Question about Hoover Elite Rewind Bagless Upright VacuumVacuum
The vacume was plugged. Believe I unplugged it, but now it just blows air OUT, does not **** in. Everything is emptied and cleaned. Don't know what to do next. Just had new carpet installed today, and am unable to vacuume up all the pieces.
    Novelist:
  • 147 Answers
Even tho its empty and clean, if the hosing is blocked up then it will not **** up anything.
The hosing down below the attachment hose may still be blocked up and that will have to be cleared for it to suction again.
remove the attachment hose look down the hose at the back. you can also flip over the machine and look for the attachment hose to come to the brush roller. I assume it is blocked up there and not picking up properly.
Good luck.
Posted on Nov 06, 2010
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
Eureka Maxima 12 amp vaccum cleaner is not picking what can be done to make it pick up?
remove and clean the filter ( tap and brush filter or use a air compressor to blow out filter ) --- also check the vacume hose near the floor attachment for any dirt and debris that may be clogging the line. this should bring your vacume to full operation.
c...
Jan 22, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
I am not getting any suction?
if youi are not getting any suction - remove and clean the filter ( tap it/brush it or use a air compressor to blow clean ). also check the hose near the bottom of the vacume where it bends - dirt loves to build up there and clog the hose.
c...
Dec 31, 2010 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Very little suction when vacumming
Hi There,
I think I know exactly what the problem is with your Dyson. I'd be happy to try and walk you through it, but just want to make sure that you still need help, or if you've already fixed the problem.
Apr 05, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
The suction in my vacum is not good. I changed
Depending on the type of vaccuum you may have another filter. I have a hoover and there is the hepa filter and another filter under the dirt container. If thats not the case, try taking off the entire hose and shaking it around. There may be stuff crammed in there. If one thing gets stuck, then everything else sticks to that. I had the same problem and when I took off the hose and shook it, a bunch of nails fell out (remodeling) and it worked fine after that.
Aug 19, 2009 | Vacuums
After I run my vacuum for a couple of minutes it shuts off. If I unplug the vacuum and plug it into a different outlet most of the time it will start working again.
I would say check inside the plug and make sure the connections are tight. If the vacume runs fine on the other socket outlet then it will bw a faulty socket which cuts your hoover out. Can buy a new socket frount from diy stores for about 2-3 pounds. If the hoover also cuts out on the other sochet it will be a temperature cut out device on your hoover. If this is the case empty the bag and give it a good clean and get rid of any accumalation of dust/dirt
Jun 24, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
No suction from vacuum.
Blow out the filter with an air compressor if available. this is causing your problem. its usually a foam filter
Mar 26, 2009 | Hoover U5290-900 Upright Vacuum
Deodorizing the vacuum
First of all Clean out the vacum cleaner . Empty canister and take filter outside and hit on something to get all dust out . Now wash canister and filter with vinegar water and let dry before using vacum again. You might try using carpet fresh for pet odors on carpet and empty and clean canister and filter regularly. I own a cleaning business and this is a hard problem to solve with all vac. cleaners. Good Luck!!
Jan 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Loss of suction bissell vacume
that is normal for the vacume to shut off if the motor overheats you must keep teh dirt cup clean and empty and all the filters clean, when you empty the dirt cup if you have a lot of pet hair take the hose off and make sure that it is clean as well, and do not try to pick up any of those cleaning wipes that will stop it up real quick
Sep 29, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Hoover Elite Rewind Bagless Upright VacuumVacuum Logo
104 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
