Question about Sewing Machines
Merrit by Singer 3004 & 3014
Machine will not load bobbin..(slipping?) Best guess. Little black tire that turns post, or the plastic (gear?) that turns tire when engaged..Cost of repair
  • Anonymous Mar 12, 2014
    how to threadle 3014 singer machine
  • Sewing Machines Master
  • 1,388 Answers
I am trying to understand the troubles..
...is it that the bobbin winder will not fully engage to spin and wind to fill a new bobbin ?
Provided the engaging spring for the bobbin winder is in good order, the replacement of the winder rubber is a simple procedure if you have a top cover that is easily removed to gain access...just pop off the old one and replace......a short term quick fix may even be to turn the old one over.
Use the old one as a sample and take to any reputable repair shop, they ought to have a variety of winder rubbers to suit most brands, & a quick phone call may save fuel if you want to be certain.
....if, however, you have a 2 piece moulded case, access is very difficult and not something recommended for the uninitiated......there are numerous concealed screws and plastic clips which break easily, so best to have someone qualified do a full service at the same time if you haven't had one done for a while, then you are sure of a good job and a revitalised machine.
Posted on Jun 15, 2008
How do you get the auto threading and wind in place to work on Singer XL6000 sewing machine
There are several FB and Yahoo groups dedicated to the Quantum XL-1000, XL-5000 and XL-6000 who can help you. It may be that your problem with the autothreading is the autothreader is out of adjustment, but I'm at a loss as to the bobbin winder problem.
Jul 15, 2014 | Singer Quantum XL-6000 Computerized Sewing...
Need instructions for singer merrit 3031
contact singer customer service about a manual and bobbiins
May 20, 2014 | Singer Sewing Machines
The black plastic piece the bobbin fit in is broken.
You may have a timing problem or bent needle. You will need to replace the bobbin basket if it is damaged.
Jan 28, 2014 | Singer 7466 Mechanical Sewing Machine
Singer sewing machine bobbin case keeps moving causing the needle to break.
Is this a front loading bobbin or top? If it is a vertical front loader with the little metal bobbin case, the metal case has to be lined up and snapped firmly into place. You should hear it snap and lock into place.
If it\'s a horizontal or top loading bobbin, and the plastic bobbin "tray" is rotating, then it may not have been nested in properly, before replacing the plate, or may be "jagged" somewhere... If there is a burr on the casing, or as in the case of one machine I worked on, still have a piece of needle stuck in it, the thread will snag on it before it finishes rotating and the rotating motion catches half way and will jerk the case right around and the next stitch will break the new needle.. Those plastic bobbin "trays" are usually easy to find and replace if they have become too burred to use. I have also sanded them smooth again as well though.
To test it, unplug the machine, thread your machine on top, but leave off your bobbin lid and leave out your bobbin, hold the top thread (like when you are about to crank to pull up a bobbin loop) and hand crank toward you, or counter-clockwise one complete rotation. Watch to see if the top thread is caught by the rotation hook and slips all the way around and back over the top of the bobbin tray, or if it snags on it somewhere.... Good luck!
Jan 15, 2014 | Singer Sewing Machines
The motor runs on my Singer Merrit 8734 but the needle doesn't move.
if you have to undo the clutch to wind the bobbin, then try undoing the clutch again & then retightening the clutch & see if that helps & if it doesn't help the machine needs to be checked
Mar 26, 2012 | Singer Merritt 8734
New Problem...I have a Singer CG-550. When I try and sew anything, the needle hits something inside where the bobbin is. The little black casing holing the bobbin keeps moving all over the place, I slip...
On the right of the black bobbin case there are two screws, you can slacken those screws off and move the bobbin case nearer to the guard leaving enough room for the thread to pass through, if the needle is hitting the bottom you may need to retime the machine.
Mar 06, 2010 | Singer Sewing Machines
Bobbin case and threading singer 6423
This machine has a black plastic bobbin case. You drop the bobbin down into the case with the thread coming off in a clockwise direction. If you look close you will see a slot in the bobbin case where there is the metal pieces. The thread will slide into that and as you pull on it it will work its way through and come out on the other end of the metal. Lay the thread over top of the bobbin case and turn the handwheel to pick up the thread. (make sure you close the slide plate)
Feb 07, 2009 | Singer 6423 Sewing Machine
Singer sewing machine Merrit. Needle is hitting something and not going into hole
turn the machine slowly by hand as the needle goes down check it does not hit the foot ,then the hole of the plate.
If it enters the hole and then stops aganst something it is possible the shuttle or bobbin is not in right take them out and replace them again.if the problem prisists take the needle plate off and warch as the needle goes down what it is hitting.
if the hook or shuttle is in the way the timming could be out.
Aug 01, 2008 | Singer 3116 Simple
Bobbin thread getting caught
Check your Instruction manual - if you have taken the bobbin case apart to clean it, the shuttle must be reinserted with the little tab pressing against the piece you mention. It is under page 45 - "Caring for your machine" in my book. I missed it the first time I cleaned and oild mine.
Mar 21, 2008 | Singer 3962 Mechanical Sewing Machine
Sewing Machines Logo
393 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
