Question about Arris SURFboard SB4100 (46977600100) Modem
I've lost my security key, and I cant find it! Hoe do I connect my laptop tp my cumputer if I cant remebmer it?!
  • 4 Answers
If you have a router, then you need to do a factory reset of it. I would also suggest you upgrade that surfboard to at least a 5100 series or better. The factory reset is somewhere on the back of the "router" not the modem. It is a pinhole that you push with a pen extended. This will take the admin settings and security setting off and reset the admin to factory default. Once you do this you are going to either connect without security settings or determine the factory default admin settings and reset all security again.
Posted on Nov 06, 2010
I want security key of my router TP-LINK-740
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. Toconnect to your wireless router from the computer/laptop, configure thewireless card in your computer/laptop with the router's wireless settings ieSSID, plus the WPA or WPA2 encryption key. Then computer/laptops cancommunicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
Dec 30, 2011 | TP-LINK TL-WR740N Router
I cant install my wifi router in my loptop
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Aug 26, 2011 | TP-LINK TL-WR841ND (813120012903) Router
Lan card is not connecting wireless connection available showing full signal but not connecting.
Jun 15, 2011 | TP-LINK TL-WN350G, 54Mbps Wireless PCI...
I have a desktop & a laptop with the Linksys router connecting the two. Everything is hooked up okay, but lost the security key on my laptop . Tried to set up my E Reader wireless & went into my...
Can you connect directly to your router using an ethernet cable?
Go into your settings on the router and choose a security key.
Set the same key for your laptops etc..
Dec 30, 2010 | Linksys WRT160N Wireless Router
Unable to wireless connect TP-Link TL-WR841ND to Motorola SBG900
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Feb 28, 2017 | Arris SURFboard SBG900 (49402201900) Modem
I have lost my wireless connection on my laptop
Delete the Existing wireless connections in the laptop and create another one
This should fix the issue
Jan 03, 2010 | 2wire 2700HG-B Router (2700HGB)
I have a toshiba laptop, already have existing computer all set up but having trouple conncted laptop to wireless. Have adsl modem and tp link router. tp link is asking or network key to be able to...
Your wireless network is secured and thats why its asking for the network key. If you dont remember the same, contact your router manufacturer or ISP and get the router reconfigured
Jul 03, 2009 | Computers & Internet
System will not connect to my wireless internet service
if you have security enabled WPA2 you have to have XP SP2 otherwise it will not connect.
try the follow:
1. try to connect via line to the router
2. if it works- try to disable the security
3. if it works- select WPA and not WPA2 and enter pass key.
hoe that helps
Dec 18, 2008 | Acer Aspire 3680 Laptop
Modem router
I can tell that your network topology is not the most complicated ever.So u ve got 3 terminals,1 desktop pc and 2 laptop.Simple,reset your zyxel(from the button on the back) and reconfigure the Local area interface connection(ip & subnet mask for the zyxel),reconfigure your internet connection,(WAN zyxel interface) in case the zyxel is your Internet gateway too.Third,make sure NAT & Firewall are up and running(usually are by default) Finally,reconfigure the WiFi interface with the correct SSID name & WEP key or whatever security you prefer.Write down the security pass for your wireless and you are done.Good Luck.
Apr 19, 2008 | Zyxel Prestige 660H Router
Labtec webcam
right lve put in the diss in my cumputer and it is not woking in my hp cumputer and Ive got web cram allso
Apr 12, 2008 | Labtec 961307-0914 Webcam
Open Questions:
CHARTER Email Password reset Phone nUmber+1800 828-0294 asif Get easy steps to forgot or change CHARTER password reset via phone number + 1800 828 0294 just follow some steps to recover CHARTER password while you want. In varoius conditions many people lost their account password and much more secure information or information may be hacked by anyone so in that case people want to configure CHARTER with CHARTER or other CHARTER account services. Their are many certified officer to suggest people that how to change or reset CHARTER voicemail password using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to reset CHARTER password to reset or change it quickly, if you have any of them so contact to get well CHARTER support form us. CHARTER password reset not working CHARTER password reset phone number CHARTER password reset contact number CHARTER password reset help CHARTER password reset support CHARTER password reset wont work CHARTER password reset wont work CHARTER password reset link CHARTER password reset issues CHARTER password reset usa CHARTER password reset customer service. CHARTER email account password reset ' free CHARTER email password recovery ' cannot reset CHARTER email password ' CHARTER email password recovery ' CHARTER email password recovery download ' CHARTER email password recovery software ' free CHARTER email password recovery. CHARTER email password change, CHARTER email hacked password changed, CHARTER email hacked can't change password, change CHARTER email password on iphone, change CHARTER email password on ipad, change CHARTER email password on android, CHARTER email account hacked can't change password, how to change CHARTER email password on droid, CHARTER email password problems, CHARTER email password not working, CHARTER email account password reset.
