD cards. The notch forces them to work in camera's, MP3 Players, PDA's, etc. that are portable devices, but not in USB card readers or computers with SD reader slots.
The card reader with the SD card has this extra built in feature to protect copyrights (for some reason on blank cards), and makes it useless for custom applications. Once you have "Unprotected" the SD card, installed your files, then remove the tape.
If you get the same error again after applying the tape, add a second layer. Double check that you did not cover the connection edge, and the plastic tab is closet to the side you insert in the device you are using.
Sometimes it takes several tries, but it will work with patience. If you have existing files on the SD card, insert it, right click, select properties. Then remove the "Read Only" check by the box and try to delete or add files then. If it says Disk Write Protected, then check the tape again.
Dec 18, 2010 | Kingston 1GB Secure Digital Memory Card
Write protection problem of my mobile memory card
Hi..
To remove the right protection it is very simple, first remove your SD card in your mobile, the observe your SD card back to back, if you can see a small button you need to slide that button to remove right protection, then plug your SD card back to your china mobile and try to copay a folder,
Good luck !!!
Regards
PCmania
Jul 11, 2009 | Nokia N72 Cellular Phone
How to remove write protected memory card
Dear the card adaptor which you are using on the side of adaptor there is a side lock please check it may be it is lock that's why u r not able to transfer data.
May 20, 2009 | Motorola Mobility L6 Cellular Phone
Write Protected
When I try to delete the files Kingmax 1GB Micro SD Memory Card it says that The disk is write protected or insert other disk
Oct 29, 2008 | Kingston 1GB Secure Digital Memory Card
micro sd 1gb card write procted problem
Sep 13, 2008 | Nokia N95 Cellular Phone
when i attach the card reader with system and when i store the software or any thing in memory card then msg show that(cannot copy because write protected error)
Aug 29, 2008 | Nokia 3230
SanDisk 1GB microSD Memory Card
The write Protect tab, is usually write protected with a small white plastic flick switch, On The side Of the SD Card. If its Down, or In Lock Position. Then It,s Write Protected.
Mike @ compurepair.
May 10, 2008 | SanDisk 1GB microSD Memory Card
Kingston 1GB micro sd card
remove your sd card from unit...in sd card you can see very small slide switch..switch it off.
Feb 17, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
