Question about SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive
In error, we disconnected our external Simple Drive (by clicking on the "Safe to Remove" icon). Although it is physically reconnected at the back, the computer cannot find it or does not recgonise it. Please help.
    Brigadier General:
  • 10,406 Answers
Disconnect it.
Turn your computer off.
Turn your computer on, and let Windows start.
Connect it, and it should be detected.
Posted on Nov 06, 2010
Should i unplug (usb cable) canvio desk without shutdown computer
You can, but if it's writing to the disk when you disconnect, it could cause errors.
The safer thing to do is... look in the bottom right hand corner of your monitor. Click on the icon that is a USB plug with a green checkmark on it. Then click eject drive. The computer will pop up a window that says it is safe to remove hardware. Then you can unplug the drive.
Nov 26, 2013 | Toshiba 3TB Canvio Desk Desktop External...
Tip
How to Back Up Trial Software
<p>The free trial software gives the user the ability to evaluate a program before they buy. If you have a free version on your computer and want it back, you can connect an external hard drive or flash drive to do. The process can relieve headaches, if your computer crashes or gets infected with viruses.<br /> <p> <br /> <p>1. Connect your external hard drive or flash drive to your computer via a USB port. Click the Start button and click on "Computer" option on the menu. Click on your external hard disk or flash drive icon in the menu. You can use this window.<br /> <p><br /> <p>2. Click the Start button and click "Search ". Enter the name of the test software that you store in the search bar and press Enter.<br /> <p>3. Transferring files to display in the search window on the external hard disk or flash drive. A small window with a progress bar will tell you how long does it take to transfer files appears.<br /> <p><br /> <p>4. Click on the My Computer icon on the Start button when the transmission is complete and right click on your hard disk or a flash image. Click the "Eject" option. Remove the USB cable from the USB port of your computer to your software.<br />
on Jun 21, 2011 | Computers & Internet
Tip
How to Download Files to USB Flash Drive
MS Windows Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. <br />Depending on your computer, there can be USB ports on the back, side or front. The flash drive can also be connected to an external port hub device. Once you connect it, the computer will automatically recognize it as a removal device.<br /> 2.Double-click "My Computer" on the desktop. You should see your USB flash drive's icon listed together with other removal devices on your computer.<br /> 3.Double-click the flash drive's icon to open the flash drive window and <br />reveal the contents saved on it. Locate the file you want to download to the <br />flash drive from its current location on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive.<br /> 5.Close the flash drive when you are done. Click the "Safely Remove Hardware" icon on the system tray. A new window will open. Left-click the flash drive and click "Stop." A message will pop-up indicating that it is safe to remove the device from the computer. Disconnect the USB flash drive from the computer (or external hub).<br /> <br />Mac Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. The computer will automatically recognize the device and display its icon on the desktop.<br /> 2.Double-click the flash drive icon on the desktop to open its window and <br />reveal the contents on it.<br /> 3.Locate the file you want to download to the flash drive from the location <br />where you have it saved on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive. Close the flash drive window when you are done and drag the flash drive icon to the trash can to safely eject it from the computer.
on Feb 01, 2011 | Computers & Internet
I/O error on Buffalo HD-PET500U2 Ext Hard Drive
The message "The Request Could Not Be Performed Because of an I/O Device Error" appears when Windows is unable to read the data on a storage device.
If this error message appears when attempting to access the files on an input/output (I/O or IO) device, such as an external hard drive, the file system on the drive could be damaged, the drive could be infected with a virus or the data connector inside the device enclosure could have come loose.
If troubleshooting the drive fails to fix the IO device error, formatting the drive might repair the device.
Connect the external hard drive to the computer.
Run an antivirus program.
Click the "Scan" tab or button, then click "Custom."
Uncheck all items in the list except for the drive letter assigned to the external drive.
Click "OK." Click "Scan" or "Scan Now" to run a virus scan on the hard drive.
Quarantine or remove any infections the virus scanner detects.
Click "Start." Input "cmd.exe" into the search field.
Press "Enter" to open Command Prompt. Input "chkdsk <drive>: /f /r" into Command Prompt.
Replace "<drive>" with the letter assigned to your external hard drive.
Press "Enter" to run CheckDisk on the drive.
CheckDisk will search for and repair detected errors or bad sectors.
Burn the files on the external hard drive to a set of DVDs or move the files to another drive, if possible.
If the IO device error reappears when attempting to move the files, disconnect the external hard drive from the computer.
Remove the power adapter from the drive.
Check the documentation included with the drive for instructions to take the drive apart.
If no instructions are available, contact the manufacturer for instructions or find out if disassembling the drive will void the drive's warranty.
Remove the screws securing the faceplate to the drive or from the edge of the enclosure. Insert the edge of a small, flathead screwdriver in between either side of the enclosure to wedge both sides apart.
Check the connections to the drive.
Confirm that the IDE or SATA interface is plugged into the back of the drive.
Reassemble the external hard drive, reconnect the power adapter and reconnect the drive to the PC.
Attempt to access the files on the drive.
If the IO device error reappears, return to Command Prompt. Input "format /fs:fat32 <drive>:" into the command-line prompt.
Replace "<drive>" with the letter assigned to the external hard drive.
