Question about Samsung DVD-R130 DVD Recorder
Drive will not open. it says "open" when the
REPLACE CAPACITERS PPCF8 AND PPCD1
Posted on Feb 28, 2011
DVD player makes grinding sound and doors don't open
You may have a stuck DVD in the player. Most DVD players have a small pin type hole in the front where you can inser a paper clip to manually open the tray. Otherwise, you have to remove the cover of the drive to actually see what is happening. support hp com Maybe this link will be of some assistance.
Mar 01, 2015 | Televison & Video
How do i open disc drive door
If the door's button (faceplate's button) is not working, then you can use a paper clip. There is a small hole somewhere on the faceplate, and you can insert the paper clip in the hole. Push the paper clip. Actually there is a small button in the hole, and if you push it, the faceplate will be opened.
Feb 21, 2014 | Dell INSPIRON 15 Notebook
Manual eject button
Use a small paper clip. Insert paper clip in the faceplate's small hole and push it; the DVD tray will be opened. Actually, there is an emergency button in the hole.
Feb 20, 2014 | ASUS Computers & Internet
Loud, grinding noise from garage door opener
Remove the cover from the motor housing and check the drive gear.
Jul 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
I am trying to install a chamberlain wireless keypad opener. I have a Craftsmen door opener. In the instructions, I thought it told me to change on my car remote the DIP Switch for #1 to "-". My...
If you held the smart button in too long it erases the memory and none of the remotes will work. To program it press and hold the button on your remote and then press and immediately release the smart button.
Feb 13, 2011 | Sears Craftsman LiftMaster Chamberlain...
Actually my dvd is not opening when i m pressing the open/close button.
It could be a "physical" problem.
Take a Norwegian paper-clip, and straighten one end.
Insert that end into the small hole in the face-plate of the drive,
and push until you feel resistance.
Then, firmly push another 10mm (1/4 inch) and the drive should "unlock" and open slightly.
Press the open/close button to fully open the tray.
Dec 11, 2010 | Compaq Presario 700 Series DVD-Rom Drive...
The machine will not open the DVD Drive. When I push the eject button the display indicates "OPEN" but nothing happens. Is there a way to open the drive manually?
No,if u forced it,will damges the little motor that help it to open the dirve door.Unplug the unit,hold the unit in ur hand tight over head shake it a few times,this will help,what caught inside that stop the drive door from opening.Wait like about an hour later to replug it back in the unit,will be resetting itself back to the factory setting,will help help the unit too.
Dec 11, 2010 | Samsung DVD-V4600 DVD Player/VCR
Why the door on the CPU will not open when button is pressed?
If it's what I think it is you can get it open by inserting a very small object like a toothpick into the small holeon the face of the disc drive somewhere, most of the face plates on computers are just that a fake front, so when you push the button there is a peice of the fake fron that hits the actual button on the drive, if you get it to open with the tooth pic you can remove the entire front of the computer, if you think you can and see if the fake button is broken off, if it is you can then remove that part of the fake front in front of the actual drive door and it will just look a little funny but will function normally, I knoe it's a lot to follow but if you go slow you will see what I mean
Mar 26, 2009 | HP Compaq Presario SR1420nx...
I opened my recently purchased Compaq Armada M700 laptop. i pushed the blue "on" button. the machine is stuck at "Initializing Intel Boot Agent Version 2.6 (build 004)" Nothing else...
First place your recovery disk in the cd drive. Then hold down the power on/off button for 15 seconds. The machine will power down. Then restart normally and reinstall from the disk.
Jul 18, 2008 | Computers & Internet
Opening disk drive compartment
If you stll have this problem, then you might try a couple of things..
Firstly, a boot of the pc usually will allow the drive to be opened.. But I'm sure you have tried that.. So, there are a couple of other ways.. There is a small pin hole in the front of 'most' CD & DVD rom drives. This is used for emergency situations when the cd will not 'dismount'. Be careful here. Use a paper clip & insert it gently into the pin hole. Only use a light pressure & you should feel a small switch plate. Gently push it with the (extended) paper clip. It will switch the open button & should allow the drive to open. Thirdly, go to 'Start' (button), 'My Computer' highlight the CD rom drive (left mouse click) then right mouse select 'eject' from the menu options.. Actually, if you are still reading, do this first. If it fails, boot the pc & try it again, before using the paperclip method. good luck. Rgds,
May 09, 2008 | Sony VAIO VGN-N130G/W Notebook
Samsung DVD-R130 DVD Recorder Logo
79 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
