An engineer claims to have observed five separate phases in a ternary alloy at the same time. Is the observation accurate? explain
He can not observr five phases at the same time.
Posted on Nov 07, 2010
What does hypothesis mean
A hypothesis is a proposed theory that could explain a set of observations or circumstances. It usually requires experiments to test it before it becomes an accepted theory. Testing often takes the form of "the hypothesis explains all of the observations, but if it is true, then it suggests one should observe x when y happens.
Aug 25, 2014 | Computers & Internet
Comm error 442
From the HP website:
420 V.34 negotiations have failed from the originating machine during phase 4. Phase 4 occurs after V.8 and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Solution:
Reattempt the fax reception at a different time when telephone line conditions have improved. 421 V.34 negotiations have failed from the originating machine during phase 3. Phase 3 occurs after V.8, before phase4, and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Solution:
Reattempt the fax reception at a different time when telephone line conditions have improved. 422 V.34 negotiations have failed from the answering machine during phase 4. Phase 4 occurs after V.8 and before the first T.30 frames are exchanged.
Solution:
1. Reattempt the fax reception at a different time when telephone line conditions have improved.
Solution: Reattempt the fax reception at a different time when telephone line conditions have improved.
Solution: 1. Reattempt the fax reception at a different time when telephone line conditions have improved.
Jul 25, 2011 | HP LaserJet 3050 All-In-One Printer
Yahoo messenger does not show recent messeges
The Bike Technicians Tactic
Phase1
An electrical inspection on the bike should produce results. First, the bike battery powers the entire lightening systems mentionable as ignition, meter readings, head lamps, signal indicators. However, the battery provides the power supply to several entities though also significant is the fuse box containing circuit protection coils. Inserting the bike key into the ignition to perform start mode displays the capacity power circuits. A charged battery should display an indication in the meter reading area also known as bike dashboard grading. A malfunctioning start mode on inserting key in ignition may be traceable several locations on the electrical circuits. Attempting to repair the electrical power of the bike usually requires batter power power test kit. The test kit ascertains the battery power making possible progress to the remaining electrical circuits. Test kit also ascertains the fuse box circuit functionality either with fuses still intact or extracted allowing for the next progress level. An observation tour of the bikes electrical wiring kits from battery hold through fuse box compartments to each lightening display area either headlamps, indicators, and meter reading should produce results of any visible damages that may require repairs after the electrical inspection has been performed. Once any faults were observed on the electrical channels, repair mode is the next level. A dull battery either may have been depleted completely of durational capacity requiring another for replacement. Alternately, a depleted power supply due to prolonged storage may require charge functionalities. Usually, a device capacapble of restoring a battery of electrolytes is resorted for charger ability. The type of battery may require constuents either liquid cathode replenishment in the battery entrapment area prior to charging feature is assumed with electrolyte machine. Once the battery has regained full functionality makes way the next repair task. The fuse box may have simply required replacement fuses either as missing or burnt out. A fuse box usually contains additional spare for replacement functionalities. An alternate arrangement at acquiring fuses on the auto mart may replace the burnt devices. The next electrical task is wiring fixtures achievable by mending broken cords with appropriate electrician's tapes else malfunctions may remain. Alternately, a worn-out electrical wire is replaceable by acquiring the entire extension lengthwise between significant areas. The last remaining electrical units are lightening indicators consisting of bulbs or luminescent displays reflectors. Observe the blub areas either by loosening covers to inspect for observable burnouts else the entire electrical circuitry is ready for functionality observations with separate entities.
Engine Technicians Tactic
PHASE 2
A bike engine inspection includes observation for indications of malfunction. Any fluid residue is indication of problem areas. Where oil leaks usually requires engine block inspections. A bike engine consists of an entrapment compartment where mechanical combustion takes place. First, the entire observable block consists of an external coating known as engine bloc housing internal component of pistons, rings, and fastens known as cylinder heads. A bike engine has every component embedded within requiring technical expertise to achieve an inspection. Once deciding on the engine task requirements, acquire a tool box with the appropriate componements as first requirement before engine works is commence able. Second, the bike may require an area environment as workshop requirement to attain engine inspections. Third, bike engine are least bulky compared with vehicle engines however assistance would complement the inspection phase. Prior to inspecting the bike engine, a strap mechanism has to be assumed to achieve expert maneuverability also as safe precaution. Unless parts hinder maneuverability at engine locations, the only removable components should be the engine. First, start with disjointing the spark plug cables to acquire accessibility to plugs imbedded on the cylinder heads. The plugs require tools to loosen thereby exposing the combustible area. Once the spark plugs are exposed, two alternatives are likely. First, a spark plug may have gathered rust residue only requiring cleaning to attain regular capacity. The pin area of the spark plug may have been twisted due to overheating and slight melting dislocation. Usually cleaning the residue from old plugs may simply expose the ignitable capacities. However, an observation of twisted plug pin may require twisting back in place to achieve full ignitability once bike engine starts. A bike engine bloc has the pistons as combustibles or blasters of fuel gasoline. The rings perform as strap fasteners whenever the pistons move about combustibility. Usually, the engine entrapment components would have collected residue requiring clearing. Also, pistons together with rings may require replacements either as worn-out due to prolongs tasks or overexerted biker features.
