Akai LCT2715 has front led blinking red and made a loud ticking sound. will not turn on
  • 1 more comment
  • davidiode Jun 15, 2008
    Yea I tried all that, I was hoping for someone actually familiar with this model tv.
    blinks about 1 second intervals all the time regardless of whether I try to turn it on or not manual/remote nothing
    Brigadier General:
  • 3,614 Answers
Look into the convergence circuit area, check the convergence amp's, bad solder the convergence module, & for the possible bad stk's.
Posted on Jun 15, 2008
    Master:
  • 638 Answers
Red led blinking/flashes how much times or just still without blinking after u on the tv let me know now i am waiting for your reply
  • hemant somaiya
    hemant somaiya Jun 15, 2008
    I have mentioned the list of no. of flashes and their solution:
    ONE Blink--- not used for the self-diagnosis
    TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
    mode then displays the 2 blink fault. Could be a short in the power supply of
    any of the circuits.
    THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
    mode then displays the 3 blink fault. This is also a problem in the power
    supply circuit, check T603 and R672.
    FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
    horizontal line then the video signal muted. Check IC1509, Q1505
    FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
    30 seconds then goes to the self-diagnosis function. Something is wrong with
    the video. Check video out, Q705, 732, 761 and other components on the C
    board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
    try turning up screen slightly.
    SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
    function immediately. Check C515 & 516 and the jungle IC, IC206.
    SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
    and the unit goes immediately into safety shutdown. Check power supply
    regulation and horizontal circuits.
    EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
    blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
    Intermittent problems ?? This is a great feature. You can also bring up
    these fault codes ON-SCREEN to see a list of the problem numbers with the
    abbreviation of the problem and the number of times this problem has
    occurred. This is slightly different than entering the service mode. To see the
    diagnostic screen, Press the following buttons:
    Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
    a screen with a list of the problems and number of times they have occurred.
    Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
    We have repeated them in parentheses in the text for the "Blinks" described
    above so you can correlate between the diagnostic screen and the blink
    codes.
    So, now that you know about these self-diagnostics, how do you use them?
    Say that you have a set with a black screen. You see that the LED is blinking
    4 times....This would tell you that you have no vertical and that is why the
    video is muted. If it was blinking 6 times, you would know that you have a
    horizontal fault.
    It's not a sure cure, but it's a little better than a poke in the eye with a sharp
    stick.
    IMPORTANT: after you repair the unit, PLEASE clear the values on this diagnostic screen. These codes do not reset themselves after the fault is 0 corrected, so if you don't clear them, you'll be seeing "old" fault codes the
    next time you enter this screen. Clearing is done by going into the service mode ( display, channel, 5, volume plus, then power ) then press 8 and Enter, which of course returns
    everything to the factory preset condition.
    Please don't forget to rate or accept the solution
    President:
  • 2,712 Answers
You seem to be having a problem with the power relay. You may have to get this replaced. It could also be an issue with some other component on the power board/circuit.
I recommend getting a qualified TV repairman to check this and give you a correct diagnosis, as some testing may be required to correctly isolate and identify the faulty component(s).
  • Swilin Sampson
    Swilin Sampson Jun 15, 2008
    I dont recommend you doing this if you have no prior experience, but you will have to replace the capacitors on the board. There are a total of 19 capacitors: 3x 1000uf 16v, 2x 470uf 16v, 3x 470uf 25v, 2x 1000uf 25v, 6x 1000uf 35v, and 1x 470uf 35v, as well as the 2 main filter capacitors that are 100uf 450v.
    You can get the full service manual from here:
    http://www.nodevice.com/manual/newmans/l...
    It will give you details as to the location of these capacitors. You dont have to replace them all. Just look for the ones that have swollen tops..they are faulty.
    Once again, beware when dismantling TV's, as there are voltages inside that can KILL , even if it is unplugged. In my honest opinion, it would be best to let a qualified professional do this.
    Kindly take a moment to 'Accept" this solution if it was helpful to you.
    Genius:
  • 3,422 Answers
Did you try pluging it into another socket?
