Question about GE Washing Machines
Washer Won't Finish Cycle....
My machine will get almost all the way through to wash- into the rinse cycle- then decide to pause indefinitely or until the machine turns off. Drain trap is cleaned out, nothing is in the pump, and load is not out of balance (tried with only a few small articles of clothing to test).
Any ideas?
Oh! But I did smell something icky- like a dead mouse smell- near the main button. Is it possible that a mouse crawled into the top somewhere, died, and is keeping my machine from ending the cycles?
Thanks for any help-
  • alasa7 Jun 15, 2008
    So does anyone know how to open the top of the machine? I tried to take the panel off, removing all visible screws (in back too) but the side of the top still feel firmly in place. Do I need to remove the whole front just to get the top off?
    Thank you- I did open the bottom front panel to see if there was any sign of a mouse- and there were signs, but no actual mouse. I definitely smelled it around the top panel but am still having trouble opening it....
    I took out the two screws at the top in the back (had to tilt the dryer back as it sits on top of the washer) but cannot figure out how to "slide the top forward".
    Where are the hooks? Every time I try to move the panel it just feels like it will break- the top where I took out the screws feels a little loose but the rest feels tight as can be...
    Sorry! I wish the manual came with a diagram or something!
    President:
  • 1,314 Answers
Yep ive removed many of em stoves too
Posted on Jun 15, 2008
  • robert samples Jun 15, 2008
    no remove the two screws in the back and slide the top forward its on hooks also on the front panel under the door is a front panel that you can remove the two screws and drop that panel look there for a critter near the motor controller board
  • robert samples Jun 16, 2008
    ok sorry you didnt say it was a stack unit i can give you what you need e mail me at b4829@yahoo.com and let me know if this is a stack unit or a launtrycenter i thought it was just the washer by itself sorry for the wrong info
Hi we moved to a new flat with a kuppersbursbuch iwt 1259.2w washer. we cleaned the filter and put in a dettol detergent to clean it-since then it pauses mid-cycle and does not pump out the water
It is doubtful cleaning the filter and using Dettol will have caused any problems.
I believe it was quite common to have a programme where the washer stopped mid-rinse before pumping out the water in order to reduce creasing of the clothes. The programmer would be advanced when it was convenient to do so and the rinse cycle would continue and finish with the final spin.
I suggest you read the instruction manual before deciding whether there is a fault or not...
Mar 05, 2017 | Washing Machines
Managemylife com sears
Sounds like this could be a blocked/air-locked filter.
easy fix if so.
First. switch off the Machine at the socket.
Check your washing machine user manual for the location of the pump filter access screw. (Normally situated behind a front bottom clip out panel) ensure you have a few towels and a couple of pans/dishes at the ready before releasing the access screw, expect 2 or three litres of water to drain... and whatever is blocking the filter. (could just be an air blockage or a small object) replace the filter screw and clip off panel, switch on at mains.
Hope this helps.
Aug 26, 2014 | Kenmore 24 in. Electric Laundry Center...
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Duet whirpool washing machine stop and DLF sign appear
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Shane
Apr 03, 2011 | Washing Machines
I've gotten the error code DL and then F, I tried sanding, unplugging but it still shows me the error. How can I fix it?
Hope this helps.
Shane
Mar 15, 2011 | Kenmore Elite 45986 Front Load Washer
Does not advance from wash to rinse to spin
The washer is new and under warranty so I have asked for warranty service.
May 23, 2009 | General Electric WSXH208H Front Load...
Washing Machines Logo
47 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
