Question about Costar DYMO DiscPainter Printer
Where can I get a drive belt for my Dymo DiscPainter?
How do I re-install my Dymo on my computer after the computer has been scrubbed.
There should be a installation setup CD that came with the unit. This will install the driver(s) and software that will allow you to use it. If you don't have it anymore or cannot locate it, go to this link and download it.
Sep 17, 2014 | Dymo LabelWriter 400 Turbo Thermal Printer
How to disable DYMO label roll sensor in DYMO 450 turbo
The sensor cannot be disabled. DYMO printers (including the 450 series) are hard-wired to only work properly with genuine DYMO labels.
^CM
Mar 14, 2014 | Dymo LabelWriter 450 Turbo USB Label...
What if you plugged in drive for labelwriter 450 before you downloaded software?
Here is how to install the software:
1. disconnect the printer and make sure you log in as an administrator. If you need to, back up your contacts: Address Book > Export;
2. uninstall everything that says DYMO (Start > Control Panel > Uninstall) and re-start the computer (back up whatever should be saved);
3. install the latest Windows updates;
4. install DYMO Label 8.5.0: see the download link below(I suggest right-clicking the downloaded file and running it as administrator);
5. connect the printer directly to the computer only when prompted;
7. only use DYMO-made rolls - black stripes on the back, the logo and article number should be there.
tinyurl.com/dymolabel850pc
Also, please go to Start > Devices and printers > right-click the printer > Printer properties > Ports > clear Enable bidirectional support > OK.
^CM
Jun 05, 2012 | Dymo ® LabelWriter® 450 Series PC...
The Installation keeps telling me that it will only work on a 32-bit computer. No where in the sales was I told this. Now how do I get it to work.
its probably talking about a 32-bit browser. some browsers could be 64bit. when you download it if there are options on where to download sometimes it will say "windows 32-bit or windows 64-bit" then choose 32-bit. also check if your default browser is 32-bit. an example of a browser is internet explorer, safarri, firefox, etc.
hope this helps. thank you.
May 23, 2011 | Costar DYMO DiscPainter Printer
A print job queue is preventing other print jobs from printing
a print job in the print queue is preventing other print jobs from fixed printing
Dec 30, 2010 | Costar DYMO DiscPainter Printer
Hi I'm wondering if the Dymo pocket will take a tape, so that I can iron labels on to clothing or even be stitched on. If so what would the cassette be called. Thanks
The Dymo label printer capable of printing iron on tape is the Dymo Letratag. There are a couple of model printers
Dymo Letratag - handheld model
Dymo Letratag - desktop model with qwerty keyboard
and the Dymo 18771 Letratag iron on tape is the tape cartridge available.
Jan 21, 2010 | Dymo LabelPOINT 100 Thermal Printer
Dymo 320 labelwriter downloadfor windows vista
Installing Dymo software on Vista can be a real nightmare if you fail installation at first time.
Call Dymo customer support, they will follow you step by step, ask you to download dymo uninstaller for your model, and tell you how to clean registry. They got used to this.
DYMO | Contact Us
May 14, 2008 | Dymo LabelManager 300 Desktop Labelmaker...
Dymo Labelwriter - Compatible Labels
Nina try www.labelvalue.com for Dymo labels and Dymo compatible labels. The shipping is also free.
Feb 15, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
DVd label
All document printers with disc printing capabilities suffer from disc feed problems. It is an inherent design flaw that results from the machines original design to print documents. Loading discs to be printed must first "go around" the printer's paper feeding mechanism to accept discs. I got tired of using document printers to print labels on discs. I switched to a DiscPainter made by Dymo. It is a dedicated disc printer that was designed as such from the outset and not as an afterthought. It prints every bit as well as any document/disc printer but without the frustrating mis feeds. Although the Canon printer is great for documents its design limitations for disc printing are not easily overcome.
Feb 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Costar DYMO DiscPainter Printer Logo
140 people viewed this question
Top Costar Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Costar Office Equipment and Supply Expert? Answer questions, earn points and help others
