Question about Infogrames Just Me and My Dad for Windows, Mac
General Protection Fault in module dad.exe at 0004 : 1752 in XP
When I try and load a card stitch I keep getting the following error message: PCDWIN22 Caused a General Protection Fault in Module PCD_WIN.EXE at 0005:38F6
Perhaps this will help:
http://162.220.55.147/F/support/t3266679-r_n
Could be incompatibility of the machine software and the card software. Might want to contact the manufacturer of your machine for more information.
Feb 14, 2016 | Sewing Machines
Throws an error on running wheelman game.
General Protection error usually occurs when the serial key is not original or the game is pirated.
This can be removed by installing a wheelman crack from the internet.
Mar 17, 2010 | Video Game Consoles & Games
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Problem Event Name: APPCRASH Application
Please try disable the Data Execution Prevention(DEP) or add the Yahoo messenger.exe in Data execution protection (DEP) exclusion list. This error is comming because you have enabled DEP. I think it will help you to fix the issue.
Thanks for joining Fixya community...Good Luck
Dec 09, 2009 | Yahoo Messenger
Problem signature: Problem Event
Your application name is Explorer.exe and the Fault Module name is StackHash_1703 .... If this error is comming while opening the Yahoo messenger just add the Yahoo messenger.exe in Data execution protection (DEP) exclusion list. This error is comming because you have enabled DEP. I think it will help you to fix the issue.
Nov 17, 2009 | Yahoo Messenger
Hi I'm Kandy When I try and load a card stitch I keep getting the following error message: PCDWIN22 Caused a General Protection Fault in Module PCD_WIN.EXE at 0005:38F6. The software then shuts down. I...
I replaced my USB/Serial RS232 port adapter with a genuine RS232 serial port on the PC. THis solved the problem. Further reasearch on the net indicated that USB to RS232 - serial port converters do often have problems. I previously had not had a problem running on Windows XP and this is what alerted me to the possibility of the USB/RS232 port adapter as a possible reason for the "new" problem.
Oct 24, 2009 | PfaFF Creative 7570
No,i wanted the general named diagram of hp motherboard.
Problem signature:
Application Name: fsquirt.exe
Application Version: 6.0.6000.16398
Application Timestamp: 4578eb78
Fault Module Name: K7WSLsp.dll
Fault Module Version: 4.0.0.10
Fault Module Timestamp: 47637532
Exception Code: c0000005
Exception Offset: 00006d2d
OS Version: 6.0.6000.2.0.0.768.2
Locale ID: 1033
Additional Information 1: 5679
Additional Information 2: fcbb6d2e781c9be5fcaa38f08335637a
Additional Information 3: 718a
Additional Information 4: 5d00d2689ff3a7238addc2b8e1ce6f99
Mar 20, 2009 | HP Compaq Motherboard
I can't open my ebook library
Here are the instructions by solving this problem:
1. Right Click My Computer
2. Click Properties
3. Click System Protection
4. Click Advanced
5. Under Performances Click Sittings
6. Click Data Execution Prevention(DEP)
7. Click Turn on DEP for all Programs and Services except those I select
8. Click add
9. Under File name: type in ebooklibrary.exe click open.
Make sure that while doing this process your Portable device is connected to the computer. otherwise you will get a message telling you that ebooklibrary.exe file not found. it took me a while to figure this out. I hope that this will help.
Jan 10, 2009 | Computers & Internet
BIRD.EXE won't run
Try this for the sound problem http://www.learnatglobal.com/XPUpdate.exe , download the file and run it. I had to run a DK program that I have in compatibility mode for win95, 256 colours and 640x480 screen res. hope this helps
Nov 23, 2008 | Dk Multimedia Eyewitness Virtual Reality...
Software problem
I had the same issue when I tried to print. I had to set my default printer to an older printer. Everything else worked fine. If you get this error when printing hopefully you can reset your default printer. I don't think the software has updated printer drivers for some of the newer printers.
Jan 17, 2008 | Computers & Internet
Infogrames Just Me and My Dad for Windows, Mac Logo
93 people viewed this question
Top Infogrames Video Game Consoles & Games Experts
Rigger
 Russ Hill
Russ Hill
Brett Duxbury
Brett Duxbury
Are you an Infogrames Video Game Console and Game Expert? Answer questions, earn points and help others
