Question about Frigidaire Microwave Ovens
My downdraft (PL36dd) will not stay up - Frigidaire Microwave Ovens
Cook top light stays on
Sounds like the bulbs shorted out the smart board, this happens sometimes when folks change the bulbs without up-plugging the oven.
Mar 30, 2014 | GE Microwave Ovens
Need a wiring diagram for the kitchenaid downdraft-/motor control switches
We have many of these schematics, but we would need the full model number with any suffix in order to provide you with free assistance.
It is usually found on a tag located inside the cooking cavity or around the door frame or controller frame.
Since FixYa is still not notifying us when you respond to clarification requests, you will have to post a new help request with your model number and symptoms / questions.
Or feel free to contact us directly here for free help.
Sep 16, 2011 | KitchenAid Microwave Ovens
HOW TO UNLOCK JEN-AIR STOVE TOP MODEL# JED4536WR01
The All Off cooktop touch control turns off the downdraft exhaust
system and all surface cooking areas that are in use at the same
time.
The Lock cooktop control avoids unintended use of the surface
cooking areas. When the cooktop is locked out, the surface
cooking areas cannot be turned on by the cooktop touch
controls.
To Lock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds. After 4 seconds, ALL OFF/LOCK will glow red,
indicating that the cooktop controls are in the lockout position.
To Unlock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds.
Apr 24, 2011 | Microwave Ovens
The burners light indicator stays on even when the burners are turned off
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on heatman101
Apr 23, 2011 | Microwave Ovens
The light for the right back burner stays on,even though the burner is turned off and is cool
heatman101
Dec 25, 2010 | Microwave Ovens
I have come down to find my aga cooker out the fire has gone out. There is oil around the burner but I can see no reason why it has gone out. Any suggestsions?
Much better than a microwave, any day!
It is quite common, if the fuel tank is not checked yearly, that condensation may build up in the fuel line and finish up with water in the fuel, causing the problem you describe. Also a sharp downdraft from the chimney can blow the pilot flame out.
Make sure it is cleaned before you re-light it. Preferably get the system serviced.
Hope this helps.
Oct 29, 2010 | Microwave Ovens
Does stove-top need downdraft if microwave has oven-hood combo?
We have a stove with no downdraft, and a microwave with a hood above it. It works just fine. I expect you could keep your downdraft and put a microwave without a hood above it, and that would also work. I don't think, however, you can buy an above the range mocrowave oven, that slides in on brackets, which will not have a hood.
Jan 08, 2009 | Microwave Ovens
I have a downdraft ventilation system Best by Broan that does not raise when switched I believe it got stuck and the gears may have been stripped. Would like to know my options or at least see some...
The Broan Best unit is older but if you call this number you will get the technicians there who can tell you what parts are available.
1-800-637-1453
Apr 03, 2008 | Microwave Ovens
Microwave Ovens Logo
48 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
