Question about Graff G-7070-LM27S Tango Series Pressure Balance Contemporary Trim Plate
Where can I buy a replacement cartridge for a Graff single lever shower control # JLO2BJ Im in NJ in the Summit area
dragonsthatk
  • 547 Answers
SOURCE: single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Posted on Feb 23, 2009
jj505
  • 195 Answers
SOURCE: kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Posted on Mar 16, 2009
peterrance19
  • 399 Answers
SOURCE: where do i get repair parts for graff shower valve
hi spare parts are on line at www.shopping.com/xdn plumbing supplies hope this helps
Posted on Dec 03, 2009
odiebugs
  • 949 Answers
SOURCE: how to adjust anti scald valve on american standard shower faucet
Remove the handle,and all the trim rings,and the cartridge cover. take a flat head screwdriver and use it to lift
up the red ring behind everything, this is the hot limit safety stop,
this just stops the handle from turning to full hot.
Once you have the red ring lifted up, notice the numbers and the pointer
on the ring, numbers are on the fixture,
O= hottest 7=cold
See what the ring pointer is set to now, and move it half, before you put this back together, just set the handle on the unit and run the water to see if its to hot or not enough. Once you have found what is the best setting, then replace all covers and trim, handle.
Posted on Feb 10, 2010
Testimonial: "Thanks for the info! It turns out that our faucet was so old it had black plastic piece that had to be popped out and re-positioned!"
kitchen92067
They can be found easily at amazon, click here: Amazon com graff shower parts and take a look. Have a nice day.
Thom
Posted on Jan 07, 2015
Shower faucet
Hopefully you had the correct type of cartridge for your faucet.
I would suggest watching this YouTube video to make sure the cartridge was inserted and fixed correctly. The travel of the cartridge may not be aligned correctly. Hard to think of anything else that could still cause the drip.
How to repair replace leaky moen cartridge on single lever tub shower...
Aug 17, 2014 | Moen Home
Why no water thru delta single lever kitchen faucet
can be a number of issues: clogged aerator, water supply is turned off, or supply lines are kinked, debris behind cartridge blocking flow, rubber seats out of place.... What has changed to cause problems?
Mar 25, 2013 | Delta & Single Handle Shower Faucet
I installed a single lever b114900 fauset i turn the water on and the water come out of shower head and fauset
I woke up to this problem this morning and was told by delta it could either be the cartridge or the check valves assembly. For me it was the check valves. The plastic developed a small crack. Very simple process to replace the parts.
Dec 04, 2012 | Delta & Single Handle Shower Faucet
How to adjust temp control for sigle lever shower control
Temp control is only accomplished by moving handle to desired position. If your asking is the hardware that in behind the single lever going to allow for adjustments, then the answer is NO. I installed the same into one of my bathrooms several years ago and I know what I am talking about. The single handle on that type on mine starts off then cold to hot. Problem is I wait for hot water to max so I can adjust it down to a comfortable temperture to prevent being burned. I refuse to buy one for other tubs. The 2 handles make temperture much easier with less wasted water used until its hot. Remember if you decide to replace with a two lever model then you will have to replumb the pipes for a two handle hardware unit (thats the stuff behind wall that your single handle goes into to which is currently plumbed for a single handle hardware unit.)
Oct 06, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Moen monticello shower control, remove handle
If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Where do i get repair parts for graff shower valve
Thom
Dec 01, 2009 | Graff G-7070-LM27S Tango Series Pressure...
Replaced the cartridge on a moen shower single .. moves easily now.. however the little valve on the shower faucet (for the tub water) does not go down automatically after the shower is turn off.. have to...
the little valve is your diverter control,sorry do not have a part # for you but it is easy to replace.i have seen them at lowe's /home depot . and if you still have hard ware store's in your area they should be able to help.
Nov 02, 2009 | Moen & Replacement Cartridge
Moen kitchen faucet. I changed the cartridge but
Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
Graff G-7070-LM27S Tango Series Pressure Balance Contemporary Trim Plate Logo
526 people viewed this question
Top Graff Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Graff Plumbing Expert? Answer questions, earn points and help others
