Roland plotter cx24 is not starting. display shows origin error. no any movements in plotter.
3 Suggested Answers
  • 53 Answers
SOURCE: hp plotter 500ps problem by
Have you solved this problem, as I post it's 3 months old. This is a serios problem and refers to paper axis shut down.
Posted on Aug 30, 2011
hoyle_jeremy
  • 219 Answers
SOURCE: My ROLAND cx24 vinyl plotter does not start
Do a hard reboot
Posted on Jun 20, 2014
My Roland Camm1 cx24 not powwering up
I would first make sure everything is plugged up correctly.
If this doesn't work I would look into the power supply inside the computer and having it replaced. other than that I'm not sure how to help.
If you have any other questions or info feel free to respond and ill see if i can help
Jun 19, 2014 | Computers & Internet
Hardware error
hello, can you specify what error number is?...i have a service manual for this ipf710 plotter and i can tell u what is wrong with it or you can download the service manual from the below link:
http://goo.gl/daFE3c
good luck
Sep 11, 2013 | Canon imagePROGRAF IPF710 Printer
Hp plotter T1200 ps gives error 22.1:10
Problem with "Ink Supply Station" P/NoQ6683-60188. Replace it..
If you are tech guy follow the suggestion:
Error reason: ISS divided in to two units, each unit will maintain that pressure to pump ink to print heads. The part called "rocker" push the elestomer bongo(black rubberized material) to pump ink. This rocker movement sensed by the respective sensors to calculate timely movement. If these sensors malfunction or variations in rocker movement causes error..
Remove/take out Ink supply station, two units of right & left, right unit not working properly, clean sensors & lubricate the drive shaft.. Follow the pics..,
Note: Technically if you are not sound don't do this activity..
2_16_2013_7_45_21_pm.jpg2_16_2013_7_45_46_pm.jpg2_16_2013_7_46_05_pm.jpg2_16_2013_7_46_30_pm.jpg2_16_2013_7_46_54_pm.jpg
Feb 16, 2013 | HP Designjet T1200 Large Format Color...
Analog test eror onroland td5
I have the same problem with my module and I can\'t find the solution anyware for the thing.Closest solution that I could find is something about Roland power adapter.Apparently module won\'t work with any adapter with the same voltage,only Roland or Boss B.R.A. adapters works.I have original Roland adapter and still shows an Analog test error.
Have you find the solution in meantime by any chance?
Sep 09, 2012 | Roland Music
86:01 error in designjet 500 plus Paper jam...
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
Corrective Action:
If this error code appeared but was NOT caused by a paper jam, then try the following:
  • Too much friction in the Slider Rod. Enter the Printer Information utility and check the Scan-Axis usage. If the percentage is close to 100%, then lubricate the Slider Rod.
  • The Carriage is bumping into the Service Station. If the carriage is stuck at the right hand side of the Printer and cannot be moved out to the center of the Print Platen it is because the Service Station cannot uncap the Printheads. In this case replace the Service Station/Aerosol Fan Assembly
  • Perform the Carriage Movement test
Aug 26, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
Hi hp designjet t1100ps plotter showing error code 86:01, paper jam. but physically there is no paper or obstacle in print area. carriage block also moving one time right to left then the error code is...
This error can be caused if there is anything blocking the movement of the carriage. I just had a client with this problem on Tuesday and it turned out that they had opened the print head cover and had not closed it properly. This caused the metal latch to block the movement of the carriage. I would check that first, as well as look for any small bits of paper that may be blocking the complete movement of the carriage.
Apr 01, 2011 | HP Designjet T1100ps Printer
Hi, we have a roland camm-1 cutter plotter. It has been showing "fan error" on the display these last few days but would correct itself when turned off and on again. Now though,when I put vinyl in and send...
I had a similar problem. The issue was that I would receive a "fan error" notice but the fan was still spinning when the error displayed and then the machine would stop. I took plotter to my garage, removed the covers and used my air compressor to blow out the dust from the fan and the circuit boards. When I blew out the fan, a ton of dust and "dots" from the punched material came flying out. After a thorough cleaning, I put it back together and have not had the problem since - it works like new. I think what happens is that the fan becomes clogged with dust and dots and slows the fan enough to send an error signal to the plotter. No dust, no dots, no error! Try that - hope it works for you!
Sep 16, 2010 | Computers & Internet
Roland SPD 20 shows analog test error at power on.
I am having the same issue with a SPD-11 that ahd brought from Japan. Please let me know if you get a resolution for your issue.
Dec 25, 2009 | Yamaha RX-V659 Receiver
66 people viewed this question
k24674