Press "y" when the message "Proceed with Format (Y/N)?" appears.
The process will format the drive, erasing all data on the disk.
If the drive still fails to function after format, you will need to replace the drive.
Hope this helps
Nov 16, 2012 | Buffalo Technology Computers & Internet
I cannot eject my buffalo ministation HD-PCU2 and when I remove it safely, a message prompts and says "device is currently in use. Close any programs or windows that might be using the device."...
Hi Welcome to FixYa!
I am having the same scenario too sometimes.. What i usually do if the drive is not in use, I turn off the computer first then unplug my external hdd. in that case, the computer is completely off as well as the drive. But if you feel like its a hassle of turning down the machine for you to remove the drive, you could try the following steps:
There is a setting for the USB drives which tells the OS how to optimize their usage. Either it is optimized for Quick Removal or for Performance. To check it, do the following:
-Right click on the USB drive icon in My Computer. -Select the Hardware tab. -Select your USB drive and click on Properties. -Now click on Policies tab.
Optimize for Quick removal This setting disables write caching on the disk so that you can disconnect this drive without using theSafely Remove Hardware icon.
Optimize for Performance This setting enables the write caching on the disk so as to improve disk performance. To disconnect this drive, you should use the Safely Remove Hardware icon so as not to hurt your USB drive.
Hope this would help!
Sep 06, 2011 | Buffalo Technology 320GB MINISTATION TURBO...
My external hard is asking to format everytime when i plugin
Files on a external hard drive can be corrupted if it isnot removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the external hard drive to working order you need to format the external hard drive,BUT you will lose the data stored on the flash drive.
May 03, 2011 | Computers & Internet
I did not install the software of WM "My Passport Essential" external drive. Therefore the WM logo does not appear on the task bar at the bottom right hand corner of the PC screen. I tried to...
It is indeed safe. When trying to disconnect while the computer is on, make sure all windows related to files/folders on the drive are closed, and check that antivirus software isn't scanning the drive.
Mar 24, 2011 | Computers & Internet
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
Feb 08, 2011 | Western Digital My Book Essential Edition...
First time i pluged my Verbatim Desktop Hard drive 2TB in my computer had no problem finding it, but the I wanted to plug it in to my laptop, but it could not find it, and when I wanted to plug it back in...
When you connect external devices, then you have to go through a process of disconnecting them. Otherwise, the device can get damaged.
1. Click on the 'Up Arrow' icon in your Windows System Tray.
2. Click on the Safely Remove icon.
3. The Safely Remove window will display any/all detected USB/FireWire devices connected to your Windows computer.
4. Click on the device (e.g., external drive) you wish to remove.
5. A confirmation window will appear.
6. It is now safe to disconnect your device.
The above instructions work for Windows 8 and Windows. However, the procedure is reasonably similar for other windows versions.
Jan 11, 2018 | Verbatim 2TB DESKTOP HD USB 3.0-SUPER...
I have a HP Pavillion laptop. The computer is starting with the "windows error recover" running. Then once you click to repair the problems or start windows normally, the computer start to load...
The easiest thing to check is to unplug any USB drive type devices (say the MP3 player) before starting Windows and see if that helps. If not then it sounds like something on the harddrive was messed up.
You could try holding F8 at boot to get the boot menu. Select Safe Mode and see if that will boot. If it does, answer yes to the popup question and then do Start'Run and type in:
cmd
to get a command prompt. In the command prompt type:
chkdsk c: /f
It should say that it can't check the drive right now (since Windows is running off that drive) and ask if you want to check it at boot. Answer with a y. Then reboot, let it try to startup normally, and chkdsk should run and check the drive for errors.
If that doesn't work (can't boot safe mode) and If you've got a Windows CD, (XP SP2 version disc may be needed if you have really large harddrives, doesn't have to be the disc used to install Windows on that computer) you could try booting it and go into the Recovery Console. (Basically a dos prompt type thing.)
Then type:
chkdsk c: /p
It should check the harddrive for errors and if it finds some will try and fix them. If when it's done it says it found and fixed one or more errors, then I'd do it again and see if it says it found one or more errors. (If it doesn't say that it found errors the second time then, hopefully, that means it fixed the errors it previously found. If it keeps finding errors every time you run it then that may indicate that the drive is failing.) In any case, running chkdsk once as above may help you get into Windows. (I'd still have it do chkdsk c: /f on reboot as above after booting Windows, just to be on the safe side.) You will need to have set a password for the Administrator account to do the Recovery Console though. (Administrator account is accessible when booting in Safe Mode.)
If you can get Windows booting (by any method) one thing you can do that might help prevent this from happening in the future is to disable disc caching for the MP3 player.
Plug the device in, right click the "Safely Remove Hardware" icon and choose "Safely Remove Hardware."
Check the Display Device Components box if it's not checked.
Find the MP3 player in the list (likely under USB Mass Storage Devices) and click it.
Then click the Properties button. On the properties window click Policies and set it to "Optimize for Quick Removal" and click OK.
From now on (at least on that computer) you should be able to remove the MP3 player without using the Safely Remove Hardware tray icon, as long the computer's not actually accessing files on the drive.
Nov 13, 2010 | HP Computers & Internet
Computers & Internet Logo
49 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
