Question about ASUS Essentio Desktop with Intel Core 2 Quad Processor
USB device over current status detected !! System will shut down in 15 seconds
  • 2 more comments
  • asmir465 Nov 06, 2010
    Keyboard not detected !
    Still same problem
    I build PC by myself , but I'm not specialist.
    This message come up on the screen, when I turn on power
    I've tried to install all updates, when I;ve seen messages
    Like usually I saw stream video online and I've turned off my comp.
    This error come up anyway, when I removedall usb devices from comp.
    I did everything what you tell me, but I have same problem
    Computer shut down in 15 seconds
    Thank you very much for your support, I've fixed up by pressing Fn A (may be).
  • 4,889 Answers
Well I have seen this problem occur due to faulty BIOS. So here's the plan. First lets make sure that its not a hardware problem. Disconnect the cables powering the USB ports(cables of one port at a time). Be careful the cables go onto pins and you do not want to bend/break them. If a particular port is not the source of the problem then move on to the next one. Repeat until you find the faulty one. If there is any recent change that you have made in your system hardware, then let me know.
Posted on Nov 07, 2010
  • ASUS Master
  • 13,433 Answers
disconnect all your usb devices aside from usb keyboard and mouse.
if the error is gone, start re attaching device one by one until you find the device that causes the problem, what device is it?
Posted on Nov 06, 2010
  • 3 more comments
  • Ekse Nov 06, 2010
    I need you to provide me with some background details so that we can solve the problem.
    Have you build this pc yourself?
    does this message come on the screen the instant you turn the power on or does the computer start up to windows and give you the error message?
    Have you done a bios update recently?
    what did you do before the problem appeared did you change anything just before it came up?
    does this error come up even if you remove all usb devices from the computer?
    Please answer all of the above questions so that we can solve the problem.
    I will answer to your messages as soon as I can, please be patient its email support not instant message support.
  • Ekse Nov 06, 2010
    Its possible that there is a short happening on the mainboard, it might not be seated properly, some of the pins might be touching the metal casing that are not supposed to be touching.
    Also if you connected any extra usb ports to the connectors on the mainboard disconnect all of them, leaving you with only the usb ports in the back of the computer.
  • Ekse Nov 06, 2010
    let me know once you have done that - if the problem remains, well then you would have to take a close look at the mainboard, that its not touching the metal casing, it should be standing on gold or metal feet that take a screw on top of them, if you forgot a few feet on the edge of the board it shouldn't be a problem but if the mainboard is touching the casing its probably causing the problem.
  • Ekse Nov 06, 2010
    post me the specs of your computer, brand and model of mainboard and what parts you got on it.
  • Ekse Nov 07, 2010
    olkay, let me know if it comes back
When i start my pc i get the error "please enter
One or more of your USB devices connected to your PC are malfunctioned, remove any usb connection exept keyboard and mouse. Boot the PC , if the error still exists then reboot after removing your Mouse first and keyboard at second. Tell me what happens after these.
Sep 14, 2011 | ASUS P5KPL-AM SE Motherboard
USB Over Current Status Detected, Computer will shut down in 15 seconds
this message popped up because one of the device which you connected to the usb of the pc was overdrawing current i.e more than 5V DC. Hence, the built in system security gave this message and will shut down your computer in 15 seconds. In order to avoid this message first remove all the usb items connected to it and then connect one by one and detect the faulty one and replace.
Jan 29, 2011 | ASUS P5PE-VM Motherboard
When the computer is booting these words appears usb device over current status detected, and then after 15 seconds the computer is shut down
A USB device is drawing too much power so the system crashes. Remove all devices attached to USB and try again. If it's the same then remove all external USB ports - the ones connected with wires to the motherboard. If it's the same then there's a short in the motherboard - unfixable, replace it with a new one.
Jul 10, 2010 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
System shutdown in 15 seconds
Shut the power down to the computer all the power and pull the power cord out, remove all usb devices except the mouse and keyboard, Turn the unit back on and see if this fixes the problem, if it doesn't then you will have to go into the computer and clear the c-mos this will allow you to get into the bios screen from there you can set up the computer again. Check you manual for the instructions on bios reset, most times it is just pins 2+3 that need to have a jumper installed to reset it. READ THE MANUAL PINS 2+3 APPEAR ON MANY THINGS ON THE CIRCUIT BOARD
May 31, 2010 | ASUS P5PE-VM Motherboard
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
hi, pl check for viruses, scan the system, and go to cmd prompt and issue this commnd at c:\ shudown -a and press enter to disable reboot and scan the system and check any hardware issue.
Aug 12, 2008 | ASUS P5PE-VM Motherboard
SYSTEM ERROR
1) if you have nothing in a USB port you will need to set bios
Try removing M/board battery for 2 to 3 hours some people say less then replace it most times it should set BIOS back to default
also check setup of hard disks master slave etc
Last resort with 15 seconds you should be able to see
press ?? key to access BIOS next boot keep pressing key see if that works
Aug 10, 2008 | ASUS M2N-MX Motherboard
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
May 11, 2008 | ASUS M2N-MX Motherboard
cheak bios settings diable serial port parrel and any onbord stuff u wont use ok
Feb 01, 2008 | ASUS P5LD2 Motherboard
ASUS Essentio Desktop with Intel Core 2 Quad Processor  Logo
635 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
