Question about Troy Bilt 5.5hp Self Propelled Mower
How do you store lawnmower for winter? do you
How do you store lawnmower for winter? do you leave gas in mower? do you charge and take battery out of lawn mower? or is it okay to leave battery in mower over winter?
  • 116 Answers
Mix a fresh gallon of 89 octane with a fuel stabilizer. run for a few minutes. the battery will need a trickle charger.
Posted on Nov 06, 2010
    Problem Solver:
  • 9 Answers
Fuel stablizers are not the right option simply take off your air filter tie the safety back so you can crank the mower as its running mist wd 40 into carb lightly you will hear the mower start to choke out stop the spray then start again after you have ran wed 40 through the grab then drain the tank restart the mower and lightly mist wed 40 until it runs out of gas I use to run a rental go kart track in Michigan some stableizers gel up in extreme cold that means a carb and tank cleaning by using wed 40 it coats and preserves make sure you drain the gas and eat it run completely out then I promise you simply fill with fresh gas and pull the cord I had 25 rentals our winters are 5 months long make sure you reconnect the fuel line just saying thanks this works for all gas powered mowers
Posted on Sep 04, 2014
Lawnmowers; mine is not starting. First use this year I believe the fuel might be gummed up from sitting over winter. How do I clean this out?
When gasoline sits for an extended period of time the "varnish" builds up inside the carburetor and can keep your engine from running. If you suspect that this has happened, the only good solution is to first replace the carburetor, and then ALWAYS use a Fuel Stabilizer every time you buy gas for your lawn mower.
Also, at the end of a season, it is always a good idea to run the engine until it is dry and out of gas before storing the lawn mower over the winter. A fuel stabilizer should keep your gas fresh over the winter, and the lawn mower will start up quickly in the spring. If you are the cautious type, always buy fresh gas at the beginning of every season, and NEVER forget the fuel stabilizer no matter what. Gas starts turning bad after just 30 days....
Rayko
May 23, 2015 | Garden
Bourght petrol 471sp lawnmower with no manual it will not? put in oil and petrol.
probably the gasoline gummed up at bottom and needs to be cleaned. if the gas is not emptied when stored it can do this and will not start
Apr 08, 2015 | Garden
Craftsman lawnmower won't start after winter storage
Try to put a little gas in the sparkplug hole.Put plug back in then try to start again.
Feb 20, 2015 | Craftsman Garden
Motor will not start-kuskee 42" lawnmower
Did you leave gas in it over the winter? Todays excuse for gas is goes bad very fast in a carbureted engine
Jun 26, 2013 | Garden
Electric lawnmower battery won't hold a charge
charger for same does not show any lights..so should i assume the charger is not working?
Apr 28, 2012 | Electric Lawn Mower
Lawnmower won't start
Remove the bowl from the carb. and blow it out with air.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
Black & Decker Cordless lawnmore CMM 1200 - battery
I bought my B&D cordless mower CMM1000 (very similar to the CMM1200) in April 2003. I made the mistake of following their instructions and stored it inside unplugged the first winter. Never again! The battery would not hold a charge April 2004, but was covered under warranty. Since then, I've left it trickle charging in the shed year round, including cold winters. No problem since then with the battery, which will last about 5 yrs before you need to replace it.
Nov 29, 2008 | Black & Decker 19" Electric Lawnhog...
B&D battery lawn mower - winter care
Hi, it depends on the age of the battery. if it's new no ploblem depending on the age you may have to give it a trickle charge in jan.
If this doesn’t work for you please write back. Thanks,
Nov 19, 2008 | Black & Decker 19" Electric Lawnhog...
** Help Starting **Yard Machine 21inches 139cc
amiseybold;
First check for spark. Remove the spark plug. Leave the spark wire connected. Hold the plug against the metal of the mower engine so you have a ground and can see the gap of the electrode where the spark jumps across. Have someone pull the starter cord and verify that you have a spark. Hold it by the threads of the plug so you don't get a little spark jolt yourself.
go to an auto parts store and get a can of starter spray (it's actually ether), Remove the lawnmower spark plug and spray a little ether in the plug hole. Put the plug back and tighten it and see if it starts.
It will probably start, run for 5 or 10 seconds and then die. Repeat this procedure once or twice again and eventually it will start to draw gas from the lawnmower tank.
A seasonal tip. when you put the mower up for the winter, **** the remaining gas out of the tank, start the engine and let it run until it uses up the gas in the carburetor. This will make iot much easier to start in the spring
Hope this helps Good Luck Loringh PS Please give me a rating
Nov 08, 2008 | Yard Machines 158cc Push Lawn Mower #11a...
Troy Bilt 5.5hp Self Propelled Mower Logo
273 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
DROPNDEAL
DROPNDEAL
Neil Hancock
Are you a Troy Garden Expert? Answer questions, earn points and help others
