Disk drive has stopped working. eithre using battery power or plugged into house 110 volts with Memorex cord
  • 11,800 Answers
Unfortunately disk drives can't be fixed. If you don't get any sign of life out of it then nothing more can be done, it's truly dead and all the data is lost. You will have to replace it.
Posted on Nov 06, 2010
Dc011 radio works with battery but wont work when plugged in what could it be
Sounds like the mains transformer has gone. That is what reduces the mains outlet power of 110 volt to that of the batteries.
You could check the power cord though for 110 volts at the end.
Oct 31, 2015 | Dewalt DC011 AM/FM Radio
Looking for manual or information my 1988 TravelAire Camper van. It is on a Ford e-250 chassis. Need to know how the 120 Volt system works; i.e. does it operate all lights (including 12 volt); does it...
Typically, the 110 Volt will go into a power center which should include a small amp battery recharger. Your 12 volt lights should run off a 'house' battery which should be isolated from the truck battery, yet, the truck alternator should charge the "house" battery on the road. The device that allows this is called a Isolator. You may find a manual switch instead. You definitely don't want the house and truck battery to both run yourf coach with no recharge capability. Some systems have a 'emergency start" switch which allows you to use the house battery to start the engine. All 12 volt house stuff should run off the house battery and the battery should be recharged by the truck or the small battery charger. Do you have an evap frig? Runs on propane or electricity? It needs 12 volts whether it is running on gas or 110 Volts. The 12 volts runs the control panel and the heat to make it work is supplied by the gas or by a electric calrod if 110 is available.
I am pretty familiar with these electrical systems ... I seriously doubt you will find any information on your 20+ year old motor home. Typically, the printed specs and equipment and the data is obsolete before the ink is dry because the manufacturers use what is available as they build. If you have additional questions simply click on the "add comment" or the "reply" link and I will take a look-see.
I hope this answers your current question. Thanks for your interest in FixYa.com
Sep 07, 2011 | Ford E-250 Cars & Trucks
Have companion 5250 generator which produces about one volt in each of the 120 volt outputs..........check in the back of generator..........looks like a capacitor is missing..........is this it and and...
The cap is a 35uf 370 vac, and the generator will not work without it. While you have it opened up, check out the diode, too. After it's been put back together, if it still doesn't put out, you may need to "flash" it. To do this take a 110 volt plug and cord, and plug it into one of the outlets on the generator. Start the generator engine and then *VERY BRIEFLY* touch the leads of the plugged-in 110 cord to the + and - terminals of a 12v battery. You should now have power available, so be very careful with the ends of the 110 volt cord as they are now "hot".
Sep 05, 2011 | Garden
I have a bathroom Broan 504/505 vent fan. This model just stopped working. I have power to the unit but for some reason it wont work. I pulled the fan plug from the fan housing & used an extension...
the motor is prob rated for 120-140 volts if your only getting 110 there is the problem see what the breaker is putting out at the box the light will still work but the motor needs enough amps to start sounds like a voltage drop issue
Aug 06, 2011 | Heating & Cooling
Whirlpool electric range super capacity 465 RF 377PXGQ0 SER# RH 4718582 the stove burners work nothing else works the control panel and oven are not working at all no lights at all... everything...
Ok
you must have a problem with you neutral leg .
Check to mak sure all 3 wires from power cord are securely connected to machine. Next make sure recepticle at the wall
has a good neutral. Use volt meter to check your recepticle.
You should get 110 volts between any top and the bottom slot.
No 110 volts means check house wiring or recepticle
Yes 110 volts means problem with neutral wiring in machine.(Not likely)
good luck
Jul 26, 2011 | Ovens
We have a proline above ground pool pump. Model PE71 III V. Been working fine the last two weeks. We vaccumed pool and then pump just stopped working. We don't hear any noise....like there is no...
at home depot the sell a pen that beeps at the sight of voltage (sensor) 12$ good house hold tool to have.. check the cord running to pump see if the pen beeps when held against cord if its a 110 set up the pen beeps and youve the 110 V needed to run the pump if 220 V a bit different .. if left powered But not running in a few min, touch motor housing the metal part of this unit. is it hot as a grill (internal winding problem) or still cool .. Motors are a wear item like tires on ones car.. motors are inexp like 110$ for a 1 hp unit
Jun 04, 2011 | Hayward 3/4hp Super Pump Inground Pool...
My GE DPSB620ECWW does not light up the pannel or
Check circuit breaker at the house electric panel, if good, check for voltage (220/240)volts at the receptacle that the dryer power cord plugs into, if good, check for voltage(220/240)volts at the dryer terminal block where the dryer power cord connects to the dryer, if good, check voltages at the dryer power transformer, should be 220/240 volts for motor,and 110/115 volts control power for dryer controls, you should find the failure within these inspections/testing.
Good Luck !
Mar 15, 2010 | GE Profile DPSB620ECWW Electric Dryer
Put lens cleaner in my memorex mvd2016 and it still says "wrong disk"
Had the same thing. Tried opening and closing a number of times- powered on and off a few times- used a lens cleaner- nothing.
Unplugged the power cord from the wall, plugged it back in- BINGO- it works. For now.
Aug 14, 2009 | Memorex MVD2040 DVD Player
Sylvania GNET28001SO Meso 8.9" Netbook PC (1.6 GHz Intel Atom
If you are attempting to connect your laptop between 110 and 220 volt power outlets, you may be able to do so already, take a look at your power cord's transformer (brick) and read the input voltage. If you only can use 110 volt AC Input Voltage should read 115VAC. If you can do both, then it should read 110-225VAC.
If your power brick supports 220, then all you will likely need is a plug adaptor, found at many electronics store. If not, you wil need to stop in at a computer store or an import store and get an international transformer, which are set up to convert many different country plugs and many common voltages.
Good Luck!
May 06, 2009 | Sylvania Meso GNET28001SO Notebook
Lost power Cord to T.V., All I have is a monitor. Need plugs
Try ordering a replacement from memorex through there web site, or any major electronics store might have a universal cord that could work with your tv. Be prepared to pay , alot. $80 -$120 . I had to replace my power cord for my panasonic lcd tv. cost was $110
Apr 12, 2009 | Memorex MT1701 17 in. HD-Ready LCD...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
