Windows could not start because the following file is corrupt or missing
Hi ~ Trying to fix son's compaq presario with the above message...tried safe mode, tried debug...keep returning to same message...any help greatly appreciated!
    President:
  • 1,314 Answers
Boot with a windows cd and do a repair install. It will reinstall all windows files. Please note, even though it should leave your data in tact, I would make sure you have a backup before doing so. After hitting F8 to agree to the terms and conditions on the windows CD, use R to do a repair install.
Posted on Jun 15, 2008
My computer displays the following on the start up screen: windows unable to start because the following file is missing or corrupt \windows\sys32\config. I have very precious pics on there and need to...
yes it may work , but for safer side, remove the HDD from your PC. and connect to your friends PC or any other PC and Backup all the Data you needed. Write it to DVD or any other media. and then try HP recovery media CD. best of luck
Feb 08, 2011 | HP Compaq Presario SR2011WM PC Desktop
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
My computer(Compaq 5301RSH 5000 SERIES) won't start because "Windows could not start because the following file is missing or corrupt: system32hal.dll. Please re-install a copy of the above file." What can...
Alright..Not a big problem..Generally happens due to some files corrupting. Put your Windows CD in the drive, boot form the Disc and choose to repair the operating system. The problem will be solved.
Thank you!
Sabharish
Jun 04, 2009 | HP Compaq Presario S5100NX (DM172A#ABA) PC...
Missing or corrupt file
See if you can go into setup by pressing the F8 key when you first turn on the laptop. It should bring you into a menu, if it does then choose safe mode. If you can get into safe mode then do a system restore back to a date when the laptop was last working properly.
If you can't get into safe mode then your system files are corrupt and you'll need to reset the laptop back to factory default and I believe it can be done by pressing F11 when you first turn on the laptop assuming the partition with the info on it is still there.
If you can't do this then you'll need to find the cd's that came with the laptop and install the operating system first and then the drivers and applications cd.
Let me know if I can be further assistance.
Ben
May 18, 2009 | Compaq Presario V4000 Notebook
I can't afford a brand new Windows XP boot disk Where
You should be able to download that file from microsoft, or try googleing "ntoskrnl.exe"
I done it for a missing dll file and found many places to download for free.
May 17, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq laptop pp2140 missing vgaeon.fon
Try to press F8 on boot and "Safe mode" boot
Jan 11, 2009 | HP 285527-001 - Compaq Presario...
Compaq Presario 1700 PC Notebook Problem gives me a screen windows will not strat because file is corrupted or missing file is \windows\system32\config\system
Is this XP?
Do you have the XP cd or the recovery cd's. This needs to be fixed by performing a Windows repair.
missing or corrupt: \windows\system32\config\system"means that the OS,XP, is missing an essential file to run.
Or it could mean that your hard drive is failing. Is the hard drive noisey?
Leave me a comment,here
Oct 12, 2008 | Compaq Presario 1700 Notebook
Windows xp missing file and won't start up
Here's what I would do, because after reading around on that error message, it seems like you can't repair the problem.
I would find myself one of these: http://www.casecooler.com/3drto2dr.html
Take out your laptop's HD, hook it up to that convertor, slave it to a desktop, pull all your data that you don't want to lose to the desktop, put the laptop's HD back into the laptop, reformat/reinstall windows back onto the laptop, pull the HD back out of the laptop, hook it back up to that convertor, slave it back to the desktop, put your data back onto the laptop's HD, then put it back in the laptop.
That will leave you with a clean install that works on the laptop and you won't lose any data.
Nov 12, 2007 | Compaq Presario V4000 Notebook
Computers & Internet Logo
145 people viewed this question
David Payne
David Payne
