Question about Zanussi Washing Machines
Zanussi aquacycle 1200 error code e90 keeps coming on any answers please
  • 183 Answers
SOURCE: zanussi washing machine
E90 is not a listed error code however most 90 range codes relate to a faulty pcb, some times worn motor brushes and blocked filter and air traps can cause some innacurate error codes being displayed we would normally check these items prior to replacing the PCB Regards Advisor
Posted on Sep 01, 2007
  • 1294 Answers
SOURCE: Zanussi manuals
Click on 'washing machines' (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
Rate me pl if helped...................
Posted on Apr 04, 2008
kjmac
  • 97 Answers
SOURCE: Zanussi Turbodry jetsystem 1200
hiya
e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
  • 54 Answers
SOURCE: E90 alarm code keeps coming
E90 appears to be caused by faulty connectors to the main circuit board which appears in the bottom right corner, if you're looking at the washer from the front with the lid off (looking down into washer). This is fixed by reseating, cleaning the connectors.
remove 2 screws at the back which secure the top,
push the top backwards,
unplug the connectors to the front panel,
vibrations due to unbalanced load may have loosened them,
push them firmly back in socket,
pushed the top (back to front, make sure a plastic tab seats properly to secure front part of top panel) in place and fastened the screws,
power on,
run the machine empty for minimum cycle - rinse only.
Good luck!!!!
Posted on Aug 19, 2008
kevin000
  • 1847 Answers
SOURCE: hi zanussi fjr 1254 w error code e90 what does
This error code seems to be the control board detecting a wrong configuration (in other words, an illogical set of sensing conditions, from its connected sensors and wiring). It apparently can happen, when wires become badly contacting, or if contaminated with motor brush carbon (the horrible black powder that comes off the motor commutator and brushes), or corroded from other contaminants from the soap dispenser area. You should be able to check this, remove, clean and replace the contacts:
Thanks
Posted on Jul 01, 2009
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded · E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    Need a free download user manual for a zanussi aquacycle 1200
    You will need the model number to get an exact match, but there are 10 different aquacycle 1200 manuals you can download from here:
    http://www.manualshark.org/s/zanussi+aquacycle+1200+washing+machine+instruction++manual/
    Jun 28, 2011 | Zanussi Washing Machines
    Zanussi electolux aquacycle 1200 w/mc wont spin
    Try new bushes and make sure where bushes run is clean and free from carbon H
    Jan 09, 2010 | Electrolux Washing Machines
    Iv got e90 and e91 coming up on my 1200 wjd 1257 w can you help me rob
    E90 - communication error between printed circuit boards. check connections.
    Nov 01, 2009 | Zanussi WJD1257W Front Load Washer
    Hi zanussi fjr 1254 w error code e90 what does
    Thanks
    Jul 01, 2009 | Zanussi Washing Machines
    hiya
    hope this helps
    Jul 08, 2008 | Zanussi FJS1225W Front Load Washer
    Zanussi aquacycle 1200 smells coming from between the drum and casing.Suspect it is caused by a build up of slime etc.
    1. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
    2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
    3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
    I got it from this link: http://answers.yahoo.com/question/index?qid=20060827101905AANuYg4
    and here:
    http://deseretnews.com/dn/view/0,1249,600124768,00.html
    Jul 02, 2008 | Zanussi FJS1225W Front Load Washer
    Zanussi washing machine
    Sep 01, 2007 | Zanussi ZWF1430W Front Load Washer
    Washing Machines Logo
    136 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
