Question about HP Photosmart Premium C309A All-In-One Printer
Cartridge/862 black and yellowe finesh - HP Photosmart Premium C309A All-In-One Printer
  • 70 Answers
Please refill your cartridge and it will work again it will refill by dealer.
Posted on Nov 06, 2010
Prints yellow instead of black
I had the same problem with my Brother MFC 490 CW. It suddenly started printing yellow instead of black. I believe my problem was cause by a mislabeled third party black ink cartridge. The cartridge was labelled black but it had a yellow end piece. In any case I took out the black cartridge and replaced with another. Initially it made no difference I assume because some yellow ink was still in the tube. After 10 or so pages of printing the print turned darker. I also did three cleanings and unplugged the unit and then plugged it back in. I am not sure what if anything these latter two actions accomplished, but I wanted to report all I did in case they were actually part of the solution. My own conclusion is that it was simply a mislabeled cartridge.
Dec 05, 2011 | Brother MFC-290C Multifunction Color...
Changed black cartridge now small black dots on all pages, even on test pages. bad cartridge?
Run the "Disable Cartridge Check" diagnostic
It will allow you to put the black cartridge in a different slot i.e. yellow. If the black cartridge in the yellow slot still puts black dots on the page...it is bad.
Can you put the original old black back in the printer. That will tell you right away if the replacement is bad.
Jan 20, 2011 | HP LaserJet 3600n Printer
Error cod 0xd0620230
Issue The product displays a '0x ... ' error message. The exact text of the error varies by product, but it is usually preceded by the word 'Error .' Important: If your error message includes the words 'ink system failure ,' check your cartridges before reading this document. If you use any of the following cartridges,Cartridges 564, 364, 178, 862, or 920
    Figure 1: Example 564, 364, 178, 862, or 920 cartridgesSolution one: Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Nov 02, 2010 | HP Officejet 5610 All-In-One InkJet...
Photosmart 8250 0xc18a0207 carlitosfop
This is a general printer error which occurs when ..........
a> cartridge/s are changed
b> defect in integrated printhead
HP Single-Function and Multi-Function Printers - An '0x ...' Error Message Displays on the Front Panel When Printing (c00489814) Issuegtabtop.gif The product displays a '0x ... ' error message. The exact text of the error varies by product, but it is usually preceded by the word 'Error .'
c01733891.gifImportant: If your error message includes the words 'ink system failure ,' check your cartridges before reading this document. If you use any of the following cartridges, refer instead to 'Ink System Failure' Message Displays on the Control Panel (c01458034) (in English) to solve this error:
  • Cartridges 564, 364, 178, 862, or 920
    c02264161.gifIllustration: 564, 364, 178, 862, or 920 cartridges
Solution one: Reset the productgtabtop.gif
    c01651067.gifDescription of disconnecting the USB cable.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
Solution two: Service the productgtabtop.gif
gtabtop.gif If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jul 16, 2010 | HP Photosmart C7180 All-In-One InkJet...
I have an HP Color LaserJet 3700 that has decided to stop printing yellow. I have changed the cartridge several times and have run all of the diagnostics/calibrations many times with no success. I want to...
Press Menu. Drill down to Diagnostics
Go to DISABLE CARTRIDGE TEST
Now swap the Yellow and Black cartridges.
Print a Config page. If Yellow doesn't print, your cartridge is bad. If Black doesn't print, you could have a bad laser/scanner
Feb 05, 2010 | HP Office Equipment & Supplies
I need black ink for my lexmarkc540n printer
This is the worst printer! i advise everyone not to buy!! changing ink every week!!!!! total garbage!!!!!!
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
Fax says to replace yellow cartridge...
There is a menu prompt that allows you to choose to print in black only.
Sep 16, 2008 | Office Equipment & Supplies
Re-installing yellow cartridge in HP 2840
There is a gray button right of the LCD display that has a black arrow circling clockwise and four color dots (magenta/black/cyan/yellow). Push it until you see the "Rotating to Yellow" in the LCD display, then open up the top of the printer by pushing the big gray latch next to the picture card reader at the right front of the printer. You now have access to the cartridge. pull it out and examine it. If it is a new cartridge, check to see if you pulled the plastic dam strip out (which keeps the toner in place in shipment etc).
Sep 07, 2008 | HP LaserJet 2840 Printer
Cannot get yellow to print
I had the same problem with the yellow cartridge. Yellow quit printing, put in a new yellow and still would not print yellow. I had a help file, don't know where I got it, but it suggested replacing the black ink cartridge also, even though the black wasn't low yet. Replaced the black, ran a few nozzle cleans and everything worked fine. Don't know why. Try it
Mar 03, 2007 | Epson Stylus CX6600 All-In-One InkJet...
HP Photosmart Premium C309A  All-In-One Printer Logo
54 people viewed this question
Ben Johnson
