Question about GE JBP24 QuickClean Electric Kitchen Range
HOW TO CALIBRATE THE OVEN ON A GE STOVE MODEL # JCBP24WOK1WW? IT CURRENTLY OPERATES ABOUT 25 DEGREES LOWER THAN THE SETTING. THANK YOU. STU
fridgetech
  • 473 Answers
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Posted on Oct 22, 2007
SOURCE: Oven Temperture adjustment
On my Epicure, you are supposed to press the bake selector pad then press the + button to set the temperature to 500 degrees or higher.  Then hold the bake button for 5 seconds.  The temp display is replaced by 00.  Release the bake pad and use the - or+ buttons to adjust the temperature in 5 degree increments.  When finished push cancel (or just do nothing).  Good luck.  I tried this and my oven kind of went haywire.  It decreased the temp by much more than the 10 degrees I had set it too.  May be something else wrong with my oven though?
Posted on Dec 20, 2007
  • 15 Answers
SOURCE: GE Profile Gas Range, serial at235522p, model JGBP79WEW1WW
If this is a newer range, the instructions to recalibrate should be in the manual that came with the stove
Posted on Oct 07, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Oven MODEL J KP27WOP2 WG - WILL NOT HOLD TEMP
You can re-calibrate the oven as follows;
press BAKE pad.
select temp of 500 degress or more.
immediately PRESS and HOLD the BAKE pad until "00" appears.
Then press the + or _ pad to adjust temp up or down 5 degrees at a time.
When fimished press the Clear/Off pad.
Posted on Mar 15, 2009
  • 61 Answers
SOURCE: oven tempature is 10 to 15 degrees lower than set
all ovens very sometimes 10-25 degrees +/- depending on the brand..nothing you can, do set the temp a little higher if you know its off.
Posted on Jan 21, 2010
General Electric oven how to reset thermostat
First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
Aug 08, 2014 | GE Profile JTP18 Electric Single Oven
How Do I Calibrate An Old Maytag Oven
If the knob is consistently 25 degrees off from the indicated temperature the simplest and cheapest fix is to make a new indicator mark on the stove 25 degrees from the original.or some knobs have a glued on ring with the temperature numbers on them . Removing the ring and regluing it at the correct position could also work. Hope this helps.
Dec 31, 2013 | Ovens
Oven is off 100 degrees. How to calibrate it?
To Adjust the Thermostat
Pull the OVEN TEMP knob off the shaft. look at the back of the knob and note the current setting before making any adjustment. The knob is factory set wit the knob directly under the pointer.
1. Pull of the OVEN TEMP knob
2. Loosen both screws on back of the knob
3. Adjust lower screw so it moves in the desired direction. You will hear and feel the notches as you turn the knob. Each notch changes the temperature about 10 degrees F.
4. Tighten the screws.
5. Return the OVEN TEMP knob to the oven.
Re-check oven performance and make the necessary adjustments accordingly.
Feb 12, 2011 | GE Spacemaker JMS08 Electric Kitchen Range
Whirlpool range 465 model # sf369lemo oven temperature
no stove holds a true temp they all fluctuate temperature depending on how well it is insulated.
Feb 06, 2010 | Kitchen Ranges
Oven tempature is 10 to 15 degrees lower than set temp.Can this be adjusted? This is a electric oven. GE Profile Model VZ295971J.
Jan 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE Profile Spectra oven is taking approximately 10-15 minutes to preheat to 350 degrees and does not seem to fully bake food as per instructions. It takes an extra 5 to 20 minutes to bake anything. ...
18 mins from room temp to 350 is factory standard,
you may need to calibrate the range, most now adays come factory set at -25 degrees for safety
depending on your model number in your instruction manuel should be a part about recalibrating it sounds like your about 25 degrees off
Oct 02, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
press BAKE pad.
Mar 15, 2009 | GE JTP15 Electric Single Oven
Sep 27, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Mabe oven thermostat and stove flame adjustments
hi If the oven doesn't heat evenly or doesn't heat at all, the oven thermostat may be malfunctioning. First, determine how much the temperature in the oven is off from the control setting. To do this, put an oven thermometer on a center rack inside the oven and turn the oven on for about 20 minutes, with the thermostat set at any range between 300 degrees and 400 degrees Farenheit. If the oven thermometer reads 25 degrees or more lower or higher than the oven control setting, the thermostat should be recalibrated. Here's how to calibrate the thermostat:
Step 1: Pull off the thermostat knob on the control panel. Behind the knob are two screws holding a round, notched plate. Loosen these screws, but do not remove them.
Step 2: With a screwdriver, change the notch setting on the notched plate by turning the plate counterclockwise; for every eighth of a turn, the oven temperature goes up about 25 degrees Farenheit. To turn the heat down, turn the plate clockwise.
Some thermostats can be adjusted by turning a screw inside the control knob shaft housing. To do so, remove the knob and insert a screwdriver into the shaft so that the screwdriver blade engages a screw slot. Turn the screwdriver counterclockwise about one-eighth of a turn to raise the heat about
25 degrees Farenheit. Here's how to test a malfunctioning thermostat:
Step 1: Test the thermostat with a VOM (multimeter) set to the RX1 scale. The thermostat is located directly on the back of the control knob that regulates the heat. To gain access to the thermostat, remove the back service panel to the control panel.
Step 2: Disconnect one electrical lead wire from a terminal of the thermostat and clip one probe of the VOM to each thermostat terminal. If the thermostat is in working order, the meter will register zero. If the needle jumps to a higher reading, the thermostat is faulty and should be replaced.
Step 3: If necessary, replace the thermostat with a new one of the same type.
If you need to replace the thermostat, follow these guidlines:
Step 1: Disconnect the terminal wires to the thermostat and pull off the control knob.
Step 2: Remove the retaining screws. On some ranges, there is a wire running from the thermostat into the oven. This wire operates a sensing bulb that controls the thermostat. The sensing bulb is usually held by a bracket; unscrew this bracket to remove the bulb. Then carefully slip out the wire, the bulb, and the thermostat.
Step 3: To check an operating thermostat, first make absolutely certain that the power to the dryer has been turned off and the dryer is cool. Then disconnect the leads to one side of the thermostat. Test an operating thermostat with a VOM set to the RX1 scale; clip one probe to each terminal of the thermostat. Disconnect the leads to one side of the thermostat so that the meter won't give a false reading. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
Sep 13, 2008 | Kitchen Ranges
GE JBP24 QuickClean Electric Kitchen Range Logo
82 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
