Question about Fedders A6P09S2A Air Conditioner
LEAKING WATER I have 2 of the same units. One works fine. The other, after 15 minutes of cooling, the top reservoir fills, and leaks onto the floor. The plastic reservoir has no drain, or hole to allow the condensation to collect into the bottom reservoir. Any ideas???
  • nickandsara Jul 17, 2008
    I have the same problem.  Did you figure out how to fix it?
    Problem Solver:
  • 7 Answers
Does the other unit have a drain?
Posted on Jun 15, 2008
Polar water cooler leaking from inside
Oh, so it's your wife's fault, then :-) Just joking!
If this is one of the ones where you put a big bottle on top, chances are that there's a crack in the bottle itself -- this lets air leak in, and without a vacuum seal, yep, just keeps leaking onto the floor. Call your water guy. If you have a spare bottle, you can pour the water from the leaking one into the last one, and make sure the service guy knows the bottle is broken.
If not, whats the model number. If not sure, take a photo.
Jul 26, 2016 | Refrigerators
My Comfort-Aire Dehumidifier has started leaking water. The unit works fine but the water bucket does not retain all the water. As the bucket fills there are slow leaks. Also, sometimes when replacing the...
It can have leaks from the condenser to the bucket. The piping and hoses should be checked all the way. Perhaps even replaced or at least cleaned. I don't think it is wise to do this yourself. Because in the system also can be algae, bacteria and viruses. And you need tools and skills to replace defective tubes, pipes or gaskets.
Oct 10, 2014 | Dehumidifiers
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
How do I fill the water resevoir for the conair steam mist curling iron??
HOW TO FILL THE WATER RESERVOIR: 1. Remove water reservoir cap (the one at the end point of the hot part) and unscrew steam activator in order to fill. CAUTION: Steam activator is very hot while in use. Do not touch. 2. Fill reservoir with water. 3. Place cap back onto unit making sure water is not leaking out. NOTE: Fully immerse the wick and wick holder in water for at least 15 seconds before use.
Jun 26, 2011 | Conair Health & Beauty
My unit is leaking tons of water only when a/c is on for a while. It leaks out of base and I have to drain tank every day. Help!!!
It is supposed to "leak" water into it's reservoir and it needs to be dumped when it gets full. That water is the humidity that the a/c is pulling form the air inside your home. As long as it's going into the reservoir and not leaking onto your floor then it is working properly.
Jun 24, 2011 | Windchaser PACR10 Portable Air Conditioner
Tub leaks, with a partially filled tub (2.5 inches measured from the lowest point over the pump assembly.) Promblem occured after the washer was idle for 3 weeks. Have just replaced the main water inlet...
I am assuming leaking when it is running, not sitting idle. Leaking from the door? Fill and run unit for 1 minute with no detergent. Open door. Are suds present? Suds turn into water when they drop to the floor. Suds can flow over the lip of the tub and drip to the floor. Oversudsing, Sometimes old detergent breakdown. Rinse aid dispenser leaking will cause oversudsing. Combination of all in one products will cause many problems. If suds are present after running unit a minute, pour a cup of cooking oil in unit. Run and fill it a few times until suds are gone. Possible most common cause is dispenser latch grommet.
Oct 15, 2010 | Maytag MDB7100AWB Dishwasher
Change my dehumidifier from draining by hose, to reservoir
I don't have the exact dehumidifier as yours, but on mine it's as simple as removing the hose, then the water fills the reservoir. Does it look like yours will do the same? If so, the hose fitting is also a sensor that will shut the unit off when it is full to avoid leaking onto the floor.
Sep 11, 2009 | Maytag M3DH30B2A Dehumidifier
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
I have a Frigidaire upright freezer that is leaking out the bottom of the unit onto the floor.......It is running fine and freezing fine.....I thought it was out of level, and it was, but I did level it...
yout drain in the frig. is clogged,find the drain reservoir most times in the back top of frig. remove cover and clear it out with a hanger or shop vac,if ice is there melt it with hair dryer then claer out,hope this helps,thanks-mike
Jun 01, 2008 | Frigidaire Refrigerators
i got a vienna digital when i take the water container of to clean it 1 time out of 2 im gonna have water all over the floor what i do now clean the container put it back fill the water container with big glass and no more leak it probably have to do warp water container when it empty it seat perfectly when you have it in our hand it warp a little bit were not the only one with that me when i dont remove the container to fill it up i have no problem since then thanks for using fixya pierre
Feb 25, 2008 | Solis Master 5000 Espresso Machine
Fedders A6P09S2A Air Conditioner Logo
191 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