  • Priya darshan Jun 15, 2008
    is it possible to turn tv on manually? if it is, problem is with remote
    control. if it isn't, i believe its a problem with power supply.if it is too high, tv will not turn on.Front lead blinking red indicates that it is gone into the standby mode.
    I strongly recommend you to get it repaired.
    Please cooperate with Irishdruid.He will help you fix it up and make sure you rate his solution.
    Hemantraj that list is only for sony TV models not for Akai.
A red power, a green timer, and a red lamp led lights are flashing on t front power panel.
Likely an AKAI DLP made actually by Samsung. All 3 lights blinking is lamp failure. You can fix yourself with owner's manual.
Sep 29, 2014 | Akai PT46DL10 46" HDTV-Ready Television
AKAI PT5598HD will not turn on.
if you got to the following link and search by the model number you will find what your looking for.
Http://www.samsungparts.com/search/search.asp
The part number for the service manual is SM-PT5598HD
As the set is showing a blinking red timer light. you can check the following link out.
http://www.techlore.com/article/15444/
May 13, 2008 | Akai PT5598HD 55" Rear Projection...
60SDX88B. No video, No sound. DP06 Protection
not a solution but i have a 50gx30b doing something similar, no picture no sound, 3 green leds are lit up on the main board and then one red led lit up also on main board, front panel red led stays on for about 30 -50 seconds and then it all shuts off, I then have to unplug and replug to get the same results.
Mar 03, 2010 | Hitachi 60SDX88B 60" Rear Projection...
When I turn on my TV (KF50WE610), it makes ticking
Hi,it sounds like a problem with your ballast.The ballast is the board that powers the lamp .When it starting to fail it will make clicking sounds.The part is around $40-$60 depending where you look for it.I believe there's instructions on youtube.Have a bless one!
Feb 09, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Hitachi 51UWX20B no sound, no picture, blinking green LED
The 392-150 is a higher current device then the 110---you can use either--this is normal in the hitachi sets---I usually replace both with 150's---check the led that does not light---should indicate which voltage source is bad---if it is one of the 2 voltages for the convergence ic's(one is a positive and the other a negative voltage) then the convergence Ic's may be bad---look for any discolored resistors around the ic's---one way to tell if it is a convergence ic is to de-solder both ic's and see if the set turns on(the convergence will be out the window) but if it comes on change both and do the alignments with the Hitachi remote. By the way----the led should have a location number printed on the top of the circuit board.
Aug 07, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Akai pt4299hd
replace your STKs big black Ics STK394-250 there is 2 of them thses are your convergence ics.Also ck resistors and pico fuses.
Jul 22, 2008 | Akai PT4799HD Rear Projection Television
AKAI LCT2715
I replaced 19 filter caps in LV power supply.
There were pruffed up on top
Mar 11, 2008 | Televison & Video
TV won't come on, the red LED keeps blinking
sounds like you have a solder joint thats touching another one, recheck your solder and make sure theres no broken solder joints else where.
Dec 04, 2007 | Hitachi 53UDX10B 53" Rear Projection...
TV won't come on!
Most likely, this is a problem with the convergence board. The convergence amps (STK392-040 x 2)are internally shorted. These can be replaced or the whole convergence board can be replaced. It's cheaper to replace the amps, but more convienent to replace the board (especially for the less electronically inclined!! :) Also, this could be from a leaking CRT. In CRT projection televisions, the red, green, and blue tube are filled with coolent (glycol). These 42" models are very bad about the tubes leaking (Akai and Samsung models)and are infamous for destroying the CRT driver board connected to the bottom of each tube. When this happens, the protection circuit kicks in and will not let the television start up. *PLEASE, FOR YOUR OWN SAKE, DO NOT FOLLOW THESE NEXT STEPS IF YOU HAVE NO UNDERSTANDING OF ELECTRONIC EQUIPMENT!!!! There are four screws and three snap clips that hold the bottom on. UNPLUG THE TELEVISION, remove the screws and pull bottom outward to remove. The bottoms of the three tubes should be visible. DON'T TOUCH THEM!! Now look under each tube. If one is leaking, there will be a wet spot (or sometimes a puddle!) underneath the tube. This will have to be serviced by a TV tech. Hope this helps...
Jan 26, 2007 | Akai PT4799HD Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
