Question about Canon PIXMA MX310 All-In-One Printer
My Pixma MX310 will not turn on
Hello:
I recently unplugged my MX310 to move it and when I plugged it back in, the alarm button glows yellow but the printer will not respond.  I have tried all the trouble shooting tips on the canon website with no luck, can you help?
Mine is doing the same thing....
Posted on Aug 26, 2008
No lights flashing, just yellow alarm light is on. why?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 15, 2016 | Canon Pixma MX310 All in One
I cannot turn on the printer. The green light blinks; the alarm light blinks. "CHECK PRINTER" appears on the LCD with 5100 in the lower right corner. I checked all the connections; turned...
According to the Canon troubleshooting website here are the steps to follow for the PIXMA MX310 and Error Code 5100:
-Remove the cartridges
-Inspect the cartridges to ensure all packaging is removed
-Reinstall the cartridges
-Press the ON/OFF button for 2 seconds
-Unplug the printer and wait 10 seconds
-Check the printer for any obstructions including packaging materials
-Remove the scanner cover
-Open the lid - check for paper that is stuck; these can be very small pieces, so look carefully
-Plug the printer back in and power it on.
If that does not solve the problem you will have to contact a service repair centre. Good luck.. thanks
Sep 05, 2011 | Canon PIXMA MX310 All-In-One Printer
The alarm button is on and 5100 is blinking on the screen, it will not print or scan or fax
Nov 17, 2010 | Canon PIXMA MX310 All-In-One Printer
CHECK PRINTER (5800)
Please un and re install the device drivers following link
Installing Devices on PCs and Laptops
May 05, 2010 | Canon PIXMA MX310 All-In-One Printer
Action to fix Error Code 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Getting a 5B00 error on a MX310. We just replaced the ink absorber
error 5b00
reset waste absorber counter. here is how to reset.
1) With the printer2.gif powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times.
If this does not work you need to call canon.
Good Luck
Nov 12, 2009 | Canon PIXMA MX310 All-In-One Printer
Alarm won't reset
To reset you can't just turn it off & on normally. You have to unplug the unit for a few minutes to an hour or so, depending on manufacturer, then plug the unit back in and turn it on. This usually will reset the unit. Hope this helps.
Mar 05, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 doesn't go on and Alarm light goes on solid.
disconnect it again for sometime.also try to remove the cartridges from the printer if possible.and take out the power wire of the printers back for sometime.also remove if any computer wire connected to the back of the printer and then slowly ---slowly connect every thing back and check out.it should work.as the printer is new and the alarm light also bliks if the internal parts gets misallighned or blocked internally.if such problems get it replaced.
Dec 14, 2008 | Canon PIXMA MX310 All-In-One Printer
My pixma pro 9000 Canon printer will continues to flash the yellow light and the on light and will not let the ink cartridges move to the middle to change the catriges
hmm..turn it off..unplug from wall outlet..let it set for 3 min
hold down power button, and plug back in wall..with button depressed.
release button after 10 seconds
that might reset the power situation.
Aug 20, 2008 | Canon Office Equipment & Supplies
Canon PIXMA MX310 All-In-One Printer Logo
274 people viewed this question
old marine
old marine
