Question about Maytag Dryers
Our Maytag Performa electric dryer dooes not rotate/spin the drum when the motor is started. The motor starts but no drum movement.
  • Maytag Master
  • 8,220 Answers
Unplug the machine Our Maytag Performa electric dryer - themobilian_53.jpgthemobilian_54.jpgRemove the Our Maytag Performa electric dryer - themobilian_55.jpgp://i.fixya.net/uploads/images/themobilian_55.jpgOur Maytag Performa electric dryer - themobilian_56.jpg_55.jpg" class="h_mi" />thOur Maytag Performa electric dryer - themobilian_57.jpgclass=
Check for lint and loose blower wheel. Replace the belt using one hand. Ribs to the drum No twists. Use your left hand to ease the idler over the motor and loop the belt onto the motor pulley. That is how it is done.
Posted on Nov 06, 2010
  • Dan Webster
    Dan Webster Nov 06, 2010
    OK if you have real skinny arms you can use both hands LOL.
My Maytag Performa Dryer model PYG3360AWW wont turn on it just buzzes when I push the start button. what do I do to fix it?
See if you can turn the drum by hand, there should be some resistance. If its locked you will need to disassembly the dryer and see what is binding. If everything(motor,rollers,pullys)spins freely they you most likely have a faulty motor winding and will need to replace it.
Dec 21, 2014 | Maytag Dryers
Dryer drum does not rotate
can you hear the motor at all? probably broke the belt. Not to difficult to replace belt. Posibility drum is off center.
Sep 18, 2012 | Maytag Performa PAV2200
When pushing the start button dryer hums but does not spin. when u release start button dryer shuts off
Sounds like a bad motor. Check to make sure the drum isn't stuck, if you can spin the drum put some tape on the door switch and press the start button while you spin the drum. If the drum continues to rotate, you have a bad motor.
Mar 10, 2011 | Maytag Washing Machines
My maytag dryer won't start. When I push the start button it makes a "errrrrrr" sound but won't start. Any ideas?
Stuck drum or failing motor. Try turning the drum by hand. It should move fairly effortless in one of the directions. If it does - the problem is in the motor. If it does not rotate - check if something is stuck between the drum and rear or front panel. Good luck Motor part number is 31001589. Replacing it is fairly hard for untrained.
Nov 26, 2009 | Maytag PYE2300AY Electric Dryer
Need belt diagram for Performa PDET920AYW dryer
Flat side of the belt goes agaist the drum. The diagram is on the new belt
Aug 08, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Performa Dryer won't start.
I would suggest checking and probly replacing especially if you cant hear the timer motor.
Mar 28, 2009 | Zanussi TD4112W Electric Dryer
Dryer motor will not spin..motor sounds like it is sutck.
Get a putty knife, release the top by pressing the springclips between the front and top.
Then remove the front. The blower wheel may be the problem. They get loose.
Jan 04, 2009 | Maytag Performa PAV2200
Maytag performa dryer
My Maytag Performa Oversize Capacity Dryer stopped working without a warning. It dried a load on the week-end without a problem. I put a load in on Wednesday, turned the dail to on
but there was no movement or sound.
HELP!
Jul 02, 2008 | Dryers
Maytag performa dryer assistance
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
Thanks,
Juan J.
Jun 07, 2008 | Dryers
Dryers Logo
136 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