Feb 24, 2011 | Yahoo Messenger
No spark at all
Phase1
PHASE 2
Feb 24, 2011 | 2000 Yamaha YZF-R1
It starts out on 20 mph. so i guess i am wondering if it was installed corectly or is it a sensor problem?
First the vehicle at regular functionality should have an odometer readings least on the zero indication. Several factors causes the reading to least lay on zero on the functioning vehicle. Observe that the vehicle odometer gradings are least entirelly on zero. Once the engine were turned causes an impression where engine temperature considering the fluid compositions makes the odometer hyperactive. First power on the vehicle depending on the vigorisity with which either as acceleration over impression produces a response at the odometeric readings as visible display of action taking place within mechanical or electrcal functions. Odometer reading malfunctions would least produce the observable action taking place also noticeble to the operator of vehicle. For example an odometer malfunction where any readings were noticed or readings that over impress are mentionable. vehicle odometers least malfunction with observation as hyper active. Odometers on vehicles that have been overexhuated either with durational drives attains an over active phase. The mentionable reasons include that fliuds either as engine olds have been heated to capacity least as responsive. Unless that vehicle retained a cooling phase where meter readings apear least over impressed. Also, ascertain the engine cooling components comprising of fluids that cuases over impression once depleted as indication. Refer to an auto technician to ascertain the condition either as malfunctioning components that requires restorations.
Feb 20, 2011 | Computers & Internet
Is it possible repair my mruti 800 by my own. becoz i am not happy with the service centres. just they are looting money inretrn they are doing nothing. i want service my car by my own. can u help me
PHASE 1
GETTING FAMILIAR WITH VEHICLE SPEAKERS
The car speakers are located within the vehicle. An observation of the passenger side doors should make accessibility to speakers. The remainng speakers would be locatable at the rear area of a sedan car closest to the wind shield area. The category of the vehicle may determine the positioning of speakers within interior either different with sedans, SUVs or single cabin trucks. However, tuning on the vehicle stereo should ascertain the location areas of sound speakers within the vehicle. The speakers may total four for most dual cabin vehicles, or two speakers for single cabin pickup trucks. Unless the vehicle original speakers were malfunctioning alternate procedures are least required. For example, a damaged speaker may require changing for an alternate acquirable at retail. However, speakers are sold in pairs to achieve coordination of sound requiring for the technician to request for purchase parts in pairs.
PHASE 2
GETTING FAMILIAR WITH SPEAKER TECHNICAL REQUIREMENTS
The stereo speakers have an entrapment space at each area within the vehicle next to passenger's doors. Acquiring accessibility to the speaker coil requires unfastening the plastic covers or interior insulation. Once unfastening cover, the speaker is exposed requiring unfastening also to dismantle from docking station within the door lodging. The speaker comes loose making possible observation for repairs or replacement parts. The area a vehicle speaker is situated may require an alternate arrangement to achieve accessibility. For example, a sedan car rear speaker is accessible at the luggage truck. Single cabin trucks may have stereo speakers at dashboard corners next to the windshield and air space window spaces at doors. An observation of the speaker area within the vehicle should acquire the tools, and compartments that have to be unfastened before speaker come loose.
PHASE 3
ACQUIRING PARTS FOR STEREO REPAIRS
Damage in the stereo setup may require replacement parts. Ascertain the damage from the vehicle prior to acquiring parts. For example, a malfunctioning stereo is physically observed as damaged or least capable of achieving operationally. The stereo speaker's least producing audio sound with proper functioning of the stereo is indication of damage. Once the vehicle damages are ascertained, several additional parts compliment the restoration process. Acquiring a new stereo player would require harnesses, wiring kits, and fasteners also acquirable. A damaged speaker requires dual speakers as replacement to attain sound distribution within vehicle and also as compatibility requirements. Once vehicle parts are acquired for restoration functionalities, tools capable of complimenting the process is required also.
PHASE 4
GATHERING TOOLS
The restoration of damages on the vehicle requires tools to achieve success. However tools have various purposes requiring keen observation of the type of components involved to assemble a tool kit to the task. Observing the broken components would provide details of kinds usually as fastening, unfastening or mending, gripping proposes. Car stereo repairs involve electrical circuits requiring tool separate than the mechanical tools for loosening screws or compartments.
PHASE 5
PERFORMING THE REPLACEMENT
The vehicle requires workshop environments to achieve successful technical restorations. Unless any technical malfunctions were observed complementary to the stereo system speaker repairs, the procedures involve removing and replacing component parts to attain regular functionality. Usually, the process of restoring damaged components requires caution to attain success without compromising the integrity of delicate components.
Jan 23, 2011 | Car Audio & Video
Got spark and batery they seem fine
Phase1
PHASE 2
Jan 21, 2011 | 1997 Suzuki TL 1000 S
Non accurate time keeping on Magellan 1215. How
go to the system settings and change your time zone to your region and also make sure you check off daylight saving time box if you observe it in your location.
Aug 29, 2009 | Magellan GPS
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
