Question about Miele Coffee System
Hi - I have a miele cva5060 coffee machine. The grinder has stopped working, any ideas or solutions?
    Problem Solver:
  • 12 Answers
Sounds like grinder, over heated or got jammed by foriegn item (stone, pebble, etc...). If it over heated, then wait a few minutes, and then try again. Grinder also has a heat fuse that may have burnt out. If grinder doesn't work, after waiting 15 minutes, then a technician may have to replace grinder.
Posted on Nov 17, 2010
  • tim_stanger Nov 17, 2010
    Thanks for the response - I think it is probably a foreign object in the grinder. It does not re start even after turning the machine off for a few hours. When it starts making the coffee you hear an electric switch turning on and off at the start and end of the grind part of the program, but the grinder does not start. Anyone know what a new grinder will cost to be installed?
I have Miele coffee system CVA 4062 the grinder is not working properly? I have cleaned everything, Descaled all that good stuff.
Its likely to be the brushes in the Grinder motor. These are replaceable but Miele does not sell them as a spare part. You may be able top fabricate your own if your technically minded and experienced and can disassemble the machine. Otherwise grinder needs to be replaced. Regards
Jan 18, 2017 | Miele Coffee Makers & Espresso Machines
Miele cva 5060 when i press on shows 'insert boiling unit.' And stucks there any solutions pls .
any chance you could put up a photo of your brew unit ? something has fallen out of mine and i can't figure out where to put it !
Aug 20, 2015 | Miele Coffee Makers & Espresso Machines
The grinder is not working
Likely causes are grinder has burnt out or temperature cut-out for Grinder has blown. Either can be replaced as a spare from Miele.
May 13, 2014 | Miele CVA4070 Coffee Maker
The grinder is not working. Only water is coming out.
Basically coffee is not being ground. Likely causes are grinder is faulty or temperature cut-out for Grinder has blown. Either can be replaced as a spare from Miele. Note: A possible cause for Grinder not working is that the carbon brushes are worn away preventing electrical contact. Unfortunately Miele does not sell brushes as a spare part.
Want to clean the grinder part of my built in miele coffee maker.
Very Carefully with the power plug pulled out of the wall.
If you do not have the manual, go on line and have customer service send you a detailed instruction manual or have a technician take you through the process.
Mar 25, 2014 | Miele CVA4070 Coffee Maker
I owe the miele CVA4075 BUT my whole bean grinder is not grinding the bean and only water gets dispensed, anyone have a solution?
Make sure the hopper is working correctly to see if there are any blockages, then check under the hopper to the opening where the beans go to the grinder. My guess is that there are a few beans and chipped portions of beans which are clogged under there.
Jun 28, 2011 | Miele Coffee Makers & Espresso Machines
Hi. I have a miele cva4060. The grinder is working but it does not seem to be getting any beans through it and I am only getting water dispensed instead of a coffee shot! It was working fine a few days...
Hi
If you hear its 'grinding' then that's good - problem is where is the ground coffee going or supposed to go??
Check there is no build up of damp/dried coffee grinds in the pathway between grinder and brew unit - this can happen if the machine is not properly cleaned say every 3 mths or more often depending on usage - coffee 'dust' can build up.
Also suggest remove all beans from grinder, vacumn last ones out. clean all around grinder opening. Add a dozen or so beans to the grinder, turn on and try again. If the beans disappear, its grinding properly. If they don't end up in the brew unit, then the hold up is as I said in that pathway - grinder to brew unit. If you cant see an obvious blockage/build up, suggest you have a tech look at it.
Cheers
Mike
Dec 10, 2017 | Miele Coffee System
Jura F70 Grinder stopped working
The switch or photo sensor is not sensing any beans present.
So it can't continue
Use torch to inspect bean entry area
Small brush etc
Apr 18, 2010 | Jura Capresso Coffee Makers & Espresso...
Miele grind cycle not working on miele coffee maching
hi,
if you move the grinder level across to the left in one action it can jam up the grinder and even damage the grinder. if adjusted is required you should move it one mark, make a coffee and then move it another mark and make a coffee.
if you can't hear the grinder operating when you make a coffee then it sounds like it could be damaged.
Dec 10, 2009 | Miele CVA615 Espresso Machine
Miele Coffee System Logo
571 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
