Question about Maytag Neptune MDE5500AY Electric Dryer
An ring fell out of jacket pocket while jacket drying, can see ring when pull out lint catcher. ring located in "dryer pipe" opening next to a rubber gasket in the front of the dryer unit. How do I take off the front panel of the dryer to make easier access to this area of the machine?
    President:
  • 3,074 Answers
You will need to remove the hinges, they lift up and out once screws are removed, the the two white plastic pieces with the screws these are for door reversal, then the front panel lifts off. Good Luck Tim
Posted on Nov 06, 2010
Testimonial: "quick response, great help"
Bosch dryer beeps
Two Beeps on my Bosch WTE84100au Condensing Dryer means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Open the door, pull out the lint catcher and clean around the silver probe (it's like a shiny 1/8" nail sticking into the cavity below the lint catcher). If it still doesn't work (and still 2 beeps), just flick it lightly a couple of times. If it still doesn't work, flick again from the other direction.
Mar 24, 2014 | Dryers
Shut off after pulling out the lint catcher. It had some BB's that fell down the shoot. Then shut off. Will not restart. Is there a safety switch that may have tripped (fire safety)
if the dryer was running and you pulled out the lint filter most likely all the lint got removed and jammed the blower wheel.unplug it,remove the vent line and the back panel,then remove the duct that the lint filter slides into and clean it out.i'm assuming this is a whirlpool or kenmore,you could have cooked the thermal fuse also,it's a white piece next to the duct,it has two wires going to it and the part number is 3392519,check it with a meter,you have to pull at least one wire off when you read it out to get the true reading,vac out the duct and all the lint,if the vent line is long,blow it out with a leaf blower,all the lint will blow outside through the outside vent,then you can remove the front and vac out all the lint in the cabinet and clean off the motor.good luck
Jan 29, 2011 | Dryers
The dryer is causing the breaker to trip
check the entire venting system . possibly full of lint .
Dec 21, 2017 | Whirlpool LER4634J Electric Dryer
My dryer take too long to dry the clothes.
hello. When the dryer takes too long, it is a sign that lint has built up in the vent pipe, in the rear of the dryer or even in the lint catcher. Check out all of these areas and remove the lint.
Jan 09, 2010 | GE DBSR453EBWW Electric Dryer
My Indesit WIDL126 washer/dryer doesn't dry clothes
You have an air flow problem. This usually happens when the exhaust pipe/vent gets clogged. Clean/inspect the vent outlet, the pipe, the inlet, and the filter/lint catcher area.
Improper air flow prevents the moisture from being vented out of the dryer.
Sep 26, 2009 | Washing Machines
Wont dry clothes is hot inside dryer but takes 3 or 4 cycles to dry load
Sep 26, 2009 | GE DBSR453EBWW Electric Dryer
Dryer has hot air but takes 2-3 hours to dry clothes. What can I do?
This is almost always due to lint build up in the vent pipe. pull the dryer out from the wall, disconnect the vent pipe. look inside the rear of the dryer and into the pipe. remove lint that is present. go out doors and examine the vent from that end. finally remove the lint catcher in the dryer and look in there. remove any lint you see.
Jun 22, 2009 | Dryers
Dryer will not heat properly
Your heating element sounds like it is going out.
May 21, 2009 | Whirlpool LGR5636L Gas Dryer
I need the schematic for my dryer series 80. Model number 11062822101 A night light bulb accidentally fell in the vent hole, when I pulled out the lint screen to clean it off. My dryer opens in the front,...
lift your lint lid and remove the 2 screws you see then pry the top up at the edges with a wide flat screw driver. If you have a rear cover remove it then remove the 3 crews that hold your lint catcher assembly to the blower housing and you should find your bulb
Mar 11, 2009 | Kenmore Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
173 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
