Question about Audiovox APS901 Car Prestige Remote Start
Pres remote starter Model APS-901, the remote will start the vehicle but then it immediately shuts off
  • Prestige Ele... Master
  • 625 Answers
PLEASE READ THE ENTIRE POST BEFORE BEGINNING
There are several reasons that could cause the remote starter to shutdown immediately after it starts:
1. It may be the lack of a tachometer signal. Did you hook up the green/orange wire to a uncommon wire at a coil or fuel injector? If not, did you program the remote starter for tachless? If you didn't hook up the tach wire, no problem; let's program the remote starter for tachless:
Turn ignition on, press and release programming switch three times. The parking lights will flash one time. Turn key off, then on, then off, then on. You are now in bank three (remote starter programming). Press and release the programming button five times. The parking lights will flash the number of the times for the setting for this feature. If you have not attempted to progarm the unit, it will flash two times (default setting is for TACH). Press and release the start button on the remote once, it will flash three times; press and release the start button again, it will flash once. The unit is now programmed for voltage. Turn the key off. If you have not attempted to do any programming on the unit, the default setting for crank averaging is AVERAGING. This means that you will have to start the vehicle at least four times with the key to be effective. Test the system.
If the problem still exists, let's try this:
2. If you did not hook up the tach wire and you already had the unit programmed for voltage and, the remote starter shuts down (probably when the parking lights come on); the 901 is seeing a drop in voltage and you need to hook up the tach wire. Connect the green/orange wire to an uncommon wire at a fuel injector or coil. An uncommon wire is one that is a different color, at the same pin location, on each coil or injector. For example; compare two fuel injectors: if they are two pin connectors you may see an orange and a pink. At the next injector you may see an orange and a blue. The orange is the common wire and the pink and the blue are uncommon wires. You may connect the green/orange to either one of the uncommon wires. After the wire is connected, turn the ignition on, press and release the programming button three times. The parking kights flash once. Turn the key off. Press and HOLD the programming button, start the vehicle. The parking lights will begin to flash, continue to hold programming button for approximately 15 second. Release the programming button, the parking lights will come on then, go off. The tach is now programmed. Turn vehicle off. Refer to the above section for remote starter programming features in bank three. Test system.
Remember: If you did hook up the tach wire there is no need to program the 901 for tach. Tach is the default setting.
3. If the remote starter still continues to shut down, the problem may be with your need for an immobilizer bypass. You failed to mention the year/make/model of the vehicle so, try inserting the key into the ignition then, remote start the vehicle. If the vehicle starts and runs, you will need to bypass the "chip" in the key for the remote starter to function as desired.
Posted on Nov 17, 2010
Aps51 won't learn tach
Never heard of an APS 51, Prestige Remote Starter.There is a APS 57. If it is a 57 then yes.
Jan 24, 2014 | Prestige Remote Start
I have a prestige aps 901 I just replaced the car batterie now the remote start will start the engine but imediatly shuts off what needs to be reprogramed?
check the fuse and relay to the remote start if not that then it might be the module itself if it is aftermarket it was probable shorted out when battery was changer and may need a new one
Jan 23, 2014 | APS-901 Prestige Remote Start
Prestige APS-51
This forum is for Cameras. Please repost in a forum dealing with either electronics or motor vehicles. Thank you
Jul 13, 2017 | Audiovox Prestige Aps51 Car Remote Starter...
I changed the battery in my remote now my car will not respond
Reprogram the remote: press and hold the f button for approximately 8 seconds. the remote will flash three times. press the remote start button on the remote. the remote is now ready to pair. enter vehicle, turn ignition on, press and release button and antenna, immediately press and hold same button, the vehicle should respond with a horn honk and/ or light flash on antenna. While holding button on antenna, pres lock button on remote...vehicle should respond with a confirmation horn honk and/or light flash. Release button on antenna, turn vehicle off. Test system.
Jul 12, 2012 | 5101 LE 1 Way Car Remote Starter System
I have a Prestige Model APS-775 3 Button Remote Start Security System made by Audiovox in a 2000 Tundra. My problem is that since I got my truck back from the frame recall (they replaced the entire...
The starter fails to disengage? Do you mean that the starter engages but the vehicle does not start? If so, there could be an issue with the immobilizer bypass. The vehicle is not seeing the transponder from the key/bypass, thereby not engaging the fuel pump. One way to confirm this is to put the key in the ignition and then remote start the car. If the vehicle starts, then you have successfully diagnosed the problem.
Or, do you mean that the vehicle starts and shuts down after 5 seconds. If so, the tachometer wire may have been disconnected during the repair service. The tach wire is green with an orange stripe and it may still be hanging (unattached) in the engine compartment. Try tracing any wiring harness coming through the firewall into the engine compartment on the driver's side that has an "aftermarket appearance", meaning that it may appear out of place in association with the factory wiring harnesses. Make sure that all the wiring is connected. The tach wire is black at the diagnostic connector on the drivers side of the motor or, you can use the uncommon wire at the coil.
Mar 10, 2011 | APS95BT3 Car Transmitter with 3 Button...
Have a Audiovox 901C installed and factory remote will not unlock while remote started. What wirre do I use to by pass.
There is no solution to make your factory remote work when the car is running. This is the issue with honda/acura, toyota/lexus, some fords, etc. Here is what must be done; connect the blue/black of the four pin connector from 901C to the unlock and/or disarm wire of the vehicle. This will unlock the door before start. Also, you have to connect the black/yellow to the vehicles lock wire to relock the doors during crank or, the black with green to relock the door after start. Now, you will be able to press and hold the start button of the 901C remote to unlock the doors while running.
Feb 18, 2011 | APS-901 Prestige Remote Start
Car starts then stalls I have installed a Pretige remote car starter on My 2005 Cadillac Escalade EXT. I have the bypass installed with the key in it. The truck starts then stalls. Any answers?
You have the wrong bypass. The bypass you are using is for universal transponders. You need the Passlock 2 bypass. The passlock is a resistance that is read from your ignition cylinder by the bcm that will allow your truck to start.
Jan 20, 2011 | APS-901 Prestige Remote Start
I'm looking to get the user manual for a car alarm: aps2k4sflcf.
Go to this site http://auto.manualsonline.com/manuals/mfg/audiovox/audiovox_remote_starter_product_list.html
and click on Platinum APS 686T - Audiovox Remote Car Starter Owner's Manual
and click on APS 686 - Audiovox 4 Channel Remote Car Starter Owner's Manual
Jan 16, 2011 | Prestige APS686T Remote Start and Keyless...
Reconnect remote starter
Those devices, when operating properly, are commonly not disconnected, but you could attempt to find the power lead and the in-line fuse to make those re-connections, also check the battery(s) in the remote. If the disconnection is more in-depth then you should acquire the installation and owners manual from Audiovox, so as to troubleshoot and maybe discover what else is disconnected.
Good luck...
Feb 23, 2009 | Car APS921 Remote Starter - Keyless Entry
Audiovox APS901 Car Prestige Remote Start Logo
407 people viewed this question
Top Prestige Electronics Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Prestige Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
