Question about Toshiba 19A25 19" TV
No Power Hi nfrandres, I have a Toshiba 19A25 19" TV with a 2005 manufacture date. When I press the on button, there is no power on the tv. The power LED does not illuminate. I know that the AC outlet is functioning and have tried the TV on a different circuit. Any suggestions? Any fuses that I can try to replace prior to bringing to a shop? Thanks
  • blueline2 Jun 15, 2008
    Opened it up today. The fuse next to the power input to the board was in good shape. Still no power...
  • 3 Answers
Your tv set power chord may have been broken. or a loose outlet.
Posted on Aug 15, 2008
How can I restore the tv signal on my Toshiba 32DL934?
    • 1 Locate the "Power" button on the front of the TV.
    • 2 Press and hold the "Power" button on the front of the TV.
    • 3 Hold down the button for longer than five seconds, then release.
May 29, 2015 | Toshiba Televison & Video
I am having issues hooking up a D-VR600KU to a dish network box. It asks for a manufacturers code and this is not in the manual. Does anyone have a solution to this issue? It is currently connected to both...
We would be happy to help. We currently do not have any codes specifically for your Toshiba D-VR600, we would recommend performing a power scan. If there is a code that is compatible with your TV the power scan will find it.
Power scan instructions:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate, then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
After doing the power scan please remember to put the remote back into SAT mode. Thanks so much for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Mar 08, 2011 | Toshiba D-VR600
Hi Toshiba Team, I have a Toshiba MD20FL1 and need a new remote control. Tried 2 different remotes and none of them worked so far. I know that this Toshiba model is a little old for a TV but I don't...
Hello
You just buy one Philips Universal Remote Control model number [CL 034]. Your Toshiba set is listed in its codes and are given here.
......... 0517 0419 0512 0613
........................... 0719 0112 0506 0111
........................... 0618 0627 0437 0041
................. 0094 0802 0111 0313 0715
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
3. Press and release the desired Mode
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing "0" performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
controlled changes channel.
6. Press and release MUTE to install
the code.
Note, when all codes under a Brand
have been searched the red indicator
flashes rapidly for 3 seconds
Dec 08, 2010 | Toshiba MD20FL1 20 in. TV/DVD Combo
I need the code to program my hitachi remote control to a SDV290 Toshiba Dvd player?
1.Turn on the component to be programmed, such as the television or DVD player.
2.Press the "Code Set" button on your Hitachi remote. The button is often located near the top with the separate component buttons.
3.Press the button for the component you wish to program with the Hitachi Remote(TV,DVD).
4.Enter the manufacturer's code for the component being programmed. The manufacturer's code can be found either in the Hitachi manual, the manual for the component being programmed or on the website of the manufacturer of the product.
5.Press the "Enter" button to submit the manufacturer's code.
6.Press the power button for the component being programmed. Make sure the remote is pointed at the correct component, and it should turn on if the program was entered correctly
Thanx
Jul 29, 2010 | Hitachi CLU-5713TSI Remote Control
Remote codes for the 22LV506 for a dish network remote please. none of the provided codes for this tv work. Thanks, Frank
You can power scan any dish network remote for the correct code by pressing and holding down the tv button(clear or gray button at the top of the remote) until the lights all light up, release the tv button. Press the larger red power button (not the red tv button) release button then press the channel up button repeatly givng time for tv to shut off. Once tv shuts off press pound key and red tv button to turn tv back on, Press sat key to go back to satellite mode.
Jun 19, 2010 | Toshiba 22LV506 21.9 in. LCD HDTV/DVD...
No power or red led fuse good .toshiba 27df46
Hello Hloggins, hi, your power supply is not producing the pulse needed to start the switching. check for the IC on the oscillator part of the power supply, you need an Oscilloscope to test this. if there is no scope. i suggest you replace the IC.
May 20, 2010 | Toshiba 27DF46 27" TV
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
Cannot find code to program sky remote control
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0156
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Mar 12, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
SKY REMOTE
Press TV
Press and hold Select & Red until the LED blinks twice
Press TV
Type in code 0 0 6 0
press the Power button on the remote, if the TV turns off press the select button and everything should work, if the TV stays on press the TV button on the remote then the Power button again, keep doing this until the tv turns off, when it does press the Select button and all should be ok.
Feb 01, 2009 | Toshiba MR120 Remote Control
The volume control won't work on my sky remote
for a toshiba tv,
press tv
press and hold select and red until the led blinks twice
type in 0 1 5 6
press the power button on the remote
If the tv turns off press select and hey presto you're done, if the tv doesn't turn off, press tv then press the power button and keep doing this until the tv turns off. When the tv turns off press select.
Nov 17, 2008 | Universal Remote Control Remote Control
Toshiba 19A25 19" TV Logo
94 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
