Nokia N95 Cellular Phone
Problem for Nokia N95 Cellular Phone
NOKIA N95 MEMORY CARD
By Ahfan on Jun 15, 2008
Everytime i turn my phone off and back on again, or if i take out the memory card and reinsert i get a bar saying installing, and it slows eveything down on my phone. How can i get rid of it. Im sure it has something to do with the memory card as it tells me that some application that it is trying to install cannot complete.....
Please help me get rid of this... its so annoying
Comments:
Jun 16, 2008
- Formatting the phone doesnt help me at all. I had another issue with the phone. And i was asked to format. It was only after the formatting that i encountered this problem with the installing message. Formatting will not do it
Same Problem
Feb 05, 2009
-   no, it's some piece of software that does not install properly .. do you have garmin mobile xt? .. I think this is the soft that causes the issue -   Guest
Jun 30, 2008
-   i got the same problem i updated my phone from v15 to v20 and turned it on picked uk did time and date then it loads and tries to install all my apps again but some fail it dose this every time i turn on phone :( i formatted my phone same thing happens i got the 8gb model -   rubber131186
Best Solution
posted on Aug 01, 2008
Very Helpful)
rubber131186
Rank: Apprentice
Rating: 100%, 1 votes
did a phone format and memory card format it solved it
Was this helpful?
Yes
No
Solution #2
posted on Jun 15, 2008
Not Helpful)
Bajanguru
Rank: Wiz  Nokia Expert
Rating: 82%, 3868 votes
you should try and reformat the phone
switch off the phone....now press and hold 3,* and the green button on the phone , do not let them go , switch the phone on while still holding the buttons.....then phone should now start to refomat itself and correct any errors you had.
Was this helpful?
Yes
No
Solution #3
posted on Feb 05, 2009
Somewhat Helpful)
spunkymonkey
Rank: Master
Rating: 86%, 5 votes
if you have installed an application onto the memory card and have done a factory reset or SW updated on your fone the fone no longer has the application in the menu but it recognizes something should be there.
Instead of formatting the mem card all you need to do is go to the "Application Manager"(Ap.mgr), usually in tools, and delete the application from there or re install your application.
When you insert the mem card into the fone it will read it. the same way as a PC reads a CD or memory stick, so it is normal for you to get the bar running along the bottom. The larger the memory and the fuller it is the longer it will take.
Was this helpful?
Yes
No
Solution #4
posted on Oct 10, 2008
Somewhat Helpful)
skasey
Rank: Apprentice
Rating: 75%, 1 votes
Fyi - The easiest way to format the memory card is to plug a usb cable into the phone and select 'data transfer' mode. After this, the card will be visible on the pc and can be formatted in the same way as any usb disk.
Was this helpful?
Yes
No
Solution #5
posted on Sep 30, 2008
Somewhat Helpful)
brianhopkin
Rank: Apprentice
seems like your memory card is corrupted. this site is about nokia n95 help
Was this helpful?
Yes
No
Popular Solutions for Nokia N95 Cellular Phone
Questions and Unsolved Problems for Nokia N95 Cellular Phone
Do you recommend Nokia N95 Cellular Phone?
Answer
Answer
i need a regiticted code for samsung gt-s5230
Answer
When I slide my phone, the screen fades out and now it's all black. what could be the cause of it... (More)
Answer
screen blank after fitting orange sim card
Answer
my mobile in not displying anything in the screen
Describe your Cellular Phones problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Cellular Phone Experts
Top Cell Phone Repairmen
in Surprise, AZ
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