Mar 23, 2019 | VIA Computers & Internet
ROADRUNNER Email Password reset Phone nUmber+1800 828-0294 asif Get easy steps to forgot or change ROADRUNNER password reset via phone number + 1800 828 0294 just follow some steps to recover ROADRUNNER password while you want. In varoius conditions many people lost their account password and much more secure information or information may be hacked by anyone so in that case people want to configure ROADRUNNER with ROADRUNNER or other ROADRUNNER account services. Their are many certified officer to suggest people that how to change or reset ROADRUNNER voicemail password using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to reset ROADRUNNER password to reset or change it quickly, if you have any of them so contact to get well ROADRUNNER support form us. ROADRUNNER password reset not working ROADRUNNER password reset phone number ROADRUNNER password reset contact number ROADRUNNER password reset help ROADRUNNER password reset support ROADRUNNER password reset wont work ROADRUNNER password reset wont work ROADRUNNER password reset link ROADRUNNER password reset issues ROADRUNNER password reset usa ROADRUNNER password reset customer service. ROADRUNNER email account password reset ' free ROADRUNNER email password recovery ' cannot reset ROADRUNNER email password ' ROADRUNNER email password recovery ' ROADRUNNER email password recovery download ' ROADRUNNER email password recovery software ' free ROADRUNNER email password recovery. ROADRUNNER email password change, ROADRUNNER email hacked password changed, ROADRUNNER email hacked can't change password, change ROADRUNNER email password on iphone, change ROADRUNNER email password on ipad, change ROADRUNNER email password on android, ROADRUNNER email account hacked can't change password, how to change ROADRUNNER email password on droid, ROADRUNNER email password problems, ROADRUNNER email password not working, ROADRUNNER email account password reset.
SBCGLOBAL Email Password reset Phone nUmber+1800 828-0294 asif Get easy steps to forgot or change SBCGLOBAL password reset via phone number + 1800 828 0294 just follow some steps to recover SBCGLOBAL password while you want. In varoius conditions many people lost their account password and much more secure information or information may be hacked by anyone so in that case people want to configure SBCGLOBAL with SBCGLOBAL or other SBCGLOBAL account services. Their are many certified officer to suggest people that how to change or reset SBCGLOBAL voicemail password using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to reset SBCGLOBAL password to reset or change it quickly, if you have any of them so contact to get well SBCGLOBAL support form us. SBCGLOBAL password reset not working SBCGLOBAL password reset phone number SBCGLOBAL password reset contact number SBCGLOBAL password reset help SBCGLOBAL password reset support SBCGLOBAL password reset wont work SBCGLOBAL password reset wont work SBCGLOBAL password reset link SBCGLOBAL password reset issues SBCGLOBAL password reset usa SBCGLOBAL password reset customer service. SBCGLOBAL email account password reset ' free SBCGLOBAL email password recovery ' cannot reset SBCGLOBAL email password ' SBCGLOBAL email password recovery ' SBCGLOBAL email password recovery download ' SBCGLOBAL email password recovery software ' free SBCGLOBAL email password recovery. SBCGLOBAL email password change, SBCGLOBAL email hacked password changed, SBCGLOBAL email hacked can't change password, change SBCGLOBAL email password on iphone, change SBCGLOBAL email password on ipad, change SBCGLOBAL email password on android, SBCGLOBAL email account hacked can't change password, how to change SBCGLOBAL email password on droid, SBCGLOBAL email password problems, SBCGLOBAL email password not working, SBCGLOBAL email account password reset.
See all Arris SURFboard SB4100 (46977600100) Modem Questions
Arris SURFboard SB4100 (46977600100) Modem Logo
444 people viewed this question
Top Arris Computers & Internet Experts
Greg Ulan
Robbie Goodwin
RS Technology...
RS Technology...
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
