Question about Samsung PCL5415R TV
When I turn on TV I would get a clicking sound and a whinning noise. After the whinning noise would stop I could unplug the TV, plug it back in and get a picture and sound. Now all I get is a clicking sound and nothing, no whinning, no picture, no sound.
  • 10,515 Answers
The whining noise you are hearing is very likely caused by the color wheel motor, and not a fan. Usually a bad fan will make a fluttering, low pitched sound; but the color wheel spins much faster, so it will make a higher pitched sound when it starts to go bad.
If you wish to change this yourself, very good instructions (and a video) can be found at these two links:
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
http://www.youtube.com/watch?v=Cx4pbNjsxfU&feature=related
The instructions are not necessarily exact to your model, but it is basically just screws and a few connectors.
If you wish to have a technician replace this, the labor should be in the $150-200 if you were to take it to a shop. Please add a trip charge if done in the home.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 06, 2010
Cause of whinning noise when trying to start xg350 motor does not turn over. Not a clicking sound but a high pitched whinning sound.
1) Most likely.
Your starter is an electric motor, with a gear on one end.
Mounted on that same end is a part called a "Bendix" or an "overrunning clutch".
When that just mentioned part fails, the starter will not engage the flywheel, and you will get the noise of which you spoke.
2) Less likely.
If your timing belt fails, he engine will turn over at a high rate of speed, but it will not start.
God bless your efforts.
Jan 19, 2018 | Cars & Trucks
When I turn my dvd player on, the volume will lower on its own to almost mute. It is hit or miss weather or not the unit will turn off on its own saying protect. All connections are good. Inside is clean....
When you've got good volume, try unplugging the speakers (only for a very short time) to see if that whining noise is still there or if it's stopped. We're trying to see if the whining is related to the low volume and "protect" or if it's only coincidental.
Try unplugging all the cables (except the power cord). Turn the player on & off several times & see if that whining noise acts the same. Also see if the player goes into "protect". What we're trying to do here is see if it NEVER goes into "protect" with the cables unplugged.
Last... try to get it to start & run without going into "protect", with all the cables unplugged (except power). Plug the cables in, one at a time, and see if plugging one of the cables in forces it into "protect". If so, there's something wrong with that cable or whatever's on the other end of that cable. Unplug it again & restart the player - no "protect"? Wait a little while, plug the cable in. "Protect"? Check the other end of that cable.
If it goes into "protect" with nothing plugged in except the power, then the player is probably a write-off, ready to be replaced (it's not very often that DVD players are worth repairing these days).
Nov 05, 2013 | Samsung HT-Z310T Theater System
I have a 19 inch emerson lcd tv that has no picture and as u plug it in the tv makes a whinning sound but as soon as u unplug it the sound goes away
More than the tv power supply board have problems in this tv,don't know yet.But the whinning sound,the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.First must see how it turn out.
Dec 08, 2010 | Emerson LD195EM8 19 in. LCD TV
Have a 27 in Rca t.v and it will not turn on. I also tried unplugging it, but still the t.v will not come back on how do i change the fuse
FORGET the fuse for the moment. If you unplug the set and plug it in do you hear a high pitched whinning sound?
This model is prone to the High voltage transformer failing and usually the Horz output transistor at the same time.
You hear a buzz if you unplug it and plug it back in?
SD TECH
Jun 24, 2010 | RCA F32650 32" TV
My tv turns off by itself and makes a clicking noise
Most likely it has some bad capacitors in the power supply. Flat--panel sets are VERY hard on capacitors, due to the fact that the "rising heat' from the set "cooks" the caps and they fail VERY early.
Oct 12, 2009 | Samsung HP-T4234 TV
Tv keeps switching on and off and will not stop
unplug tv for 2 minutes and plug it back in. problem should go away. if not, call toshiba.
Jul 22, 2009 | Toshiba 27AF41 27" TV
Picture wont come on, makes noise like it is on, but no go
when u plug the set in does it make a whinning noise or a poping noise. this might be a lamp or a color wheel stalled.
Jun 16, 2009 | Samsung HL-R4667W Rear Projection...
TV will not turn on.
hello..i think you have very big problems inside on you're TV you need a Electronics Technician to see inside the real problem.my tips is located in Power Supply Regulator..Can i know what kind TV Model???thanks
Apr 23, 2009 | Televison & Video
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
No picture
Bad IHVT ( flyback transformer)--need complete service
number off back for part #-----------Let me know...T.
Oct 15, 2007 | GE 46GW947 46" Rear Projection Television
Televison & Video Logo
83 people viewed this question
Jerry Greenberg
Jerry Greenberg
