Question about Epson WorkForce 600 All-In-One InkJet Printer
Hi, there is continous paper jam flashing light indicated at the printer (epson 600). i have checked but i found nothing jammed. i wounder i could be the reason. your support is apperciated. Regards. i can be contacted at sonofsouq@yahoo.com
Sorry - no solution, except to perhaps agree with the guy who says throw it out the window. I only wish I wasn't just on the first floor. This thing does more jamming than printing. It claims a jam when there is none. Infuriating.
Posted on May 01, 2012
  • 425 Answers
Hi, since you checked the paper jam and you did not find anything, You need to do a general troubleshooting .
How to Clear a Paper Jam in an All-in-One Printer
Even the best all-in-one printer has the occasional paper jam. You should be familiar with the clearing process before a jam stops you in your tracks. Most jams are caused when the paper negotiates the turns and rollers inside the machine. Check these places first when the paper jam light starts blinking. Follow these steps to make clearing a paper jam easier.
Things You'll Need:
* Nasty paper jam
* All-in-one printer
Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands on the metal tools inside the chassis.
Pin down the exact location of the jam. The three hot spots for a jam are before a sheet completely leaves the paper tray, between the feed tray and the print carriage or between the print carriage and the output tray.
Pull on the sheet with both hands and steady pressure. Don't tug too quickly. You might rip the paper, leaving a chunk of it deeper in the machine.
Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
Use the carriage access door to get at a jam further inside. You may need to move the print carriage out of your way to get at the jam.
Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Tips & Warnings
Avoid using different sizes and kinds of paper while printing. Save different paper types for a separate print batch.
Correctly load paper into the feeder tray to reduce the chance of jams in the future. You can find instructions in your all-in-one printer's manual.
Allow the printer to reset itself automatically after clearing a paper jam before further use.
Reaching inside an all-in-one printer while it is turned on is a good way to get shocked. Turn off the printer and allow the residual charge to dissipate before you put your hands inside it.
Hope that help..
Posted on Nov 06, 2010
  • crippledxnin Nov 22, 2010
    all right what you have to do is first get your printer find the nearest window and throw it, 2nd go to best buy and get a better one most likely an HP there wayyy better.. this printer is the worst
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
Mar 05, 2011 | Epson Stylus C48 InkJet Printer
Ink light and paper light flash alternatively, printer does not work
Hi - According to the Epson manual that error indicates that paper may be blocking movement of the print head.
Turn off the printer, then open the cover and remove any jammed paper or foreign objects. Turn the printer on. If the lights continue to flash you're most likely going to need a dealer service.
Hope it's the paper.
Good Luck, Mikeywaf
Feb 28, 2011 | Epson Stylus C66 Inkjet Printer
Epson Stylus 1200 lights indicate carriage jam
This means that your Epson printer has come to its end of life. In short, Epson wants you to retire your printer and buy a new one. Your Epson printer may be in good shape which is often the case. But Epson has this build-in "feature" which they want you to buy a new one.
Jun 15, 2010 | Epson Stylus Photo 1200 InkJet Printer
The pause light continous blinkiing
plz check the ink status and check is there any paper jam
Nov 01, 2008 | Epson LQ-2180 Dot Matrix Printer
Red Paper light keeps flashing
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
Oct 02, 2007 | Epson Stylus C86 InkJet Printer
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Epson WorkForce 600 All-In-One InkJet Printer Logo
1,241 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
