Question about Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Frigidaire dishwasher PLD285ORDC3 Professional series: Wash cycle runs through but no water seems to be getting in. Soap drains down inside of door and dishes remain dirty.
  • 7 Answers
SOURCE: dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Posted on Nov 02, 2007
NJFIRESTORM
  • 84 Answers
SOURCE: Frigidaire Dishwasher
A common problem with dishwashers is the non-draining machine. If you are having trouble, check to see if the drainpipe and sink trap are clogged. If you still have drainage problems after doing this, check your drain hose to make sure there are no kinks or bends. if the hose looks worn out you can replace the hose pretty inexpensivley. if your have thoughly checked from dishwasher to trap under the sink where your dishwasher should drain to and it seems clear you may have to call in the repair man.
Posted on Jun 20, 2008
SOURCE: Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Posted on Jan 09, 2009
  • 686 Answers
SOURCE: Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Posted on Feb 20, 2009
MNfisherman
  • 11896 Answers
SOURCE: Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Posted on Jun 01, 2009
Frigidaire dishwasher leak
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
Sep 02, 2012 | Frigidaire Dishwashers
Ffbd2407lm frigidaire dishwasher stops washing cycle?
Sounds like you need a professional to diagnose the unit for repairs. You are either having a timer issue or a control board communication error.
Aug 24, 2012 | Frigidaire Dishwashers
After running a cycle, there is some water in the tub and the soap dispenser is open but the soap has only run down the inside of the door. It does not sound like there is a vigorous spray during the wash...
May have a stripped wash impeller. I would tear into the pump and look for any kind of obstruction but if its clean probably the motor assembly needs replacing.
Sep 27, 2011 | Frigidaire Dishwashers
Dishwasher fills and drains, but water is not spraying from the upper or lower arm. Dishwasher is normally very quiet, but it seems to make all the sounds it normally does (and no extras). When...
Hi jpcoop,
Please look at my Tip I wrote about how to ensure your dishwasher is washing correctly, I believe your dishwasher should be cleaned in this manner at least once a month:
CLICK HERE - > DISHWASHER NOT CLEANING WELL...
Hope it helps
Regards
JEDEMEYER
* If this solution was helpful, please rate it
Jul 10, 2011 | KitchenAid 24 in. KUDI02IRBS Stainless...
Frigidaire Dishwasher Professional Series runs loud now and the dishes aren't clean when it finishes its cycle.
Check the water supply line for kinks, check bottom strainer/drain inside to remove particles/trash blocking water from exiting to pump washer motor, be sure no items block rotation of washer heads. Good luck.
Feb 26, 2011 | Frigidaire Professional Series 24 in....
Im getting standing water at the end of the washing cycle.
Possible that there is a leak at the drain hose, failure of holding clips--, failure of drain valve/pump, failure of gaskets in the drain or door or it can be an over flow on the chamber due to failure of the drain.
Your observation to find the source of leak in the washer.
Jan 22, 2011 | Frigidaire Professional Series 24 in....
I have a Frigidaire dishwasher that is not workin...
Remove the drain end. Keep it above little . Check whether the water is retained inside the washing machine. If water is retained- check your drain valve in the machine. it is parmenantly open or having improper closure.
May 21, 2010 | Frigidaire 24 in. FDB510LC Free-standing...
Fridgidair Dishwasher takes long time to run
ok with the soap prime the sink before you start it and clean the dish washer.take a table sppon full of tang put it the dispencer and run the unit this will clean the unit
Apr 25, 2010 | Dishwashers
Frigidaire dishwasher won't end cycle - will run on and on for hours. Sometimes it cycles through, usually it just endlessly washes and rinses. I have to CANCEL the cycle, which causes the dishwasher to...
I would say the resettable thermostat has failed. There is a thermostat which senses the water temperature, and when it fails, it causes the dishwasher to run constant. Replace the thermostat underneath the dishwasher and that should cure problem. Part number is 154290204 (I know the number off by heart, that's how often it happens!)
Apr 07, 2010 | Frigidaire 24 in. FDBB540 Built-in...
Dish washer won't wash
is the drain hose to low causing the dishwasher to fill and drain at the same time,if the water level is to low the motor wont wash the soap out of the dispenser.hope this helps
Mar 03, 2008 | Frigidaire FDBB1940D Dishwasher
Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
131 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
