Question about Nikon D80 Digital Camera with 18-135mm Lens
Dark Picture I just got my D80 and started taking pictures with it at my nephew's birthday party and noticed that the pictures were dark and the shutter speed is slow but I don't know how to change it! Help!
    Problem Solver:
  • 8 Answers
I am assuming the following two things.
1. The part was indoors.
2. You are using the 18-135 mm lens with the Nikon D80.
The problem with shooting indoors is that not enough light goes in through the lens to the filter. Solutions:
1. Use the flash with every shot. In case there is not flashlight available, use the on board flash. Press the top button behind the barrel on the camera. It has a lighting icon. It will pop open the flash. If you are in 'P', 'A', 'S' mode, the camera will sync the shutter speed with flash. If the camera is on auto mode (The green camera icon) the flash will pop up and fire by itself.
2. Use the lens with with lowest f stop, i.e. with bigger aperture.
3. Increase ISO. You ought to get usable photographs right up to 800. To change ISO, press the button on the back of the camera which says 'ISO' (Second button from bottom) and turn the primary command dial simultaneously to change ISO setting. Higher ISO speed = Lower shutter speed (But less clarity too).
Hope it helps.
Satdeep
Posted on Jun 17, 2008
  • Satdeep Marwaha Jun 17, 2008
    I made a few mistakes in my answer. The corrected version is as under. My apologies for an inconvenience caused.
    1. The party was indoors.
    The problem with shooting indoors is that not enough light goes in through the lens to the sensor.
    Solutions:
    1. Use the flash with every shot. In case there is no flashlight available, use the on board flash. Press the top button behind the barrel on the left side of the camera. The button has a lighting icon. It will pop open the flash. If you are in 'P', 'A', 'S' mode, the camera will sync the shutter speed with flash. If the camera is on auto mode (The green camera icon) the flash will pop up and fire by itself.
    Hope it helps.
    Satdeep
My D80 fell from a foot n half above the ground level well packed in a good quality carry case few days back.uv filter attached to 18-135 Nikor lens cracked & lens cap was jammed. After carefully...
Hi, allow me to suggest using another lens to see if you still see the dark patches in the top corners. If not it is the lens, if so it is the camera. Either way it sounds as though something is maladjusted. Call Nikon digital 1-800-645-6689.
May 14, 2010 | Nikon D80 Digital Camera with 18-135mm...
What should I set the Nikon D80 on to take basketball pictures? when I put it on the lowest aperage I still have a little blurring. On auto it is too dark and when I put it on shutter speed it was also too...
I take it you're shooting indoors?
To get the fastest possible shutter speed, use the Aperture-priority (A) mode and turn the sub-command dial on the front counterclockwise until the numbers stop changing. This sets the lens at its widest aperture.
Even at your lens's widest aperture, the shutter speed will usualy be too slow to freeze the action. You can ease the situation a little by increasing the ISO, though this will result in additional noise. Personally, I'd prefer a noisy picture over a blurry picture.
If the action is close enough, you can use your flash (assuming it's permitted).
Adding lights to the gym is probably out of the question :-(
Other than that, about the only thing you can do is to use a faster lens. But then you're talking $2000 for a stop or two. That's one (or 2000) of the things that separates the _Sports Illustrated_ photographers from the rest of us.
Jan 29, 2010 | Nikon D80 Digital Camera with 18-135mm...
I recently purchased the D80 and had no problems, it worked great and took magnificant shots. However, the other day I turned it on and the viewfinder was now, dark and out of focus. The battery was fully...
Check the mirror. The image you see in the viewfinder comes through the lens, and is reflected by the mirror. If it's dirty, it will affect the image you see. When you take the picture, the mirror lifts up, the viewfinder image is interrupted, and the light from the lens goes to the image sensor. So...if the mirror is dirty, the picture will be fine but the viewfinder image will be dark or out of focus.
Jan 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Dark Viewfinder and Slow Shutter Speed
At first it sounds like a faulty aperture blade that is stuck after your first press. However you mentioned that this happened in other lenses as well. Seems to me that there is a problem with your camera (e.g. mirror lockup problem or something else). Pls have it looked at by Nikon
Aug 13, 2009 | Nikon D80 Digital Camera
I have a Nikon D80 SLR camera, and have purchased an Opteka 650 x 1300 mm zoom lens (fit on). I have changed the setting on the camera to manual, and it will now take photographs, however the images are...
You can't meter through that lens. If the images are too dark, either slow down the shutter speed or open the aperture. Keep going until the picture looks okay on the monitor. If you know how to use the histogram, that's even better. If you go too far and get images too light, reverse the process (faster shutter speed or smaller aperture).
If you have another light meter, you can use that to get a ballpark exposure to start with. Alternatively, take a reading with your other lens at the longest zoom.
Jun 15, 2009 | Nikon SLR D80 Digital SLR Camera Digital...
D80 Nikon - dark in viewfinder
What you see through the viewfinder is not exactly what you get in your picture. It is possible that your settings are just off in the camera. To make sure that this is the problem, set your settings to Auto and try again.
The red light before the picture is taken is a setting you can turn on to indicate that you have focused correctly. You can turn this off in the menu if this bothers you.
Lastly, I do not think your camera is broken. You just need to read your manual to make sure your settings are correct when you take a picture. Hope this helps.
NOTE: Please rate our help to keep this free service online
May 08, 2009 | Nikon D80 Digital Camera with 18-200mm...
Dark photos
  • Be sure camera is set to the Green auto, not the A (A= aperture priority)
  • Be sure your white balance is on auto.
  • Be sure your EV is set to 0
  • Be sure your lens is on M/A, not M
  • Check the internal meter. See if it is showing a middle of the graph reading when the camera is on auto. If it is and you still get dark pix, might be time for Nikon repair.
Mar 12, 2009 | Nikon D80 Digital Camera
I was at a basketball game last night and taking pictures with the d80 and the 55-200 lens. All of the pictures I took in auto focus were blurry. I changed it to the S mode with shutter speed at 4000 and...
Hi and welcome to FixYa.
I could go into a long disertation about your camera settings and what you should use, but I should let Ken explain it. I read this a couple of months ago (because I love photography too)! He has some good ideas, tips, tricks and really has the D80 dialed in. You can read it here.
http://www.kenrockwell.com/nikon/d80/users-guide/d80-users-guide.pdf
Good luck and have fun with your camera.
Rob
Feb 28, 2009 | Nikon D80 Digital Camera with 18-135mm...
Dark Picture
Symptom: NO PICTURE
Cause: DEFECTIVE 3D/YC COMB FILTER
Symptom: DARK PICTURE
Cause: DEFECTIVE C724
Jan 16, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Stopped taking pictures . . .
When previous pictures display fine but does not take new one directs the problem to camera mode problem. Some component is at fault in the main board which controls menu functions and display is damaged. For the solution, the main board is repaired or replaced by technician. The repair cost may run between $100 to $200 in US.
Mar 21, 2007 | Nikon Coolpix 5600 Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
163 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
