Question about Honeywell Programmable Thermostat Heater
I just bought a new honeywell thermostat last year and it always kicks on about every 15 min, waht is the problem!? i bnought is to savew energy and it seems as if it is using way more the it should. please hlep me!
  • 528 Answers
All thermostats have a component called an anticipator which guesses when the heater should kick on - I suspect yours is out of adjustment. If you can, find the installation instructions and look them over for the setup procedure and fine tuning of the anticipator. It's usually hit or miss as you try to get it adjusted properly. If you don't have the instructions, get the model # and go to honeywell's website for the instructions. It is also possible you can go to where you bought the thermostat from and they will let you look over instructions from another one on the shelf.
Posted on Nov 06, 2010
Honeywell RTH2300 says Heat On, but furnace isn't running.
Your tstat is not the problem. I've not yet worked on an oil furnace. I'm way down south. But either way, if your tstat was calling for heat(heat on), and you pushed a reset at the furnace, more than likely that reset is a safety. OK to reset, but now what ever that safety is preventing from happening, has failed and can not be reset until repaired. The reset should be an automatically opening switch upon unsafe operation. And manually closed to "reset" the safety. That safety is connected to something that is not working properly. Hope this helps!
Mar 02, 2017 | Honeywell prgrammable thermostat RTH2300B
Honeywell rth7400d
your thermostat is getting bad and cannot get temp very well either due to batteries or old life try getting a new one
Dec 17, 2013 | Heating & Cooling
Ac set at 74 room temp up to 78 and no Ac kicking on.
it could be the thermostat is loose on the subbase or if you went from OFF to COOL and the stat is a digital stat It will not come on for five min. This is a delay set by the manufacture to protect the compressor. during normal operation you will not notice because thier will be more than 5 min from the time it shuts of till it need to come back on but if the system switch is set to off and you switch to cool or unit just shut off it will always delay 5min. usualy there will be some insdiction on the screen that it is in delay like a flashing COOL or SNOW FLAKE or the word WAIT. the unit will not be running until the flashing words go solid
Jun 26, 2009 | Honeywell Programmable Thermostat Heater
Honeywell thermostat won't regulate temp properly
check to differential setting in the thermostat and are you saying the temp in the room and the set temp is being read from the thermostat or is there another thermometer in the room your looking at
Jun 25, 2009 | Honeywell Electronic Programmable...
Thermostat just stopped working.
is the tstat in cool mode? if not hit the mode button untill cool pops up then hit the down airow untill desired temp. sometimes the thermostat has a 5 min delay so be patent. If unit still does not run call the service co. and find out about how long they warranty their service call. usualy one month.
Jun 14, 2009 | Honeywell Electronic Programmable...
Fan blows too strong (and loud) when heat comes on
Make sure your fan switch set to "auto". If there is a switch or jumper in the t-stat labeled "G" and "E" or "GAS" and "ELEC", it should be on "E".
Please rate my answer!
Mar 14, 2009 | Honeywell Programmable Thermostat Heater
Have gas furnace and this winter,began having
The Thermostat Wizard is an interactive tool that will guide you through wiring and troubleshooting your thermostat, as well as programming it to the most comfortable settings for you and your family. Simply answer the questions from the Thermostat Wizard to correctly connect, troubleshoot and/or program your Honeywell Thermostat. You can even print the instructions and bring them right to the thermostat to help make things easier.
Go to: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
However - the problem is probably not with your thermostat but with your furnace. It is most likely a dirty flame sensor - a maintenance issue. If you have not had your furnace serviced recently (more than 1 year) that is where you should start. Modern furnaces require regular maintenance.
Feb 28, 2009 | Honeywell Electronic Programmable...
Furnace kicks on every 15 mins
fuanace may be oversized and is short cycling it heats up house to fast it is better when they run longer
Dec 06, 2008 | Honeywell Programmable Thermostat Heater
Honeywell rth7400 keeps turning furnace on
check your heat antisipator setting make sur eit matches your tpye of heat. also, do you have a 2 stage heating sys?
Nov 21, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
338 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
